Question about Weather King 10AJA3001AH Air Conditioner
My weather king air conitioner lines frozen and unit won't shut off , what can I do?
Stickx
  • 148 Answers
SOURCE: Condensation pan replacement
im one of your techs i did some research thanks
Posted on Jun 28, 2008
  • 358 Answers
SOURCE: What is your oponion of a Weather King Unit ?
I installed Whethe king ,Goodman ,Philco,Intertherm condensing units and there's no much difference in prices and the quality is the same ,just choose the one with better warranty.But if you want to expend more money the next one will be a Rheem or Ruud unit ,and after that you have more expensive and more complicated units like Lenoxx or Trane but those have more electronic parts that can brake and they very expensive to fix.I'm in this business for a long time and if ineed to get a new one i'll go for a standar price one with a good warranty.
Posted on May 02, 2009
lojacksdad
  • 121 Answers
SOURCE: Weather King 13AJA36A01 AC freezing up at night
check the inside coil is dirtyor may be low on freon
Posted on May 14, 2009
localwonder
  • 6784 Answers
SOURCE: not blowing cold air
Your in house core could have frozen over. check the core inside the indoor blower unit. it may have frozen over. this will interrupt the cold air function.
Posted on May 28, 2009
hvac1
  • 338 Answers
SOURCE: a/c unit not cooling house weatherking model #12AJA3601
I use a spray nozzel on my water hose to clean out the oustide coil. You can go to a local Hvac parts store and get a cleaning gun and foam to clean the coil. I just use my water hose and sprayer with arm and hammer baking soda.
Posted on Jun 04, 2010
We have a weather king central air unit mod# WAKA-030JAZ. ser#5339 mo6959417. volts 208/230. compressor rla 13 5/13.5. outdoor fan motor f.l.a.9. mfd 02/05. hertz 60. l.r.a.76. hp1/6 min supply...
I would bet the outside units contactor is bad. This is the device where the two thermostat wire connect outside. If this is pulling in/out as you turn the stat on/off then it is working. I just fixed one yesterday with the same symptoms and found the start capacitors were bad. If they are bulged at the top or bottom then they are bad. Good luck.
Jun 19, 2011 | Weather King Heating & Cooling
Power went out briefly and now the unit won't come back on. Is there a reset button?
unit may have power saver box and until you either open unit and manualy engauge contactor or call your local power company it wont start.It has to feed power off unit to start
Jun 04, 2011 | Weather King 10AJA6001AH Air Conditioner
I have a central air unit that the line has frozen. How do i fix this?
Shut it down and keep the fan on so it will thaw out...then check the filter and have someone check the freon charge...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Aug 21, 2010 | Weather King 12AJA4801AH Air Conditioner
Not blowing cold air
May 28, 2009 | Weather King 10AJA6001AH Air Conditioner
Is there a reset for the a/c unit itself
check for fuses in disconnect at the out door unit or a reset button where the copper line set goes into the unit at make sure stat wires have not been damaged hope this helps
May 15, 2009 | Weather King 10AJA4201AH Air Conditioner
Weather king model 10AJA4201
Unit is over heating and setting the internal limit switch. Capacitor an/or outdoor fan could be failing.
Aug 21, 2008 | Weather King 10AJA4201AH Air Conditioner
Weather king
sounds like very high humidity in the house.....is water running out the drain?
Aug 06, 2008 | Weather King 10AJA2501AH Air Conditioner
Weather King contact info
479-648-4900 is the main line to the factory in Fort Smith Ar. Hope this helps, RepairUSA
Sep 03, 2007 | Weather King 10AJA6001AH Air Conditioner
Weather King 10AJA3001AH Air Conditioner Logo
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
