Question about Tanita Health & Beauty
I have a Tanita BC 557 scale that will not turn back to zero. It is stuck on the activity level. My scale has been verified by Tanita to be under warranty for 10 years, and my scale according to model
I take very good care of the scale, but I DO understand others have had the same problem with Tanita not honoring their warranty. Where do I go from here???
SOURCE: I have a tanita tbf-612
Press the Set and Up Arrow buttons at the same time. Release the buttons, the display will flash. Press the Arrow button to cycle through each weight mode until just the mode that you require is displayed. Then press Set. The display screen will flash to confirm your selection and store in memory.
Note: If weight mode is set to pounds or stone-pounds, the height programming mode will be automatically set to feet and inches. Similarly, if kilograms is selected, height will be automatically set to centimeters.
Posted on Mar 14, 2009
fitnessbalan
  • 59 Answers
SOURCE: somehow my tanita ultimate scale has been switched
Q: Why does "st-lb" or "kg" appear when taking a measurement?
A: The unit's "Weight Mode" has been set to measure your weight in units of stone-pounds (st-lb) or kilograms (kg). Tanita's Body Fat Monitors and the UltimateScales can measure weight in three different modes: lb (pounds), kg (kilograms) or st-lb (British stone-pounds). To change the setting, first find out which model you have (it should be written just above or below the display screen of the unit).
Method 1
Body Fat Monitor/Scales: TBF-611, TBF-612, TBF-621, TBF-622, BF-541, TBF-560, TBF-572. UltimateScales: 2000, 2001, 2001T. BF-662, BF-555, BF-556, BF-558, BF-559, BF-625, BF-626.
Method 2
Body Fat Monitor/Scales: BF-542, TBF-551, TBF-521, TBF-531, BF-681, BF-682, BF-679, BF-680, BF-578, all Ironman products, and all InnerScan products.
Select the preferred weight mode by using switch on the back of the measuring platform.
Posted on Mar 16, 2009
SOURCE: TANITA UM-016 BODY SCALES
Try downloading the um-80 manual. It's equivalent.
Posted on Apr 25, 2009
SOURCE: Tanita Ultimate Scale 2001 - no user manual -how to set it?
does your scale have an orange SET button and a button with a triangle (or arrow) below the display?
Try this... make sure the scale is turned off. (and you are not standing on it)
Now press the SET button.
2 arrows should appear on the display. use the arrow/triangle key below the display to make changes and the SET key to choose.
If you have the same scale as me, you are prompted to chose Adult/Child followed by Male/Female, and finally input your height in feet/inches by pushing the arrow/triangle key until the display shows the desired height.
Press SET to finish and step on the scale like you usually do. It will now show your weight followed by your body fat %.
Hope this helps you!
Jacob
Posted on Jul 14, 2009
SOURCE: need to reset scale bf-681 tanita scale
I have a tanita body composition scale BC-534. It suddenly stopped working. I have new batteries. Is there a way to reset the digital disolay?
Posted on Jan 20, 2010
Need the instruction manual for the Tanita BC 534
how do you remove the glass on the printout section to clean it
Sep 22, 2011 | Tanita BC-534 InnerScan Body Comp Scale
Tanita BC 543. I need to clear the memory held under buttons 1-4 to allow new people to use machine and update age etc
leave the scale off, and only press "set".
the scale will flash "1234"
choose your number with the ^ v arrows and press set.
all options will then be open to be set.
Jul 09, 2011 | Tanita BC-533 InnerScan Body Comp Scale
Hello, my new device Tanita BC 532 measure weight and body fat%, but no reaction when I try to press rest of the featured keys. I use the description attached, and the weigth and fat% showes alternly on...
My Tanita BC-532 also developed this fault. It seems to be common with a number of the models! I asked Tanita and over a number of emails this is what they said:
"not to place it in wet rooms and remove the batteries if stored for a longer time period."
When I said it was in a bathroom (isn't that where everyone keeps their scales) NOT a wet room - they said any bathroom is classed as a wetroom!
When I said how can you tell if the batteries are just about to run out (that's what seems to trigger the fault) I had no reply; and when I asked how long is a "long period of time" - 2 weeks/ 2 months (we used to use ours every 1-2 weeks) again no reply to this question.
