Question about Epson Perfection V370 Flatbed Scanner - B11B207221
V370 flashing orange light - Epson Perfection V370 Flatbed Scanner - B11B207221
Colour and black ink cartridge flashing orange
They call that flash codes or error codes. please count
count how many times the lights flash, here is what they mean
Alarm / Power light flashes orange 7 times consecutively (ink cartridge installed incorrectly)
Alarm / Power light flashes orange 5 times consecutively (Print Head Error)
Alarm / Power light flashes orange 4 times consecutively (Out of Ink Error)
Alarm / Power light flashes orange 3 times consecutively (Paper Jam Error / Cover Error)
Alarm / Power light flashes orange 2 times consecutively (Load Paper / Paper Feed Error)
Alarm / Power light flashes orange 16 times consecutively (This FINE Cartridge has previously been used)
Alarm / Power light flashes orange 15 times consecutively (FINE cartridge not recognized)
Oct 05, 2014 | Canon PIXMA MP495 InkJet Printer
Orange ink light keeps flashing
HP Desk Jet 940c orange light flashing
Oct 01, 2014 | HP DeskJet 940c InkJet Printer
Alternate green and orange lights flashing, tried to remove battery pack and left off for half hour, still problem, if i hold green button down orange light blinks 15 times which i saw in the manual to...
Hi I have a ip100 portable printer and both green and orange lights flash. Green flashes twice and the orange light flash at what seems to be a random disorder.
May 17, 2011 | Canon iP100 Portable Printer
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    Both lights are blinking and will not print
    they call that flash codes or error codes. please count
    Sep 20, 2009 | Canon Pixma iP2600 Photo InkJet Printer
    Flashing Orange Light
    the flashing orange light is an indicator to tell you that your wireless adapter is working and has a connection to your router, if you are not wireless, press the button that is flashing and it will dissable your wireless connection,to turn back on press it again.
    Aug 04, 2007 | Acer Aspire 3003LCi Notebook
    Epson Perfection V370 Flatbed Scanner - B11B207221 Logo
    144 people viewed this question
    Top Epson Office Equipment & Supplies Experts
    Alun Cox
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
