Question about Dometic Portable Ice Maker HZB-15S
DO YOU HAVE A LEVEL LEG OR FOOT FOR THIS ICE MAKER
THIS ICE MAKER HAS 4 RUBBER FEET TO LEVEL IT WHER CAN I BUY ONE
I want to no what causes swollen feet
poor blood circulation, weight problem,
talk with your doctor as there can be other more serious concerns involved and fixya site is not a medical site
Apr 22, 2017 | Televison & Video
Feet for Acuvibe 5004 foot massager
Take one of the rubber feet to the hardware store and see if they can sell you replacements.
Oct 10, 2016 | Sewing Machines
I need the non-slip rubber feet for the tgt bk58t
take a sample along to a rubber retailer as they have a selection of rubbers that may do the job
Oct 04, 2016 | Targus Tgt Bk58t 58 3 Way Panhead Bubble...
What are the effective shin splints stretches?
Here are some of the effective shin splints stretches:
1) In a kneeling position, point your toes out behind and gently sit back on your heels pressing the tops of the feet towards the ground.
2) Standing arm length from a wall, put your hands on the wall while keeping your feet and knees straight, then lean forward as far as possible.
3) Standing with your feet flat, bend your knees forward as far as possible keeping your heels on the floor.
4) Put feet flat on the ground and have a partner hold them down. Partner applies resistance to your toes and you lift them up against the pressure.
5) Sitting with your left ankle on right knee, apply pressure to inside of your foot (near big toe) with hand, then and turn your foot up and in, using the leg muscles.
6) In the same position as above, put pressure to the outside of the foot (near little toe) with your hand, and turn foot down and out using the leg muscles.
7) In the same position as above, put pressure to the top of foot (near toes) with your hand, and lift the foot using leg muscles. Repeat these with the right ankle on the left knee.
8) Sit on a table or chair attach a weight (a bucket filled with stones or sand works well) around the foot. Without bending your knee move your foot up and down from the ankle - Start light and work up.
9) Attach one end of a stretching exercise elastic band to the leg of a table or sofa and loop it around the end of the foot. Move your foot up and down and side to side against the bands resistance. Try to draw the letters of the alphabet in the air with your big toe.
10) Stand erect and raise up and down onto your toes several times. You can make it harder by doing it while standing on a step and allowing your calves to stretch over the edge of the step.
11) While sitting lower and raise your feet with the heels on the ground as high and quickly as possible for 60 seconds. This is a great one to do during work days while sitting at your desk.
Sep 15, 2015 | The Health & Beauty
Have a tube w/rubber end hanging down in ice maker. Also a molded styrofoam w/ plastic loose in ice bin on model#253.70313211 French door bottom freezer. Wher does this belong and how do I fix it.
It fell of the bottom of your ice maker put your model number into repairclinic.com and you can find a pic or video that shows you how to put it back together
Mar 02, 2014 | Kenmore Bottom Freezer French Door...
How to level the refrigerator
do you mean your refridgerator is wobbling on a level floor? of so the feet are usually adjustable. Each foot/leg can be adjusted to different heights to level it out. they usually are just simple bolt and nut arrangements hope that helped
Oct 02, 2012 | Refrigerators
Need rubber foot for frigidaire professional series gas stove iron grill. My stove has three grills, each grill having 4 rubber (rivit-looking) feet. Apparently the missing foot, as small as it is,...
I just had my stove serviced today. You can purchase a foot kit for $30. The part # is 5304475129. http://www.mdappliance.com/ELX-5304475129.html. I could not find a place that only sold the rubber feet. Clean any debris from the hole that the rubber feet goes into. Add a small amount of the high temperature adhesive in the hole. Insert the rubber feet back in. The rubber feet has a pin point hole in the middle. Insert a paperclip in the hole and stretch out the sides of the rubber feet, so the sides stick to the adhesive. Place the grates back onto the stove and let it sit for 2 hours. Good luck.
Feb 06, 2010 | Kitchen Ranges
The ice does not drop out when holding a glass under the pour spout. Ice maker is fine
Sounds like the F.F. is not leveled correctly. If it's making ice but not dropping it and you are certain the mechanism is working, then it may be leaning back too much.Try winding the front feet to reset the level.( A friend had a similar problem when the back foot sunk into flooring)
Jun 26, 2009 | LG Side by Side Refrigerator w/ LCD TV and...
Microsoft 4000 Ergonomic keyboard - broken foot
they don't really make replacement parts for these, its not profitable just a small piece of plastic, you would have to create your own from metal or similiar, or use the keyboard without the feet, or replace the whole keyboard.
Jun 05, 2009 | Microsoft Natural Ergonomic 4000
Dometic Portable Ice Maker HZB-15S Logo
18 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
