Question about Raymarine St40 Wind Rotavector E22047
How can one test a ST40 wind instrument ?
No speed or direction indicated
  • Raymarine Master
  • 696 Answers
According to the Raymarine forum, aside from making sure that the spade lug connections are good and clean, there isn't a field test for the ST40. The recommended remedy is for you to send the complete unit to Raymarine for evaluation. Here's the link to that forum.
Sorry I couldn't be the bearer of better news.
-Steve
http://raymarine.ning.com/forum/topics/st-40-wind-troubleshooting
Posted on Jan 15, 2015
Is there such a thing as a reset for the Autohelm WIND ST 50? I purchased a boat with one that showed proper wind angle but not speed. I removed the sender, greased both the wind vane and cuos. now
I assume you have an ST-50 or ST60 windvane setup. These are the calibration instructions from the unit manual for the ST-50. They are the same for the ST-60 and ST-60+ units.
Hope it helps you.
Initial Calibration Windvane Alignment
Before the unit is used for navigational purposes the masthead transducer must be accurately aligned to the vessel. Before this procedure is carried out the windvane should be linearised as follows.
1 . Powerup lhe ST50 Plus Wind instrument.
2. Tum the vessel through two complete circles, making sure that the windvane remains in line with the wind -the instrument will automatically linearise the windvane.
Alignment
1. Press and hold CAL for 2 seconds until CO is displayed by the LCD.
2. Press < > to move the pointer to the correct wind angle.- WIND
- Press < > once to move the pointer by 1 degree.
- Press < > for 1 second to move the pointer by 10 degrees/second.
The LCD will now display the applied correction.
3. Press and hold CAL for 2 seconds to exit and store windvane alignment.
Windspeed Unit Selection
1 . Press and hold CAL until Ul (Knots) or U2 (Meters/second is displayed.
2. Press CALwithin 8 seconds to change the windspeed units selection.
3. After 8 seconds the wind instrument returns to normal operation.
Nov 22, 2014 | Boating
Why does my st40 bidata read a maximum 1.3 knots in any conditions. I have checked the paddle wheel, it is running free and all 4 paddles are in place?
Even the smallest amount of friction can keep the paddle wheel from turning properly. See if it will turn if you blow on it. If not, there might be something impeeding it from turning easily.
Apr 29, 2014 | Raymarine St40 Bidata System Depth/Speed...
Wind sensor doesn't work
Test all wires for continuity. 90.8 % of problems are caused by faulty wiring.
Aug 13, 2017 | dr. Tech WA-1080PC-T Solar Wireless Home...
Manual
Go to the Raymarine.com website, they have manuals for their products even ones that have been discontinued.
May 10, 2013 | Raymarine ST40 Wind System Rotavecta...
Should I buy a Davis Black Max Wind Direction Indicator straight from the manufacturers' website or is it worth looking elsewhere?
They sell them online for $39.99 on their website; however I suggest searching other avenues as I have found other sites that sell the same product for less. Here is one example that sells it for $26.99.
http://www.intensitysails.com/dablmaxwiin.html
And a second option for $31.50
http://www.sailrite.com/Davis-Black-Max-Wind-Direction-Indicator
Jul 17, 2012 | Davis Instruments Davis Black Max Wind...
Raymarine ST40 Bidata Manual
Hi
I realize this question has gone unanswered for quite awhile, but here is the link to ST40 owners manuals.
-Steve
https://flir.app.box.com/s/w7dp1h5hwi1f3fmda4x1/1/402191597
Jun 18, 2012 | Raymarine St40 Bidata System Depth/Speed...
ST40 Depth and Knot meter
I traced the line from the mast and it was good so finally ordered a new instrument head "$150", It works now, the head was 2 years old {the length of the warranty} not a very long lasting instrument, hope I get more time out of the new one.
Aug 08, 2008 | Raymarine St40 Depth Display E22038
St60 wind instrument
You might want to double check that all of the spade connectors that are used to plug the wind transducer into the ST60 wind display are firmly plugged onto the display's terminals.
Because of the blind connection, sometimes the terminal ends up lodged between the red insulator and the spade, rather than within the spade connector itself. This results in intermittent or missing readings from one part of the sensor or more.
Also make sure the display is in Master mode. You will need to get into its setup mode to confirm this. The other possible mode is repeater, which would be used if this were a secondary readout.
Dec 13, 2007 | Raymarine ST60 A22012-P GPS Receiver
Raymarine St40 Wind Rotavector E22047 Logo
144 people viewed this question
Top Raymarine Boating Experts
Steve
Steve
David Burbee
David Burbee
Are you a Raymarine Boating Expert? Answer questions, earn points and help others
