Question about Coleman Heating & Cooling
Water leaking on the inside - Coleman Heating & Cooling
    Genius:
  • Coleman Master
  • 1,363 Answers
Coil froze up or stopped up drain.
Posted on Aug 10, 2015
Fix leak inside Samsung refrigerator
water may not be leaking inside? What u may have is water condensation? this happens when u have a clogged or plugged evaporator drain plug line or bad seals on the door which allow air and moister to come in and CONDENSATE, THEREFORE WATER IN THE FRIDGE. U NEED TO CLEAN THE DRAIN LINE USE HOT WATER, AND A SOFT FLEX TUBING OF SOME TYPE
Feb 15, 2015 | Samsung Refrigerators
Is rumbling sound from leaking water heater dangerous?
Rumbling sound usually means sediment build-up inside tank.
Yeas a leaking water heater is dangerous because it can cause water damage.
Copy following link to determine source of leak.
http://waterheatertimer.org/Leaking-water-heater.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 28, 2012 | Water Heaters
Frigidaire refrigerator water filter area leaking
There has to be a loose or disconnected water line. Check the water dispenser inside the door and behind the door and then go from there.
Jul 23, 2012 | Frigidaire GS26HSZDW Side by Side...
Whirpool Gold refrigerator model GR2SHTXKQ01 (water leaks from dispenser. This model has freezer on top, dispenser is inside refrigerator.
Water valves leak like a leaking faucet sometimes. They just will not close all the way allowing water to bypass the valve and either drip at dispenser or drip and make a mess in freezer. Your model takes a=> 2219592 Water Valve - Dual Outlet
Change the dual water control valve and I believe this will solve this problem, Thanks Sea Breeze
Jul 11, 2012 | Whirlpool Refrigerators
Water leaking passenger side air conditioning
Water or coolant? inside the driver compartment or under the hood? if it is inside it sounds like a leaking heater core
Mar 07, 2011 | 2003 Chevrolet Tahoe
Turned off the hot water to fix a leaking tap. now the tap has no hot or cold water and the hot water tank valve is leaking?
It sounds like two problems.
Problem 1) Clog inside faucet or clog inside pipes at faucet
Remove supply tubes leading to faucet and see if problem is inside pipes or inside faucet.
My bet is clog inside faucet.
If you have galvanized pipe that meets copper pipe, this can be trouble spot.
Article on clogged water pipes at Inspectapedia:
http://www.inspectapedia.com/water/Water_Pipe_Clog_Repair_Guide.htm
Article on clogged pipes:
http://www.waterheaterrescue.com/pages/WHRpages/English/Troubleshooting/Tanklets/backflushing.html
Problem 2) Water heater leak ... you say tank valve is leaking? Is that cold-water shut-off valve? Or tank drain valve? Or TP valve?
If cold water shut-off is leaking, then replace shut off.
If tank drain valve is leaking, then check if plastic valve is cracked. If drain valve is cracked, then replace with a brass valve from Home Depot. If plastic valve breaks off, then use hammer and screwdriver to gently chip out the broken plastic valve. New valve threads need teflon tape to seal pipe. If valve is just dripping, then put garden-hose cap over end of valve and screw down tight.
If TP valve is leaking, then replace with same temperature and pressure rating.
New TP valve threads need teflon tape to seal pipe.
Problem 3) If pressure is low all over house:
Buy pressure gauge at hardware store that screws onto hose connection.
Test pressure on outdoor spigot.
Open faucet and check if pressure drops. This says if problem is inside pipes that enter house.
Test pressure on water heater drain valve.
This says if pressure problem is before -or- after water heater.
If problem is before the water heater, then shut-off valve located on cold water line is suspect.
If problem is after water heater, it could be in hot water outflow pipe on top of water heater, or a nearby elbow.
Remove hot water line leading from water heater and check pressure. This says if problem is where hot water leaves tank.
Read articles above about clogs inside water lines.
Nov 16, 2010 | Rheem Water Heater Pressure Relief Valve
Water was leaking inside on passengers side, now
HVAC drain tube was blocked and condensation could not drain to the outside of the vehicle
as a result the water pooled inside the HVAC case leaking on the inside and killing your blower motor and probably blower motor resistor
clear the drain, replace the blower and resistor and you'll be back in business
Jun 08, 2010 | 2001 Oldsmobile Aurora
Icetube leaking water inside freezer and outside back of freezer
Your refrigerator needs a new water valve and possibly some new water tubing. You can find the correct part by going to sears.com and entering the refrigerator's model number in the parts search field. When you have the valve, shut off the water to the refrigerator. If you're not sure how to do that, just shut off water to the entire house. Be sure to run the kitchen sink after you shut the water off to relieve any presure and double check that the water is completely shut off.
Be sure to unplug the refrigerator before you start this project...water and electricity aren't friends! Using a 1/4" nut driver or socket, remove the cardboard or metal cover off the back of the refrigerator. Follow the water line to the water valve, unscrew the nut going to the valve, and remove the water line. There are 2 screws holding the water valve to the refrigerator cabinet; remove the screws and gently pull the valve out. Unplug the electrical connectors and remove the water lines. Take the new valve, connect the water lines and electrical plugs, screw the valve back into place, attach the water line and turn the water back to to test for leaks.
Since the valve has been leaking inside your freezer it would be a great idea to clean out your freezer and let the water tube and lines thaw. Find a place for your frozen food, unplug the unit and let it sit overnight with the doors open. Don't forget to remove the ice bin, as these make quite the mess when the ice melts. Once it's thawed, plug it back in, make sure the water is on and not leaking and enjoy!
Jun 03, 2009 | Kenmore 57029 Side by Side Refrigerator
Air Conditioner 3 in 1 danby SPAC12030 leaking water on the floor. No water in right side compartiment also no water in the back reservoir. Water leak from right side of the machine. From the right side...
I had that problem last year. When I took it apart I found that the drainage hoses that lead to the reservoirs were plugged with dust build up. I clean out the hoses as well as the rest of the insides. I have since placed the entire unit inside a shallow (under bed) style rubermaid tote and have not had any more water leaking. Hope that helps you.
Aug 04, 2008 | Danby Heating & Cooling
Heating & Cooling Logo
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