Now out of warranty after 5 years Tanita suggested it I didn't follow either of these instructions above (in the manual, but not defined) then I only have myself to blame. They did suggest one remedy was to:
"1.Take out the batteries.
2.Make a short-circuit between (+) and (-)with a piece of wire.
3.Put the batteries back and try it out.
If that doesn't work, you simply have to discard it. "
Personally I don't think this is satisfactory and I won't buy Tanita again. Scales should last much longer. They should make any warnings clearly defined - especially based on the number of times this happens according to reports from users on internet.
It seems this is a well known fault and I would thus suggest scales are not fit for purpose over longer term. Tanita should own up to this and stop avoiding their responsibilities.
Should you not keep in the bathroom, use every few days, and replace batteries before they get too low - then these scales are great (well they were for the first 5 years!)
Dec 25, 2010 | Tanita BC-533 InnerScan Body Comp Scale
I want to buy TANITA BC-612 design ,but I want to get the Enghlish language to read, do you know how I get it?
The BC-612 model in UK/US market is BC-601, you can download the manual from Tanita UK website.
Dec 16, 2010 | Health & Beauty
Lost the manual
To learn about the scale you can download the manual on the link below right under the buy now.
http://www.tanita.com/en/.downloads/download/?file=855638025&lang=en_GB
Good Luck
May 08, 2010 | Tanita BC-533 InnerScan Body Comp Scale
Need to reset scale bf-681 tanita scale
Jan 12, 2010 | Tanita Bf681 Body Fat Monitor Scale...
Tanita innerscan stopped working. New batteries installed but will not switch on. There is no display except on the guest button which comes up with "88888" when pressed. Any ideas - thanks
Maria,
sorry no, i don't have a sltn. however i recently experienced the same issue w/ my tanita innerscan. i've just notified Tanita's customer service... have you had any progress?
Dec 30, 2009 | Tanita BC-533 InnerScan Body Comp Scale
CALIBRATING A TANITA KD-200-110 DIGITAL SCALE.
According to Tanita, you must send the scale back to the factory to adjust the calibration. As of September 2011 the cost is $125.00
This is more the scale costs.
Moral of the story. Don't buy Tanita.
Aug 24, 2009 | Tanita 1479V - Digital Pocket Scale /...
Tanita BC-552 Body Composition Monitor Won't Turn On
I contacted Tanita for you and am working on the manual the link here is for the download however the file says it is currupt maybe it will work for you. if not I have requested it from tanita. http://www.tanita.com/en/downloads/personal/
This is the response from Tanita
Thank you for your e-mail.
It appears that this could be a battery connectivity issue.
When you change the batteries – please insure that you are getting a nice tight fit and that the positive side of the batteries are making contact with the inside wire. Sometimes the batteries can differ in length so you can gently pull on the coil to help make it fit more tightly. Also take a look at the inside contact points to make sure there is no rust. If there is rust – you can clean by using a green kitchen scotch-brite pad & a q-tip dipped in rubbing alcohol.
If you continue to have problems we may be able to replace under warranty.
Your scale does carry a 10 year warranty but you will need to have a copy of the original itemized receipt (or order confirmation if purchased online) in order for us to process a warranty claim.
If you happen to have a copy of the original receipt or order confirmation, please contact our customer service line between 8:30 – 5:30, Monday – Friday, (Central Time) at 847-640-9241, and we can issue you a Return Merchandise Authorization for product replacement
Sincerely,
Cheryl Morse
get-attachment.aspx?uid=1.23025525&folder=oldmail&partid=4
TANITA CORPORATION
2625 South Clearbrook Drive
Arlington Heights, Illinois 60005
Office: 847 434 3985
Email: cmorse@tanita.com
Apr 26, 2009 | Health & Beauty
Health & Beauty Logo
63 people viewed this question
Top Tanita Health & Beauty Experts
dkmun
Level 1 Expert
Ankit Chandel
Ankit Chandel
Terry
Terry
Are you a Tanita Health and Beauty Expert? Answer questions, earn points and help others
