Question about E-Machines (308714) Motherboard
G620 boot problem
Hi
My eMachines g620 fails to boot almost every time I turn the power on. It hangs before loading windows Vista, just a black screen hangs... It probably doesn't load up the boot files, 'cause hitting F5 or F8 on boot-up won't do anything. With patience and occasionally several hours of time, I manage to get it powered on by turning the laptop on and off. If I try to restart Windows, it powers off and it all starts again. I've replaced the battery, no use. Though, there's something fishy 'cause if I try to power the device on without power supply cord, the power led only flashes once and laptop turns off... With cord, I'm yet able to unplug it immediately after power-on. Every time I press the power on, the system wakes and I'm able to enter BIOS and the fans are on. After exitting BIOS the system powers off, no reboot. If I manage to get the system started, everything works perfectly. Because of this annoying problem I have to keep my laptop on 24/7, but sometimes I really should reboot at least for updates... Is the cause in Vista, mobo, hard drive or what?? I really appreciate your help!!
  • simo_h_sorsa Jun 23, 2009
    I was suspectin' the hard drive also, but how it could cause an improper restart? Is it possible to re-write the boot sector/boot files?
    And about that RAM matter... Why is the system working properly after succesful boot? This is a boot-up issue only..!
  • Vivek Chalotra
    Vivek Chalotra May 11, 2010
    This is simply a problem of Hard disk. Try replacing it. You can reload vista before replacing it.
    President:
  • 392 Answers
After ur long question the problem is the faulty RAM ... ur RAM is causing all this remove and replace your RAM . ur problem will get solved..
Posted on Jun 23, 2009
  • M.Jeevan Chaitanya
    M.Jeevan Chaitanya Jun 23, 2009
    yes of course it may be a hard disk problem too... yes you can rewrite the boot files...
    or repair them using
    fixmbr command and other commands from the fdisk utility.
How do i boot into safe mode?
To boot into safe mode press F8 continually on and off from before the windows logo!
Oct 04, 2014 | E-Machines eMachines Desktop PC
Restore laptop
If your PC has a recovery partition:
Turn it off.
Before Windows logo appears (after it turns on) keeps pressing F8.
Then you should see Do a system restore?
Keep pressing F8. Then follow what your computer will give you.
If you have a DVD/CD drive and a recovery (reinstall too) disk:
Insert it in.
Turn off your PC.
Turn it on again.
Then keep pressing F12 or F8 (any works).
After that you should see a boot-menu.
Select the option which says to boot from the CD/DVD drive.
Then follow the instructions.
Jan 24, 2013 | eMachines Acer G620 G720 Lcd Cable Gle...
Can't install windows
If there is a boot menu you may have to load the CD drive from there and the restore disk will load. Check the boot screen when the PC is first turned on and look for restore option and which key to press. It is usually F10 or F11. If all else fails press F8 on start before the first boot screen vanishes and select the prompt option. then load the CD from there after you ID the drive letter.
Sep 16, 2012 | E-Machines eMachines Desktop PC
PC HANGS ON BOOT
Try running the Check Disk Utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
Feb 18, 2012 | Computers & Internet
Missing reboot mgr forAcer eMachines 350-2074 Atom N450 1.66GHz/1GB/160GB/bgn/NIC/WC/3C/10.1" LCD/XPH/Black (EM3502074) Netbook
Actually Its a Operating system problem. What you need is to boot from a Windows Vista or Windows 7 disk.
1. Boot up using windows 7 disk and you will be getting windows is loading files roadfox_60.jpg
2. Select the keyboard layout
3. Keep on hitting next until you will be getting this screen. Choose Startup Repair. Then keep on hitting next until the computer prompts you to restart. If all things fails repeat steps 1 to 3 choose System restore this time.
4. Choose Recommended Restore point keep on hitting next Until you will be getting this window below
5. When you Click on finish it will revert the settings back to the time that you selected
Thanks for choosing Fixya
Jul 20, 2011 | Acer eMachines 350-2074 Netbook
Compaq Presario c500 - Not booting into Windows Vista Desktop
Try to repair the windows,
use the windows installer and select the repair option to recover the previous windows that was running normally.
Sep 21, 2009 | HP Compaq Presario C500t Notebook
G620 boot problem
When you power up press F8 key then ente rin enable vga mdoe.
Then go to contro lpanel and then open dispaly property then change screen resolution to 1024*768 then apply and ok.
Then restart it.
Jun 23, 2009 | Computers & Internet
Problem with booting my A205-S4577 with the powercord on
Have you tried a new power AC/DC convertor ? make sure you have the correct spec...see manual for power adaptor needed. Cost less if you can get a loan of one. other than this i would be looking into checking the power jack. hope this helps
Feb 15, 2009 | Toshiba Satellite A205-S4617 Notebook
E-Machines (308714) Motherboard Logo
535 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
