Washing Machines Logo
A
Anonymous Posted on May 11, 2014
Elite model number 79640512900
Washer will not power up have to unplug and plug back in to power up
5 Related Answers
Anonymous
  • Posted on Oct 17, 2008
SOURCE: Kenmore Elite Front Loader HE 4t washer
I am getting an f 02 error
Anonymous
  • 163 Answers
  • Posted on Jan 04, 2009
SOURCE: no power to washer
Hi!!! say check your lid switch make sure its good..
Anonymous
  • Posted on Nov 27, 2009
SOURCE: Kenmore elite washer control lock on and can't use washer
There is a manual release. You can either take off the kick plate and reach up from the bottom, or take off the top and reach down. It's a teardrop shaped plastic tab coming out the bottom of the lock mechanism, and you just pull it down.
Anonymous
  • 7 Answers
  • Posted on Dec 06, 2009
SOURCE: my kenmore elite oasis washer will not turn on. I
its the power button its a common prob use a soldering iron and switch it with the load sinal button this happpens as the washer alallows moisture to get on the board as its not protected it will save u a ton of money and anyone can do it
jimorris77
  • 411 Answers
  • Posted on Dec 24, 2009
SOURCE: I have a Kenmore Elite, Model: 22992. Switch
It's quite likely you have a bad lid switch.
I am not a repair professional. I am a 78 year old man who has been making his own repairs for about 50 years. So the machine ID doesn't mean much to me. I came to fixya looking for a schematic for an really old AM/FM radio and just happened to see that more than 4,700 people were asking for help with a washer repair. I recently had a washer repair of my own and at that time I found an excellent video on youtube which showed me how to take my machine apart. This video (direct drive washer repair) made it possible for me to do my own repair. You probably don't have any idea of the wonderful help you can get from youtube videos. Your first stop should be at youtube. Just search for the help you need. You could search for "clothes dryer repair" or "clothes washer repair" or "dishwasher repair". If you are not able to view and/or download the videos, or after you've seen all you want to see, I suggest you go directly to www.applianceaid.com where they have very good step by step trouble shooting and repair information on washers, dryers. and dishwashers as well as other appliances. Another excellent site is www.acmehowto.com If you have a direct drive top load washer and need help taking it apart these youtube videos are wonderful help. I was so impressed with them that when I saw all these people needing help, I wanted to tell them about the videos. If you look at the back of your top load washer and the panel is solid (no small inspection plate to remove, which would indicate you have a v-belt drive) chances are you have a direct drive and this video (direct drive washer repair) is just what you need. After you've seen all the appropiate videos, or if you have a belt drive washer, you will probably still need help in determining what the trouble is and how to fix it. I suggest you go to www.applianceaid.com where they have very good trouble shooting and repair nformation on most washers and dryers, dishwashers and many other household appliances. I think you'll find what you need there. Another excellent site for DIY help is www.acmehowto.com Don't worry about the timer on a washer, they hardly ever go bad. I realize I haven't solved your problem for you, but I hope I have sent you where you can get help to solve the problem. Good luck with it.
How to Reset a Kenmore Elite HE3 Washer?
Unplug it for 1 hour and plug back in. Hope it works.
My delay start says 8888 and it wont delete no other lights come on, i unplugged and plugged back in and its still there
Sears has online expert service. Go to the link below and they might be able to answer. You'll need your model number which you can get off of plates mounted in various locations on washer.
Repair Maintenance Questions Answers
I have a Kenmore Elite Oasis top load washer and keep having the UL code pop up. I have leveled and re-leveled the machine with no avail. I have also ensured that my level is still in working order. If...
You can try to clear the Error Codes;
  • Unplug the washer for 1 to 2 minutes.
  • Disconnect the U.I. (touch pad).
  • Plug the washer back in for 1 to 2 minutes.
  • Unplug the washer.
  • Plug the U.I. back in and then plug the washer back in. Codes should then be cleared
  • if that doesn't work that indicates a problem with the software in the machines control board replace board with this part number 26-110-8564393R and this should resolve the problem part cost about 114.16 if you like go sears parts direct .com or call parts directly at 800-573-6456
I am getting an F2 error constantly on every wash. Any ideas what this F2 code means or how I can fix it. Thanks
1 check the drain hose to make sure its not kinked.
2 unplug the machine
3 check the electrical plug at the pump and make sure that the pump runs
4 check the drain pump filter for foreign objects
5 plug washer back in
6 if the above does not fix the problem go to #7
7 unplug machine
8 Replace the pump
Part #8181684 http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-elite-Parts/Washer-Parts/Model-11042922200/0583/0153200/P0309046/00006?blt=06&prst=&shdMod=
Washer not working
Hi, your control circuits are locked. you will need to replace the microcomputer in this unit. it is malfunctioning.
3helpful
My kenmore elite oasis washer will not turn on. I
1helpful
Kenmore elite washer won't start
Dear Customer
Please perform the following
unplug the washer for 5 minutes and then plug it back in,This can resets the system
Please rate this,Thank u
Alexander
vince
