I accidentally entered self service mode on my hobart quantum and cannot exit,how do i return to the quick presets menu?
  • 95 Answers
SOURCE: Exiting service mode
All different brand of PTV has there way of excisting out of the service mode, panasonic don't list it, very hard to do, turn tv off then you see.
What about Bob
Posted on Mar 01, 2008
dsacco86
  • 1077 Answers
SOURCE: tv is locked in menu mode
Ok, you should be able to go to the philips web site and download a software for your TV for free.
The web site should show you how to preform this procedure with a USB memory stick.
I hope this works for you. So far, it worked for everyone else that had the same problem.
Posted on Mar 18, 2009
  • 36 Answers
SOURCE: How to exit service menu
Try this
Use the CLEAR button / long press on the MENU button to toggle between user and svc menu. Press EXIT button to exit svc menu.
Posted on Apr 17, 2009
pineworks
  • 4041 Answers
SOURCE: My pixma mx300 shows 5100 error message, and I
Hi You can Try 2 things.
ERROR 5100 means that there is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 01, 2010
gopakumarg43
  • 74383 Answers
SOURCE: hobart quantum scale says code cannot be used in self service mode
Try an other code.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Posted on Aug 29, 2016
Changed battery now radio doesn't display song or artists name. How do I fix this?
Once you disconnect the battery everything that is in your memories goes "poof" it will take a little time for all of your stations to come back. If I'm not mistaken you still have to set those manually. Radio is mostly satellite that's why you get song names etc. So drive let the computers collect data and before to long you'll get to see this names come up again. Hope this helps.
May 04, 2015 | 2010 Ford Edge
How do i return to the main menu using my 50 inch proscan smart tv?
What happened to the menu functions? Have you entered its service mode option to do any data adjustments. If you haven't entered in to, there should be no problem; just pressing the 'Menu' button again (on rare occasions 2 or more times press on it); will return to main menu. If you have entered the service menu, you should "EXIT" from service menu.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Jul 24, 2014 | Televison & Video
Clear/stop 1, 0, 7 color start does not work
Each menu is classified into two "Modes" depending on how you enter the service menus.
"Menu Mode" can be executed by pushing a sequence of keys.
"Special Mode" can be executed if you press certain keys at the same time as you turn the power on.
Each menu is classified as follows:
Menu Mode
Maintenance Mode Menu This is a menu for maintenance and service.
Special Mode
Fax Service Test Menu This is a menu for checking the fax mode.
MAINTENANCE MODE MENU
Selecting an Item
To select an item, press the "Up" or "Down" key.
Going into the Next Level/ Returning to the Previous Level
To go into the next level of an item, select an item then press the "OK" key.
To return to the previous level of an item, press the "Return" key.
Exiting the Maintenance Mode Menu
To exit the maintenance mode menu, press the "Clear/Stop" or "Return" key until the
"Ready" display appears.
For clear SC 543 Enter the engine maintenance mode.
Press "O.K" in "Fuser SC Reset" with engine maintenance mode, and then turn the main power switch off and on.
Oct 08, 2013 | Ricoh Aficio SPC232SF All-In-One Laser...
Clear/stop 1, 0, 7 color start does not work for getting into service mode?
Menu Mode
Special Mode
Selecting an ItemTo select an item, press the "Up" or "Down" key.
Going into the Next Level/ Returning to the Previous LevelTo go into the next level of an item, select an item then press the "OK" key.
Exiting the Maintenance Mode MenuTo exit the maintenance mode menu, press the "Clear/Stop" or "Return" key until the
I have a Xerox Phaser 6110 laser printer. When I try to print, I get Transfer Belt Error. When I go into the Troubleshooting Guide, it states that I get an Internal System Error. I have already tried to...
The "Transfer Belt" error shows up after the printer has printed 60,000 pages. At which time the belt needs to be replaced.
You can try resetting the count, which may clear the message:
1. Enter Service Mode by pressing [MENU] [#] [1] [9] [3] [4]2.
If you do not see the Tech Mode menu press the menu button again. (You need to enter the key sequence quickly.)
