Question about Royal Sovereign ARP-1000EX Portable Air Conditioner
Fam motor ls-53d2 - Royal Sovereign ARP-1000EX Portable Air Conditioner
Engine cooling fans not coming on
could be fuse/relay/temprature sensor/wireing or fam motor
Aug 02, 2011 | Chevrolet Malibu Cars & Trucks
No power to fan moter but moter runs fine
Heater fan moter or Radiator fam motor?
Dec 06, 2010 | 1996 Oldsmobile Eighty Eight
Why does the fan seize up from time to time and I have to manually rotate the exhaust fam to try to get it started? Is the motor bad?
mcdevito75 Yes the fan motor is going bad, the bearing inside is sealed unit. have your local a/c repair shop look at it, they come to the house.
Jun 21, 2010 | Whirlpool ACQ108XL Air Conditioner
Evap is froze up is there a defrost cycle trueGDM -33
Probably the evaporator fan has stopped working. If there is no airflow evap will freeze. Chrck operation of fam motor.
Apr 18, 2010 | True GDM-33-SSL-54 Refrigerator
Heater fan short.....Fan quits working. Relay or something loose?
check the heater motor hot lead as well as the ground wire on the heater motor they have common ground fault issues that result in bad / weak connections also check the fam motor speed control resistor located under the hood in the AC/heater box
Jan 24, 2010 | 1997 Buick Riviera
When the temperature control on my refrigerator is set to medium or higher the indicator starts flashing and the fridge stops working. What could be the problem?
the temp controller ie either out of range or the fam motor is arching out when you switch to a higher mode that causes the fan motor to run longer too!! check the fan motor or change it that should fix your probelm
Jan 15, 2010 | Refrigerators
Items in heater that are binding
Remove fam motor & have a look for them?
Jan 14, 2009 | 1994 Chevrolet C1500
Fan motor ???
ef452b7.jpg I will send another figure then instructions
Nov 19, 2008 | Whirlpool Refrigerators
Have had 2 9600xt's that had the fan motor start squealing
Try cleaning the fan with a can of compressed air ,make sure there are no wires close to your cooling fan blades. If this doesnt resolve the problem replace the fan .
Nov 24, 2007 | ASUS RADEON 9600XT, (128 MB) AGP Graphic...
Royal Sovereign ARP-1000EX Portable Air Conditioner Logo
20 people viewed this question
Top Royal Sovereign Heating & Cooling Experts
jdthefixer
Bill Long
Are you a Royal Sovereign Heating and Cooling Expert? Answer questions, earn points and help others
