Question about Car Audio & Video
Clarion problems I have a clarion xc1410 amplifier. When I connected everything it turns on, and sound comes through, but when I turn the volume up slightly, the dash speakers start cutting off and on. There are four 6 1/2 polk audios in the doors, and two 2.5 inch stock speakers in the dash.
KaeZoo
  • 156 Answers
SOURCE: i dont get any sound
Many vehicles have factory amplifiers that must be activated or bypassed when installing a replacement head unit. If the factory amplifier isn't integrated or bypassed, you won't hear sound from the factory speaker locations. Another possibility is that you have a shorted or pinched speaker wire or terminal. A short at any speaker will shut down the head unit's internal amp, killing the sound to all the speakers. The RCA outputs wouldn't be affected, so the subwoofer keeps playing.
Posted on Mar 07, 2007
Open SKy
  • 618 Answers
SOURCE: Polk Audio Speakers
hi Hubbell2008
And Happy Holidays
well, as you can see depending on your audio card, and output power, and sound settings on control panel, if is all up, or down.
you can try that first. But if not work is and Audio Card, type of power output, ....in that case you can change your audio card, if an onboard audio, place a PCI and will be ok, Creative labs models makes diff.
Posted on Dec 04, 2007
  • 24 Answers
SOURCE: speaker problems
i would make sure that your speakers are wired in the correct phase.. positive and negative are correct.. if they are out of phase they will cancel each other out giving you no bass
Posted on Feb 22, 2008
marsrover
  • 682 Answers
SOURCE: sound cuts when volume is turned up
check that power amplifier rating(how many watt)must be more than total speaker rating by 20% at least..
exampel:if speakers watts are 100 watt-amplifier watt must be 120 watt.
Posted on Mar 15, 2008
SOURCE: Kenwood DNX7100 no sound when vehicle is started
'06 and up dodge rams have a CANBUS system, you have to buy an $80 adapter for it to function correctly. Just google "CANBUS adapter".
Posted on Apr 15, 2008
Less than a year my church purchased wireless microphones suddenly not working there is no sound coming out of microphones. HELP!!
What does the receiver go into ?
a pre amp mixer ?
What are the volume levels set at on the mixer for the receiver input ?
Also check if the pre amp goes into another amplifier that the volume setting on the final amplifier device if used have not been turned down.
Bet someone has fiddled with these settings of volumes !
Aug 23, 2015 | Pyle Pro PDWM5000 4 Mic VHF Wireless...
Subwoofer repair
Check your connections. Make sure everything is plugged in properly. If it is still making a sound, even a whisper, then the amp is probably fine. Do you have other speakers connected to the amp? If so, they should be sounding too. If not, then it's definitely an amp problem. Ebay sells tons of .... well, everything, so you should check that out...
Mar 05, 2014 | Jmlab Audio Players & Recorders
I have two ten inch subwoofers hook to my clarion cz200 they work with the tuner but not when listing to aux or usb how do i fix it
Sounds like you have the amplifier for the subwoofer only coming on with the radio. On the back of the Clarion radio, you should have another blue wire, but with a white stripe. This is the correct wire to use for turning on the amplifier. Connect this to the "remote" or "turn on" connector of the amp.
Feb 28, 2011 | Clarion CZ200 Car CD USB MP3 Player
Kenwood Receiver VR 806 turning off
Sounds like the music amplifier is different to the tuner audio amp. The music amplifier is now looking at an unbalanced impedance which is less than it should be. Therefore the output chip of the music amp has more current through it than it wants so it gets hot and shuts down.Put a four ohm wirewound resistor ( from Radio Shack ) in series with each surround speaker to reduce the current flow through the amplifier output.
Apr 09, 2010 | Kenwood VR-806 Receiver
Clarion DRB2475 mutes when I turn up the volume
Sound like one of your car speakers is faulty, try using the fader and see if it still happens when all sound is to the front or rear and try left and right.
Nov 16, 2009 | Clarion DRB2475
The volume cuts out completely.
you probably have a lose connection. check all connections at both ends of the wires. if that dosen't solve the problem there is something wrong with the amp
Dec 03, 2008 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Amplifier installation
Since there's been no response in over a month, I guess I'll assume the problem was fixed!
Feb 19, 2008 | Kenwood KAC-X520 Car Audio Amplifier
400 watt amplifier not working
Disconnect all the speaker wires from the amplifier that runs the 6-speaker system. Switch off the amplifier or disconnect the remote turn-on wire, then re-connect it. Does the power light still flash with no speakers connected? If so, your amplifier is probably damaged. If not, then connect one speaker and see if it plays. If it doesn't, disconnect the first speaker and connect a different one. If the first speaker plays, continue connecting the rest of the speakers until you find the one that's causing the problem.
Mar 05, 2007 | Clarion APX401.2 Car Audio Amplifier
Car Audio & Video Logo
52 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
