Question about Homedics Digital Scale
How do you get new battery back in slots? - Homedics Digital Scale
How to unlock my Samsung galaxy note 4?
  1. Switch off your Galaxy Note 4.
  2. Take out its battery.
  3. Pull the Sprint SIM card out of the slot.
  4. Insert a new SIM from a different wireless carrier in the SIM slot.
  5. Place the battery back in the mobile.
  6. Power on the phone.
  7. When prompted, type the unlock code that you received from Sprint. http://electronicshelponline.blogspot.com/
Dec 07, 2015 | Samsung Cell Phones
How to cure a ticking relay in tns slot on kia rio.
If its a sealed relay, tap on it, or you may need to unplug and replace it.
Oct 19, 2015 | 2003 Kia Rio
Can you tell me why does my gigabyte ga-7mmxp have a long beep?
It's memory problem.
You should try another RAM module or stick it to another slot.
  1. If the another RAM works - you need new RAM
  2. If the RAM in another slots works - the original slot is destroyed
  3. If any of above works, motherboard RAM slots are destroyed - you should buy new motherboard
May 09, 2011 | Gigabyte Computers & Internet
A new battery on my 250 aquilla and it still goes flat after a day or so. I put a multimeter on the terminals while engine running and it;s hardly showing a charge the readout flucktuates thinking its the...
GV250: Removing the Battery:
Since I've done it a couple of times recently, I thought I would put together this quick HowTo.
Remove the seat. You don't necessarily have to but I find it makes it easier.
Using a #3 Phillips head screw driver, loosen the screw holding the chrome piece below the plastic panel in place.
Note: Do not remove the screw, just loosen.
Pull the plastic side panel towards you until the tab comes loose from the slot. There will be resistance because of the tab slot that holds it in place.
Note: do not pull to far towards you as you may damage the tongue below (see Appendix A for visual reference)
Using a 10MM socket wrench or a #3 Phillips head screwdriver (I recommend the 10MM socket wrench) remove the two bolts holding the bracket battery.
Gently pull the battery out and, using a 10MM socket wrench or a #3 Phillips head screwdriver (I recommend the 10MM socket wrench), remove the two terminal bolts.
Note: For the positive terminal, you will need to pull the rubber boot back. It should slide back along the cable.
Tuck the loose terminal cables back in the now empty battery slot and replace the plastic side panel and seat.
Thats it, your done.
Appendix A:
There is a tongue on the plastic side panel that slides into a slot in the chrome below it. Do not put the tongue behind the slot, it must go inside the slot
Jan 03, 2011 | 2002 Hyosung GV 250 Aquila
Cannot open the battery compartment on my suunto x6 without breaking it....any ideas?
  • Turn the Suunto over to view the backside. Insert the quarter in the coin slot located on the battery compartment cover. Turn the coin counterclockwise to the "Open" position marked on the back of the case.
  • Remove the battery compartment cover. Remove the old battery from the battery compartment. Make sure the o-ring and all surfaces are clean, dry and not damaged. Do not stretch the o-ring!
  • Place the new battery into the battery compartment (negative side down, positive side up). Make sure the o-ring is in its place, as to keep the Suunto waterproof. Place the battery compartment cover back onto the backside of the watch.
  • Insert the quarter back into the coin slot and turn the coin clockwise to the "Close" position marked on the back of the case.
  • If this doesnt work take to a jeweler who has tools.
    Jewel
    Aug 31, 2010 | Suunto X6 (black) Wrist Watch
    How do you replace batteries in freshair remote control . i cant get the back off the remote control.
    For the Fresh Air 2.0 or 2.1 remote, its oval shaped.
    1. Hold the remote so that that the power button is facing up.
    2. Then flip the remote in your hand so you can see the back side.
    3. Then with your other hand, side your index finger from the top down the back side of the remote until you finger nail catches the a slot (about an inch from the top of the remote). Right below that slot, is a plastic tab that secures the battery cover. Using your finger nail, pull that tab down about 1/16" away from the remote to unlatch the cover.
    4. Lift the cover off the remote, and you should see 2 AAA batteries. Remove the old batteries and replace with 2 new batteries.
    5. Align the two tabs on the battery cover into slots on the back of the remote.
    6. Gently press the back cover and the latching tab should shap into the remote.
    Hope this helps.
    Jun 14, 2010 | Ecoquest Fresh Air Air Purifier
    How do you replace the battery in a keyless remote for Pontiac G6 GTP?
    hello there
    first you will need to remove the cover usingaflat tip screwdriver
    look for a slot on theback of the fob or it may even have a slot inthe middle of the back for it simply pry up on the slot or it may unscrew or pop off
    and it will come off
    once your battery cover removed. Before you tear the battery that gave you weeks of frustration right out of the thing, take a look at how it's in there so you can put the new battery in correctly. Most remotes have a + sign on the side that gets the + side of the battery facing up, but you'd be mad if yours was the remote that decided not to provide that info.:
    Nov 23, 2009 | 2006 Pontiac Grand Prix
    Cant figure out how to open back of phone to put in new battery
    First: you need to simply remove the back; then after you remove the back the battery will be there. If it wasnt removed simply remove the battery from the back of the phone without it getting wet. There might be some slight difculty doing this. What you have to do is ; slam the back of you're phone; on you're thigh if you have anyproblems. also place the sim card in behind the battery u will find the sim card slot; . Then place it in the slot facing up wards.
    Thank You; :-* Hope it works!
    May 02, 2009 | T-Mobile Sidekick II
    Chabging the batterys on the prg 40
    If you look very closely you will see that one side of the clip goes nearly under the battery. the plastic there has what looks like a small hole near the metal. It is in fact a slot. use a straight pin inserting it in the slot and gently moving the clip away from the battery. There is bend tension on the clip and it should raise slightly when released. Then use a tweezer grab the battery.
    use your tweezer to hook the clip back over th plastic after you insert 4 new batteries.
    Jul 01, 2008 | Casio PRG-40T-7 Pathfinder
    Cannot find slot location to replace storage card
    The memory card slot is a tiny slot below the battery.
    1.Remove the back cover of the HTC
    2.Remove the battery
    3.You would be able to the card slot on the lower left corner of the device.
    Thanks
    Mandeep
    Jun 04, 2008 | HTC P3300 Smartphone
    Homedics Digital Scale Logo
    70 people viewed this question
    Top Homedics Health & Beauty Experts
    Jim London
    Jim London
    Ankit Chandel
    Ankit Chandel
    Are you a Homedics Health and Beauty Expert? Answer questions, earn points and help others