3. Select Tech Menu
4. Select DataSetup
5. Arrow to Clear Counts and press Enter6. Enter Password 19347. Arrow to Transfer Belt and press Enter.
The display will show Clearing Counts and then return you to the Tech Menu. Press exit several times to exit the Tech Menu and then power cycle the printer.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Apr 27, 2011 | Office Equipment & Supplies
My Escape Radio, CD, and Aux input will not work. My temp gauge works, but all music controls do not, except for the load and eject buttons for the CD player. I replaced three fuses that according to my...
Which three fuse's did you replace ? You should check for B+ voltage on both side's of the fuse . Two little metal tabs on top of the fuse. Voltage on both , fuse is good .
Try radio self-diagnostic mode .
A fluctuating AC voltage audio signal is sent to the speakers directly from the audio unit to reproduce sound. The audio unit has a self-diagnostic mode that can be entered by pressing preset buttons 3 and 6 simultaneously.
Visual Inspection Chart Mechanical Electrical
  • Audio unit
  • Antenna or antenna cable
  • Speaker mounting/speaker cones
  • Radio ignition interference capacitor, radio frequency interference suppression bond, or radio receiver hood bonding strap
  • Smart junction box (SJB) fuse(s):
    • 7 (10A)
    • 12 (5A)
    • 16 (15A)
  • Battery junction box (BJB) fuse(s):
    • 7 (40A)
    • 15 (20A) (Hybrid)
    • 16 (25A)
    • 21 (40A)
    • 22 (40A) (Hybrid)
    • 23 (40A) (Hybrid)
  • Subwoofer amplifier
  • Circuitry
  • Audio unit
  1. If the concern is visually evident, GO to Symptom Chart .
  1. If the concern is not visually evident, proceed to the Speaker Walk-Around Test and the Audio Unit Self-Diagnostic Mode.
Speaker Walk-Around Test (Except Premium CD6)
NOTE: To enter the speaker walk-around test or audio unit self-diagnostic mode, the audio unit must be turned on and in the radio tuner mode (AM/FM).
  1. To enter the speaker walk-around test, simultaneously press the audio unit preset buttons 3 and 6.
  1. The speaker walk-around test stops at each speaker and applies sound to each speaker for about 1-2 seconds. Each speaker is tested and displayed on the audio unit in the following sequence: RF, LF, LR, RR and SUBWOOFER.
  1. To exit the speaker walk-around test, turn the ignition switch off, turn the audio unit off, or press preset button 1 for diagnostics (DIA).
Audio Unit Self-Diagnostic Mode (Except Premium CD6)
NOTE: To enter the speaker walk-around test or audio unit self-diagnostic mode, the audio unit must be turned on and in radio tuner mode (AM/FM).
  1. To enter the following tests, press the desired preset button while in the speaker walk-around test or while in the audio unit self-diagnostic mode.
  1. To exit the audio unit self-diagnostic mode, turn the ignition switch or the audio unit off.
  1. If the concern remains and the fault is not detected, GO to Symptom Chart to continue diagnostics.
  1. The self-diagnostic mode has 6 manual tests available:
    • Preset button 1 = ENTER DIAGNOSTICS. This test enters diagnostics from the speaker walk-around test. Metrics are available with SEL and ON buttons indicating time played in AM/FM, media, number of buttons pressed, etc.
    • Preset button 2 = EEPROM BLOCK STATUS. This test shows the validity of memory to calibrate the clock, and seek sensitivity.
    • Preset button 3 = EXIT DIAGNOSTICS.
    • Preset button 4 = Software configuration level. This test queries each radio system controller for its software configuration level.
    • Preset button 5 = DISPLAY TEST. This test lights all the display segments for five seconds and then turns all segments off.
    • Preset button 6 = RAM CONTENTS READOUT. To enter these tests, press preset button 1 while in the speaker walk-around test, then the desired preset button.
