Question about Kodak ESP 2150SE Wireless Office All-in-One Printer
Kodak 2150 printer error 3528
Printer instructions-clear all paper-Cycle power off for 30 seconds. Power on- I have done that, still get error code 3528..What to do next??
SOURCE: Kodak easy share printer dock series 3 faults
got same error, took the clear cover off the paper cartridge and kinda' force fed the paper thru. To my surprise...it worked.
Posted on Jul 06, 2009
SOURCE: error code 3528 keeps coming up,telling me to
I have this printed and if you read (carefully) through the manual it tells you it doesn't like single sheets of paper. If ever my paper feeder tray runs below say 3 sheets then this error will crop up so keep it topped up with paper. The same goes for photo paper too.
Posted on Jan 18, 2011
HansPP
  • 2510 Answers
Check the complete paper path very carefully, it only takes a small fragment of paper stuck somewhere to signal a paper jam. Also check that the paper sensors have returned to their normal positions. See that the printer has not picked up a second sheet of paper and this is somewhere in the path.
Posted on Jan 28, 2011
sharonbur480
SOURCE: On my Kodak 5200 printer,
the paper jams wen its going through all the time ive taken it out and tried again but, still does it .
Posted on Mar 06, 2011
willinois
  • 77 Answers
SOURCE: I've just bought a new kodak printer ESP3250 last
Sounds like there is a sheet of paper jammed in it. Try taking off the roller access panel in the back (not the access panel by the cartridges). Make sure to only use clean sheets with proper humidity level to avoid jams. Also fan the sheets before feeding to disperse any static.
Posted on Mar 28, 2011
How do I clear kodak esp 2170 error 3528
To resolve the error:
  1. Press the On/Off button on the printer control panel to turn off your printer.
  2. Wait 30 seconds.
  3. Press the On/Off button to turn on your printer.
Jul 28, 2014 | Kodak ESP 2170 All-In-One InkJet Printer
How do i remove paper jam
I can't guarantee that this will work, but when I had my Kodak printer, I uninstalled it and then reinstalled it and it came right. I'd tried everything else I could think of before I did that. I got all the welcome to Kodak messages etc. etc. again after I'd done that!!
May 30, 2014 | Kodak ESP Office 2150 All-in-one Printer
HOW DO I FIX THE ACCESS DOOR ERROR CODE 3501?
The Kodak support site says:
To resolve this error, close the printer access door. The printer will not operate while the door/cover is open.
If the error continues even after you close the printer access door, power cycle the printer:
  1. Turn off the power (press the On/Off button on the printer).
  2. Unplug the printer power cord from the back of the printer.
  3. Wait approximately 30 seconds.
  4. Plug the printer power cord into the back of the printer.
  5. Turn on the power to the printer.
If the error continues, contact Kodak at:
http://www.kodak.com/go/contact
May 18, 2014 | Kodak Office Hero 6.1
Code3825
Error: Printer Error (3825) Published 04/17/2012 04:30 PM ' Updated 05/30/2012 11:48 AM ' Answer ID 46577
How do I resolve the error message "Printer Error" (code 3825) on my all-in-one printer? To resolve the error:
  1. Remove all paper from the paper tray(s).
  2. Disconnect the power cord from the printer.
  3. Wait 5 seconds, then reconnect the power cord.
  4. Reload paper in the paper tray(s).
  5. Try printing again.
Mar 12, 2014 | Office Equipment & Supplies
Kodak 3.2 ESP has an error clear all paper code 3528 but there is nothing there
Turn off the printer and unplug it. Open the top access panel. Inside on the left you will see three round, white gears. Rotate the gear closest to the front back and forth with your finger. If any scraps of paper appear near the rollers, remove them. Close the top access panel. Plug in and start the printer. This worked for a Kodak ESP 3.2.
Feb 04, 2013 | Kodak ESP 3 Multifunction Printer/ Copier/...
Esp 5250 error code 3528
Hello Shaheen,
Try this:
  2. Wait 30 seconds.
If the error continues, double-check that all paper and foreign objects are removed from inside your printer.
NOTE: Even if you do not physically see a paper jam, you will need to follow the paper jam link to solve the error.
Paper Jam Error
Oct 19, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Printer keeps displaying error 3528 there is no paper in it and has never been any please help
Hello, Welcome to FixYa!
Error 3528 in Kodak Printer is mostly because of paper jam. their may be small bit paper jam in side. There are some "micro-sensors" that detect a paper jam. To solve it
Try taking off the roller access panel in the back and make sure that the printer has not picked up a sheet of paper somewhere in the path.Also make sure that sure that really there is no piece of paper paper, dust or foreign objects.If you have seen and you are sure that there is no any paper or foreign object then Turn the printer off, and disconnect the AC power-cable. Open the printer cover & now give the printer a "blow-job" by compressed air. Turn the printer On and check. If you still face this error then try a trick may be it can resolve the issue.
Press the On,Off button on the printer and turn off your printer. Now wait for 30 seconds.Press On button to turn your printer On and try printing.
If still there is an error then then probably your Kodak ESP 3 Multifunction Printer/ Copier/ Scanner is in need of servicing by a service professional.
I hope this solution helps you.
Thank you for using FixYa!
Sep 13, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Paper jams
Paper jams - Kodak Printers
Feb 19, 2011 | Kodak Office Equipment & Supplies
My p0rinter is not printing with good color quality. Blue doesn't pick up. I ran the troubleshooting and the error code 3502,3501,,3830, comes up. How may I fix this? I have new cartridges. thank you....
This is from the Kodak website.
How do I resolve the error message "Printer Access Door Open" (error code 3501 or 3609)? Published 08/25/2010 11:38 AM ' Updated 01/07/2011 08:40 AM ' Answer ID 1467 How do I resolve the error message "Printer Access Door Open" (error code 3501 or 3609)? To resolve this error, close the printer access door. The printer will not operate while the door/cover is open.
Feb 07, 2011 | Kodak ESP 5 Printer
Paper jamed in ESP7 AIO printer
Clear the paper jam.
1. If paper is in the paper tray, remove it.
2. Turn off your printer.
3. Wait 30 seconds, then remove the AC power cord from the back of your printer.
4. Wait 30 seconds, then plug the AC power cord into your printer.
5. Wait 30 seconds, then turn on your printer.
6. Fan the paper to keep the sheets from sticking together.
IMPORTANT:
1. Do not overload the paper tray. Load a maximum of 100 sheets of plain paper, or 30 sheets of photo paper, into the paper tray.
2. Do not load more than one type of paper into the paper tray.
7. Load paper into the paper tray.
8. Align the paper with the dotted lines on the paper tray, then adjust the paper width guide until it lightly touches the paper.
This should fix the issue, if you need further help , visit the below web site to take help from Kodak support team.
http://www.kodak.com/eknec/PageQuerier.j...
All the Best.
Dec 13, 2010 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak ESP 2150SE Wireless Office All-in-One Printer Logo
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
