Question about Tools & Hardware - Others
Where is the low pressure port on 2009 acadia slt
5 Suggested Answers
abauto
  • 353 Answers
SOURCE: How do I replace the low beam headlight bulb on a
cd2aa88.jpgb5b9eca.jpg...
Posted on Oct 04, 2009
sisadsl
  • 1508 Answers
SOURCE: I have no low beams on my 2009 Acadia. Fuses are
could be two blown bulbs or the control switch
Posted on Apr 17, 2010
  • 12650 Answers
SOURCE: 2009 gmc acadia replace rear brakes
this is on a bigger truck but its the same procedure for changing your brakes if you dont have a piston tool you can use a c-clamp with an old pad to depress piston (s)back or most auto stores will let you borrow tools
Yahoo Web Search
Posted on Aug 07, 2015
emissionwiz
  • 76848 Answers
SOURCE: 2009 GMC Acadia SLT 3.6 need intake manifold torque specs and sequence
OK now that you have your engine right does this look right. The numbers are small but they are there. please rate my help.
Posted on Dec 23, 2016
Where is fuel pump relay on 2009 gmc acadia
Your vehicle has no fuel pump relay . Has a fuel pump flow control module .
Fuel Pump Flow Control Module (FPCM)
The fuel pump flow control module (FPCM) is a serviceable GMLAN module. The FPCM receives the desired fuel pressure message from the engine control module (ECM) and controls the fuel pump located within the fuel tank to achieve the desired fuel pressure. The FPCM sends a PWM signal to the fuel pump, and pump speed is changed by varying the duty cycle of this signal.
Plus it has two fuel pumps !
The high pressure fuel pump (9) is a mechanical one cylinder design driven by an eccentric on the exhaust camshaft (1) of bank 2. High pressure fuel is regulated by the fuel rail pressure (FRP) regulator, which is a part of the high pressure fuel pump. The FRP regulator is a magnetic actuator which controls the inlet valve of the high pressure pump. The ECM provides battery voltage on the actuator high circuit and ground on the actuator low reference circuit. Both circuits are controlled by the ECM. When the ECM deactivates the FRP regulator, both circuits are disabled and the inlet valve is held open with spring pressure. When the ECM activates the FRP regulator, the low circuit driver connects the low reference circuit to ground and the high circuit driver pulse-width modulates (PWM) the high circuit. The ECM uses the camshaft and crankshaft position sensor inputs to synchronize the FRP regulator with the position of the eccentric on the camshaft. The ECM regulates fuel pressure by adjusting the portion of each pump stroke that provides fuel to the rail. The high pressure fuel pump also contains an integrated pressure relief valve.
Your best bet is have it towed to the dealer , you don't want to mess with the high pressure pump .
Pluse
Feb 27, 2016 | 2009 GMC Acadia SLT-2
Yahoo Web Search
Aug 07, 2015 | 2009 GMC Acadia SLT-1
Is the mirror housing motor and seat heater on drivers side of 2009 Acadia SLT hooked to same fuse???
Try to go to a near by autoparts store and have them test your fuses, it's free. They can also do a lot more. Good luck
Jul 02, 2015 | 2009 GMC Acadia SLT-2
Where is the low pressure ac port
Not positive for this model, but usually passenger side, near the firewall, inline and perpendicular to a silver tube about the size of an average man's pinky finger, with a plastic cap that is either black or blue and has a large "L" molded into the top. Likely half-hidden behind hoses, tubes, wires, etc. Alternative location is near the radiator, same side.
Jul 20, 2014 | 2009 GMC Acadia
My 12 volt outlets in gmc acadia not working..where is the fuse for this?
The Fuse block is on the Passenger side right below the glovebox. Look directly below it there is a panel that pulls down.
Jul 17, 2014 | 2009 GMC Acadia SLT-1
Mirror control pushed out of the door
need to pull off the door panel and repair, usually a clip holds it into the door panel
Aug 21, 2013 | 2009 GMC Acadia SLT-1
Apr 17, 2010 | 2007 GMC Acadia SLE
Tools & Hardware - Others Logo
77 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
