Question about Vizio L42HDTV 42 in. LCD Television
Vizio lcd 42" popped and half the screen went black
The tv just popped and then the screen had a black side and the other side had part of a picture but isn't black
  • 87 Answers
SOURCE: Vizio GV42L LCD TV screen black when turn TV on first time
If you are using a set top box this might be caused by turnig the box on at the same tie as you turn the tv on or slightly after you turn the tv on.  If you are using compnent or HDMI inputs the set needs to see the signal as it is turned on to know what formt the signal is in.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Posted on Oct 23, 2007
  • 300 Answers
SOURCE: vizio 42 hdtv lcd no power
lol , technicaly it's not possible to plug a USB PORT , into an RJ45 Phone Jack lol
But lets assume he did manage to do just that.
A. Land Lines in the united states phone system use -48 volts of electrical power.
B. USB ports that provide power to USB devices use +5 volts of electrical power.
What you have described to me would suggest to me that your USB port has been overloaded
by the input of a much higher voltage sourse ( the phone line )
Some suggested steps
1. completely unplug the computers power cable for approximately 15 seconds.
2. plug the computer back up and press the power button.
If this fails you may now have a defective motherboard or a blown power supply.
You have some options at this point.
You can change the power supply and see if that solves the issue
If a new power supply does not solve the issue
you will need to change the motherboard.
My advice on changing the motherboard is that you replace ONLY the motherboard first.
If more things like the Memory or CPU are dammaged , you will then replace them as needed.
I feel very dissapointed that your son was unable to accomplish his computer hacking goals lol
perhaps when he is older he will make a fine Engineer.
Thank you for using FixYa!
Az.
Posted on Sep 19, 2008
  • 155 Answers
SOURCE: Vizio 42", have picture for about 5 mins then screen goes black.
also check the power cord wire coming from the back of the tv is loose from the tv side or perfect.
Posted on Oct 26, 2008
ginko
  • 19396 Answers
SOURCE: 42" Vizio - no picture no sound
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
Posted on May 04, 2009
SOURCE: Broken LCD Screen on a Vizio VW42L. Where can I buy one?
Hello Sesman200,
We have a good screen in Stockton, CA... Call us at 209-465-6139 .. Dave
Thanks.
Posted on Jul 20, 2009
Snow on screen with no picture.loud noise on audio
42" Vizio TV flickering strobing easy way to repair VW42L ...
? 2:49
https://www.youtube.com/watch?v=Qba7_YHnXwM
Dec 2, 2013 - Uploaded by ozzysslayer
42" Vizio TV flickering strobing easy way to repair VW42L HDTV10A LCD TV ... EASY How to Fix Samsung LCD TV Flashing Flickering Screen!Missing: vp422hdtv10a ‎snow
Vizio Replacement Boards - ecoustics.com
www.ecoustics.com > ... > Plasma & LCD TV Forum
Apr 15, 2009 - I have a vizio p42hdtv10A that just went into a black screen. .... I have a Vizio VP422 HDTV10A that will not stay on or show a picture. I removed ... Vizio vp422 hdtv10a
Dec 20, 2011
May 13, 2011
More results from www.ecoustics.com
Dec 30, 2015 | Vizio VP422HDTV10A 42 inch 720p LCD HDTV
Im only getting half a picture
most LCD sets use two boards (or one with both in it) for this, one drives half the screen and the other the other half.
Possible bad board or bad connection where the board connected to the panel===that would be the worst case as the display which is called a panel could have a issue inside which is fatal costwise.
Nov 06, 2012 | Vizio 42 in. LCD TV
I have a VA26L vizio tv, the screen went black I have power but no sound how do I fix it?
I would like to know if you would describe the picture or screen as a dark swirling cloud like one?
Mar 16, 2012 | Vizio VA26L 26 in. LCD HDTV
Vizio VW42L went black screen, no sound could turn on but not off, with remote or on the side. Called a repairman, decided to purchase a new TV. Year gone by, plugged it in and it has worked for several...
Yes,the tv main Tuner signal board it is the problems and the causes it have intermittents shorts in sides.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv main Tuner signal boad for the replacement.
Jul 10, 2011 | Vizio 42 in. LCD TV
Vizio VU412L 42" made a
The pop has been generated by the explosion (literally) of an capacitor from the power board of the tv. When that happened the power source has been shorted and, if you're lucky, it went in protected mode. Fixing that is a relatively simple job - all you need is a soldering iron and a basic experience in using it. Follow this
http://www.youtube.com/watch?v=YCSNWi3UHf4
If you're unlucky the entire source has been fried and it will have to be replaced - here's a good one
http://cgi.ebay.com/VIZIO-VU42L-FHDTV10A-POWER-SUPPLY-DPS-283BP-C-REV-S0-F-/370477438027
Mar 06, 2011 | Vizio VU42L 42 in. LCD TV
My Vizio TV Screen went black last night. I cannot get a picture or the TV won't turn off unless I unplug it.
The slave inverter problably went out. Good luck finding if it is a 6632L-0471A The same thing happened to me and I can not find one.
Nov 18, 2009 | Vizio GV42L 42 in. LCD Television
Visio LCD TV - Partial Picture blacked.
Hello! I have a 32" Vizio LCD...within 30 minutes of the tv being turned on, black lines start running through the bottom half of the screen and eventually blacking out the bottom half of the tv screen. It also doesn't have anything to do with the ratio as I have tried that. HELP!
Jan 06, 2009 | Toshiba 42HP66 42 in. LCD Television
Vizio tv first screen had bluish discoloration and than few days later a pop and screen went black .ANY IDEA OR SUGGESTION all of the sudden started experiencing severe discoloration
This is called the pop of death! If you call vizio they will ask you if you heard a pop, this is a common issue and unless your under warrenty your looking at 916$ to fix it. (assuming you have no sound! If you do its 430$ plus tax for parts and repair. You can buy a used one on ebay for that price!
I have the parts numbers if you want them!
Call vizio if you have had this system for under a yr the will fix it free!
As for me my 50 and 42 inch had this issue and well I am out of warrenty.. I hate vizio lol!
May 24, 2008 | Vizio L32 32 in. LCD HDTV
Vizio L42HDTV 42 in. LCD Television Logo
424 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
