Question about GE JBP35BHWH / JBP35BHCT / JBP35CHCC / JBP35EHBB / JBP35WHWW Electric Kitchen Range
The jkp15boa2bb I need to know the inside dimensions
Need to know Size/ Dimension
Inside of the doors there is a tag...show model #, cubit sizes, rating and more.
Apr 23, 2015 | Kenmore Refrigerators
Where is the hard drive in the dimension 2400 dell. I see the cd drives, the power supply, the cooling fan, the heatsink, the video card, the memories... so where is the hard drive?
You know the power button in the front? If you open the cover to see the insides, there is the HD that is kind of covered by a metal slot (has like holes...). Well, the HD is right next to the power button in the front, but inside.... Here is a picture. The wires are attached to the HD. yup.
Feb 22, 2011 | Dell Dimension 2400 PC Desktop
What part number do i need for replacement cd rom rw dvd drive for the 2400? Thanks
Hi ,
Any one will do , you just need to know he interface used inside your machine : IDE ? Sata ?
Regards ,
Fanaudi .
Jan 18, 2011 | Dell Dimension 2400 PC Desktop
About where the graphic's card in on my dell Dimension 3000.
From a general look on Dells website your computer only supports PCI style cards. You might have a completely different style of motherboard in there depending on when your PC was made. The only way to know whats truely inside your computer is to look up the Service Tag that is on the outside of the case. You can also take the side cover off (after you unplug the computer) and look inside if the motherboard (towards the bottom) in there only has 3 Cream colored slots on it then it only supports PCI cards.
Jul 01, 2010 | Dell Dimension 3000® Pentium® 4...
Dell Dimension 8400 won't power up at all
It could be your PSU (power supply unit) inside your desktop.
At any rate, I need to know more about its condition i.e. actions taken before incident before I can give better solutions.
Dec 07, 2009 | Dell Computers & Internet
I need to know the cubic feet of my upright frost free frigidare freezer Model # MFU17F36W6
get a measureing tape measure inside dimensions multiply them together eg: a freezer with an inside dimension of 2' X 2' X 3' would equal 12 cubic feet if want an exact value measure in inches 24" X 24" X 36" = 20736 and divide by 1728 will give you cubic feet cool eh.. where did I get the 1728? (12 X 12 X 12) =1728 converts cubic inches to cubic feet Good Luck let me know when you pour that cement pad for under your shed I tell you how many yards to order
Oct 23, 2009 | Freezers
Inside of PC is extremly dirty!
There should be a gray button type thing on the top of the back end of the case and the bottom. You will need to push both in at the same time to get the case open. Push both in and slide the case apart. I found that having somone pull the case apart while i push on the buttons is easier.
Let me know if how it goes.
Regards
Dec 13, 2008 | Dell Dimension 2400 PC Desktop
Installing new airconditioner
mesure the outside dimensions and those will be the rigth dimensions to go by
May 25, 2008 | GE AJCQ08ACB Air Conditioner
GE JBP35BHWH / JBP35BHCT / JBP35CHCC / JBP35EHBB / JBP35WHWW Electric Kitchen Range Logo
79 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
