Question about Brinks 1-1/2 In. Brass Combination Resettable Padlock
WHY IS MY LOCK IS LOCKED OPEN, LIKE IT WANTS ME TO RESET IT. CAN'T GET IT TO CLOSE
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 24 Answers
You just have to unlock again
Posted on Sep 23, 2016
I do have a volvo S70 yeat 98. The trunk dont close it seems to got locked up; i tryed to fix it anf the only lock I found its for the seats. Csn sny onr hrlp me how to fix it mysrlf?
This is a diagram of the lock assembly in the trunk lid. The highlighted area shows the lock in the open position. If you look at your lock assembly and it doesn't look like this, it may be in the locked position causing the trunk to not close. use the trunk key and turn the lock cylinder. You may have to use a screwdriver to gently pull on the lock hasp while using the key to unlock. If the hasp is in the locked position, it should open and allow the trunk to close properly
May 27, 2016 | Volvo Cars & Trucks
I locked the door latch maualy at the door of 2000 ford explorer how do release it
Look into the lock opening on the door frame for a part you can reach with a flat-blade screwdriver.
These can normally be opened if prying on the lock mechanism.
If you want to risk another door, watch the mechanism move when locking it manually.
You should then be able to reset both.
Mar 14, 2015 | 2000 Ford Explorer
The safe i have is locked with the door open. How do i reset the safe to close the door.
Remove the batteries end leave it for 10mins or so..then replace batteries and set a new combination on the lock.
Feb 24, 2015 | Sentry FIRE-SAFE Combination Safe DS3431,...
Self cleaning lock is in lock position and oven door is open.
Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
Also check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Apr 16, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
SMALL LOCK APPEARS IN CONTROL BOX AND WONT ALOW
That lock icon indicates a locked door, and if you can open your door with it locked, your door lock will need to be reset. Your instruction manual should have your reset procedure listed in back. But if your door IS locked, you will need to manually drain out the water before it will open.
Mar 18, 2010 | Samsung WF328AA Front Load Washer
The door is open, but the latch is in a locked position.
it sounds like the child lock as been turned on,check the handle part to see if it as a **** in it were you can turn it with a screwdriver just turn this upwards or sidewards to see if the door will lock or open ?.rgrds,paul
Jul 07, 2009 | Washing Machines
Frozn on lock
1. Try to press the Reset button at the bottom of the mp3, it's on the back side. If that doesn't do it, then try step 2.
2. Let the battery drain out, eventually the mp3 will close automatically, then simply recharge and open.
Sep 02, 2008 | Samsung YP-K3 MP3 Player
I WHANT TO RESET MY MASTER LOCK , WHAT STEPS I HAVE TO FOLLOW?
Instructions:
Opening the key storage
compartment door
1. Open shutter door to reveal the dials
and the release button
2. Rotate dials to the current combination
(if the lock is new, the combination is set
at the factory to 0-0-0-0)
3. Press down on the release button
to open the door
4. Pull the door fully open
5. Add or remove keys
6. Close compartment door
7. Scramble the combination dials to lock
the door and conceal your combination (A)
8. Close the shutter door (B)
To set a new combination:
The initial combination is set at the
factory to 0-0-0-0
1. Open the compartment door
(see instructions above)
2. Push the reset lever left and down.
The lever remains in this position
3. Rotate dials to your desired combination
4. Push the reset lever, up and right, back
to the original position
5. Close the key storage compartment door
6. Scramble the combination dials to lock
7. Close the shutter door (B)
To hang shackle model
2. Push the shackle release lever to the left
to open shackle
3. Pull the shackle up and out of the lock
4. Place shackle around door knob or other object
5. Close shackle to lock
6. Close the compartment door
Reminder:
(A) The release button will open the lock
until you scramble the dials
(B) Keep the shutter door closed to increase
weather resistance and to conceal the
dials from view
Mar 05, 2008 | Master Lock 5400d: Portable Select Access...
Brinks 1-1/2 In. Brass Combination Resettable Padlock Logo
723 people viewed this question
Top Brinks Locks & Locksmithing Experts
john h
andrewcahoon
Are you a Brinks Lock and Locksmithing Expert? Answer questions, earn points and help others
