Question about Kenmore 24032\24036 Top Load Washer
My front load kenmore washer does not start/fill out of water. The ligths next to the start bottom ligths are blinking. This washer is 2 years old. please help me. Thanks Ray
  • 15,935 Answers
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question*&^$%^
Posted on Oct 01, 2010
We have a 2-year old GE washer WBVH5200J3WW brought from HomeDepot. It leaks water from the bottom. Any suggestions are appreciated.
Just started having the same issue (ours will be 2 yrs old next month) we are thinking its the rubber seal tube around the front that is worn out....
Jan 16, 2011 | General Electric WBVH5200J Front Load...
Washer fills with water after the cycle is over
check the pressure senser ,if this ok check the pcb assy
Jun 20, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Washer will not start/continue with cycle
check if the water pump is not blocked in any way preventing the water from emptying properly as the machine wont continue until the water sensor tell the machine that its ready for the next cycle the pump may not be doing its job preventing the next cycle to take place eric
Jan 15, 2018 | Kenmore 24872 Top Load Washer
Kenmore top load washer approx. 10 years old
f7686aa.jpgPump is leaking around the drive shaft.
To get to the pump CLICK HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 28, 2008 | Kenmore 24032\24036 Top Load Washer
10 year old model kenmore top load washing maching won't fill.
That means that eithere the membrane water lever switch is faulty (most common) or that the drain pump solenoid is stuck on open.
Dec 21, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 Series - water wont fill to full load
remove edge decore trims from left and right side front of control panel8b608f8.jpg
remove phillips screws from bottom corners of contol panel
remove knob from water level selector
raise control panel ~1 inch then flip over backwords on pivots
depress lock tab on right/underside of water level control body where it touches metal mount plate
rotate water level control body 45deg anti clockwise
pull body off
top side of body next to knob shaft is 1/8 hex head bolt
turn clockwise to rais water level
anticlockwise to lower water level
machine can be operated with this part not fitted so can check level. fill, adjust screw, fill will start again, adjust screw, until water level is correct
reinstall in reverse order
Incidentally, the cause is a VERY small wire spring inside the control body that is not really up to the task, and stretches over years.
Its a common occurrence, and I make this repair, on callouts, no parts required, couple times a month you may have to flip the switch to reset to get the water to restart filling
Oct 25, 2008 | Kenmore 24032\24036 Top Load Washer
Water doesn't stop filling tub in washer, water overflows everywhere. washer doesn't wash on super/large loads and doesn't spin on any loads. washer is only 2 years old
water not stopping filling is the pressure switch its a long thin tube that goes from the bottom of drum to the front top about the thickness of a pencil this needs taking off clearing through and checking for pin holes then refitting this should solve water problem
Jun 19, 2008 | Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