  1. To exit the self-diagnostic mode, turn the audio unit or the ignition switch off.
Oct 06, 2017 | 2008 Ford Escape
LOOKING FOR PICTURE SETTING SAMSUNG MO.NO.LN-T5265F
This may help you...you can also get an owners manual free on line.
English - 23
Using Automatic Picture Settings
Your TV has Three automatic picture settings ("Dynamic", "Standard", "Movie") that are preset at the factory.
You can activate either Dynamic, Standard, Movie by making a selection from the menu.
1. Press the MENU button to display the menu.
Press the ENTER button, to select "Picture".
2. Press the ENTER button to select "Mode".
Press the ??² or ??¼ buttons to select the "Dynamic", "Standard", "Movie" picture
setting. Press the ENTER button.
?³ Choose Dynamic to increase the clarity and sharpness of the picture.
?³ Choose Standard for the standard factory settings.
?³ Choose Movie for a natural Image without picture enhancements.
3. Press the ??² or ??¼ buttons to select "Contrast", "Brightness", "Sharpness",
"Color", or "Tint(G/R)", then press the ENTER button.
4. Press the ??? or ??? buttons to decrease or increase the value of a particular item.
For example, if you select "Contrast", pressing the ??? button increases it.
Press the EXIT button to exit.
• When you make changes to Contrast, Brightness, Sharpness, Color, Tint(G/R)
the OSD will be adjusted accordingly.
• When in PC mode, Tint, Sharpness, and Color are not available.
Press the P.MODE button on the remote control repeatedly to select the desired
picture mode.
Picture Control
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 00
??¼More
TV Picture
Move Enter Return
Mode : Dynamic
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 0
??¼More
TV Picture
Dynamic
Standard
Movie
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 0
??¼More
TV Picture
50
??² Con trast ??¼
Move Adjust Return
English - 24
Adjusting the Color Tone
You can change the color of the entire screen according to your preference.
Press the ENTER button to select "Picture".
2. Press the ??² or ??¼ button to select "Color Tone", then press the ENT ER button.
3. Press the ??² or ??¼ button to select "Cool2", "Cool1", "Normal", "Warm1",
or "Warm2".
When the picture mode is set to Dynamic or Standard, Warm1 and Warm2
cannot be selected. Movie mode is only available.
Move Enter Return
??²More
Color Tone : Cool2 ???
Detailed settings ???
Size : 16 : 9 ???
Digital NR : Low ???
Active Color : On ???
DNle : On ???
Reset : OK ???
TV Picture
Move Enter Return
??²More
Color Tone : Cool2
Detailed settings
Size : 16 : 9
Digital NR : Low
Active Color : On
DNle : On
Reset : OK
TV Picture
Cool2
Cool1
Normal
Warm1
Warm2
Activating Backlight
You can adjust the screen brightness by adjusting the LCD backlight brightness. (0~10)
2. Press the ??² or ??¼ button to select "Backlight", then press the ENTER button.
3. Press the ??? or ??? button to decrease or increase the valueof the backlight
brightness.
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balcklight 1 0
??¼More
TV Picture
5
??² Balcklight
??¼
Move Adjust Return
Move Enter Return
??²More
Color Tone : Cool2
Detailed settings
Size : 16 : 9
Digital NR : Low
Active Color : On
DNle : Off
Reset : OK
TV Picture
OK
Cancel
Resetting the Picture Settings to the Factory Defaults
1. Press the ??² or ??¼ button to select "Reset", then press the ENTER button.
Press the ??² or ??¼ button to select "Cancel" or "OK" then press the ENTER button.
Each mode can be reset.
Feb 04, 2011 | Televison & Video
How do you reset image unit counter on Xerox Phaser 6110MFP
2. If you do not see the Tech Mode menu press the menu button again. (You need to enter the key sequence quickly.)
3. Select Tech Menu
4. Select DataSetup
7. Arrow to desired counter and press Enter.
Feb 01, 2011 | Office Equipment & Supplies
14 people viewed this question
jasbo
jasbo
