Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
How to change drive gear on Craftsman 41A4315-7D
Craftsman yt3000 model no. 917.288517 changed v-belt drive when put in gear to go forward it go's backwards put in reverse it go's forward ?
You've obviously performed the v belt replacement bass-ackwards. Recheck the belt routing scheme in your manual.
Jul 16, 2017 | Craftsman Garden
Hammer drill wont drive
It sounds like the gear inside sheared the teeth. You can check with Craftsman to see if you can get a replacement gear.
Apr 07, 2014 | Craftsman Professional 1/2 in. 8.0 amp...
No drive gears
ok ther is clutch Disc and it,s worn out need to replace it or the drive gear is worn look for broken rubber ring
Feb 03, 2014 | Craftsman Snow Blower / Snowblower Bottom...
My interrupter cup keeps flying off on my craftsman garage door opner model 139.53648srt1
This sometimes happens after changing a drive gear. If this is the case follow the instructions below.
You probably did not have the motor shaft pushed all the way back when you tightened the coupler after replacing the worm gear. Loosen that coupler up and from the front of the motor (opposite end in which the coupler is on) push the shaft back as far as it will go. Hold it there while you tighten the coupler back up and then try it.
If you didn't just change the drive gear you will find the motor shaft is moving towards the rear and knocking the interrupter cup off. Replacing the drive gear with the new coupler and washers will cure this problem.
Jun 04, 2011 | Sears Craftsman LiftMaster Chamberlain...
My Craftsman LT 2000 will not go into gear when I let the clutch out. Everything feels normal but when I let the clutch out, tractor is not in gear. Tried both forwardand reverse. I can change the gear...
First check to see if the drive belt is on the front and back pulley. Next check to see if the rod in back is in the correct position for use verse free wheeling. www.nnyparts.com
May 27, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
The gears are very hard to shift
you need to put dope in trans and check gear shifter to see if it is loode if not check your drive belt
Apr 23, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Need to change plastic 3" diameter gear that is driven by the worm drive gear
The part number for the gear kit is 41A2817. It comes with instructions and is available at any good door opener service company.
Dec 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
The nylon drive gear on Craftsman Garage Door keep stripping
The most common reason for this is a door that is too heavy. Release the door from the opener and lift it by hand. If it is heavy to you it is heavy for the opener. Be sure after replacing the gear to lubricate it heavily with the lubricant supplied with the gear. You can't apply too much.
Jul 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 19hp won't move when in gear
There is a square key about 2 " long that fits in the slot on the axle and wheel and locks them together.. You probably didn't see it when putting tire back on and knocked it out. If you go back where you removed tire, you'll find it laying on the ground.
May 27, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
61 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
