Question about Exercise & Fitness
What is the advantage of aluminum to the enviroment
What are the advantages of using aluminum oven cookwares?
The major advantages of using Aluminium oven cookwares are mentioned below:
a. Lightly weighted
b. Larger sized legs.
c. Safe dishwasher.
d. Delicious food.
e. Great versatility, etc.
You can visit this link, to get best deals on these aluminum cookwares of best brand.
Jul 03, 2017 | Kitchen Ranges
2006 Volvo Penta stern drive, are they bad news and were all of them made of composite?
all driver whether outboard or stern drive are make of an aluminum composite material. it would be more advantageous to state your problem to get an answer rather than to make a blanket complaint about the manufacture of the equipment
They will all rot or corrode if left in salt water and not maintained correctly
Dec 17, 2016 | Volvo Cars & Trucks
My dad has chosen aluminum fabrication for his new company. Is it really good to go for an aluminum fabrication?
My answer is a Yes. Because I have had an aluminum fabrication done from Bayview metals at Ontario. I have done it long back and I never needed any maintenance work till now. It has a great advantage of no corrosion. So your dad is right. Let him go for it.
Jan 26, 2014 | 1993 Ford Mustang Scott Rod Fabrication...
Which one is best between UPVC and Aluminium Doors & Windows?
I will prefer UPVC windows and doors because it is much advantageous than aluminum. Some points are given below-
Maintenance
Aluminum windows and doors need painting over long periods of usage whether UPVC windows and doors requires no painting; only routine cleaning.
Durability under Extreme Weather
Aluminum windows and aluminium doors can start fading after sustained exposure to sun. Start looking ugly. But, UPVC windows and doors have UV resistant blend; do not fade under sustained exposure to sun.
Aesthetics
Aluminum windows and aluminium doors can look cold and out of proportion whether UPVC windows and doors have elegant looks; enhances both; the exteriors and interiors of the building.
For detailed information visit: http://www.fenesta.com/aluminium-windows-doors.aspx
Dec 05, 2013 | Scotch 600 Film Tape,upvc,clear,3/4 In. X...
What problems or benefits will I get with an aluminium boat hull
Aluminum boats are easier to maintain, will last longer than fiberglass, and are easier to repair. You can also bump into things without causing damage like you would to a fiberglass hull.
The only real advantages to fiberglass are that it looks better due to the gelcoat finish, providing that it is maintained, they also feel more solid in the water due to the extra weight, and they tend to ride better and are quieter than an aluminum hull.
One other consideration is whether you will operate it in fresh water or salt water. Salt water can lead to corrosion problems on an aluminum hull if you leave it in the water. Fiberglass doesn't have that problem, but you can have a problem with blistering if you leave a fiberglass boat in the water for long periods, especially if you don't use a bottom coat of some sort.
If you do opt for an aluminum boat in salt water, just make sure that you spray it down with fresh water and wipe it down with a soft towel whenever you take it out of the water. This is actually a good practice for any boat, aluminum or fiberglass.
Mar 28, 2013 | Boating
What are the advantages of aircraft grade arrows?
Aircraft grade arrows are made of aluminum and are lighter as well as cheaper than other arrow therefore they are much faster and accurate.
Aug 26, 2012 | Betsey Johnson Archery
Switch cover feels warm -2 pass&seymour dimmers in 4" box is this o.k.
Dimmers are naturally warm.
They are meant to radiate the heat to avoid burning out.
IF the dimmer is HOT, then that is a signals trouble, and dimmer is overloaded or has gone bad. Check Load capacity rating of dimmer, and/or replace HOT dimmer.
Load is the total wattage of lights being controlled.
Ordinary dimmer from box store usually has load rating of 600 watts.
Other residential dimmers are rated up to 1800 watts, which is max for residential dimmers.
1800 Watt dimmers have special aluminum cover that looks like a heat sink, because it is a heat sink. Aluminum dissipates heat faster than other metals, so dimmers usually have special aluminum cover or they can have aluminum fins that stick out on the sides so heat radiates.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on circuit or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 17, 2011 | Pass & Seymour #T600LAV 600W Almond SP...
I ned at instruction book for electrolux enviro multi steamer
You didn't specify which model you had, but I assume it's the newer Eureka Enviro Steamer Model 313A.
Here's a link to the owners manual for your Steamer. If you have an older Enviro steamer, please feel free to reply using the comment field below. Also, if you found this solution helpful, please be sure to leave feedback for me. Leaving feedback is greatly appreciated by the FixYa community, and ensures that repair experts continue to leave great FREE advice, as opposed to just answering the premium, or paid questions.
Hope this helped you, thanks again.
Eureka by Electrolux Enviro Steamer Owners Manual for 313A
Jan 07, 2011 | Vacuums
Exercise & Fitness Logo
69 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
