Question about Braun MR 550 M MultiQuick Handheld Blender
How to open - Braun MR 550 M MultiQuick Handheld Blender
Will not start but lights up
Put a multi meter across the motor when disconnected from the pcb. If it is open circuit then check the field windings, one of them may have a fuse taped to the windings that has gone open.
Apr 22, 2015 | Krups KB790 Blender
How do I open the prismacolor pencil sharpener
Unlatch the clear Top Cover to lift up like a Toilet seat lid which is hinged by a SUPER FLIMSY strip of plastic to the opposite side of the unit. This done with the Sharpening Holes facing UP.
Sep 28, 2014 | Sanford Corporation Prismacolor Premier...
Blender won't start
Test motor for continuity, if open circuit locate thermal fuse in windings and replace it. If not open circuit check cable for continuity, if that is ok you are likely looking at a new button control assembly.
Mar 12, 2014 | KitchenAid Kitchen Aid KSB560 5 Speed...
Kitchen aid blender won't turn and flashes lights
Motor open circuit most likely. Check the field coils for continuity if one is open it is possible a fuse in the field has failed. It is a job for someone with electrical knowledge.
Jan 25, 2014 | KitchenAid Blenders
How do I open a Kenwood hb720 triblade hand blender to replace the motor?
need instructions on how to put a sg500 together
Oct 23, 2013 | Blenders
PHILIPS HR1357
Good question! There is usually one screw under a label on the unit. After this screw is removed, the case can be squeezed, slid up or down or gently twisted side to side to open it. Each unit is different. I do not know this model specifically. Some cases ARE glued together and cannot be opened without breaking them.
Mar 29, 2010 | Philips HR1358 Handheld Blender
I have one of those back to basics blender express machines and it will not come open. i've run hot water over it and cold water but the thing is the seal ring was missing but it still closed so i closed...
The seal ring probably stopped the blender from tightening to far. It is a good idea to warm the blender but you can also try tapping it with a small piece of wood or similar as you try to open it. I think it may just need a bit more force to get it open. Be aware that it could break - but you can't use it at the moment anyway!
Nov 06, 2009 | Blenders
Braun blender 4191 motor part does not work. fuse is alright. cannot open the cover in order to asess the damage. please advise.
My GF broke our Braun handheld mixer type 4191 500W, trying to mix some figs, the mixer doesn't do anything anymore. I like the mixer very much. I poked a while trying to open it and look what is wrong. This is what i found to open it. On the top, where the numbers are to adjust the speed: remove gently that lid. Below that you'll find 2e lid with the numbers on (1-5), this you can get open by pressing inside the 2 holes with 2 little screwdrivers, push these 2 black tips away and the 2e lid can be removed. Unfortunately i broke my mixer up trying. Now it's open i see how it was. Good luck guys
May 01, 2008 | Braun MR 5550 M HC + BC MultiQuick...
Braun MR 550 M MultiQuick Handheld Blender Logo
50 people viewed this question
Top Braun Blenders Experts
Ross Keen
NOEL
NOEL
Are you a Braun Blender Expert? Answer questions, earn points and help others
