Question about Pride Sundancer 3 Wheel Electric Scooter
How to remove rear seat ford f-150 -2013 - Pride Sundancer 3 Wheel Electric Scooter
How to remove bolt covers for front seats on 01 ford taurus
Identify and Remove bolt covers - Instructables
https://www.instructables.com/...remove...seats/.../Identify-and-... InstructablesNext slide both seat forward as far as they can go, and lean the back of the seat forward as well. Find the two bolt covers and remove them as well.
How To Remove Front & Rear Passenger Seats 2006-11 ...
? 15:30
www.youtube.com/watch?v=qCLx3Ak2BvY
Jul 31, 2013 - Uploaded by TheTongMan Here is a tutorial on how to remove the front passenger seat and the rear ... what pieces of equipment are you ...
Oct 21, 2015 | Ford Cars & Trucks
How do i remove rear seat in 1965 Ford thunderbird
On the one I had the bottom of the seat pushed in and their was hooks on both sides .You would push in and pull up on each side. if this was helpful please leave good feed back
Mar 03, 2015 | Ford Cars & Trucks
How to remove rear seat for a 2004 ford f150
push down on top of seat then pull out its on hooks that point down
Sep 21, 2012 | 2004 Ford F150
I need to replace a rear seat belt in a 1997 Ford Tarsus. Does any know the best way to access the assembly? In addition, are there any diagrams available that show the connection points?
please don't forget to rate, thx.
Retractor and Tongue—Sedan
SPECIAL SERVICE TOOL(S) REQUIRED Description Tool Number Safety Belt Bolt Bit T77L-2100A
NOTE: Safety Belt Bolt Bit T77L-2100-A should be used for safety belt removal and installation.
Removal
  1. Remove rear seat cushion. Refer to Section 01-10 .
Seat Cushion, Rear Sedan
Removal
  1. Apply knee pressure to lower front portion of the rear seat cushion. Push rearward to disengage rear seat cushion pad and frame (600A88) from rear seat cushion front retainers (63370).
  1. Remove rear seat cushion from vehicle.
  1. Remove rear seat back. Refer to Section 01-10 .
Seat Back, Rear 60/40 Split Bench—Sedan
Removal
  1. NOTE: Safety belt bolts do not secure seat back to vehicle.
    Remove rear seat cushion as described.
  1. Fold down back seat and remove two bolts in the center of each seat back striker plates.
  1. Remove two bolts from outboard rear seat back frame retaining brackets.
  1. Lift seat back up and pull forward to remove from vehicle.
  1. Remove panel (52018) and quarter trim panel (31012). Refer to Section 01-05 .
Trim Panel, Quarter—Sedan Removal
  1. Remove rear seat. Refer to Section 01-10 .
  1. Pull up on rear section of rear door scuff plate that overlaps lower quarter trim panel.
  1. Pull lower quarter trim panel away from body.
  1. Remove safety belt retaining bolt.
  1. Feed safety belt through lower quarter trim panel.
  1. Remove safety belt anchor plate-to-sill bolt from quarter panel.
  1. Remove retractor anchor nut and retractor from rear quarter panel.
  1. Remove upper seat belt anchor bolt and anchor from upper rear quarter panel.
  1. Slide anchor plate end of safety belt through the openings in the quarter trim panel.
  1. Remove outboard front safety belt retractor and tongue (611B08) from the vehicle.
    Item Part Number Description 1 386277-S190 Bolt (Part of 611B68) 2 31012 Upper Rear Quarter Trim Panel 3 611B60 Retractor and Tongue 4 N800937-S190 Nut 5 389370-S190 Bolt 6 — Rear Quarter Panel (Part of Body) 7 52018 Lower Rear Quarter Trim Panel 8 — Mounting Stud (Part of Body)
  1. Remove seat belt anchor bolt and retractor and tongue from rear deck panel.
Installation
  1. To install, reverse Removal procedure.
  1. Make sure the safety belt webbing is not twisted. If it is, remove the twist.
  1. Tighten retractor anchor bolt and safety belt anchor plate-to-sill bolt to 34-46 Nm (25-33 lb-ft).
  1. Check the restraint system for proper operation.
Jun 30, 2009 | 1997 Ford Taurus
I have lost the key which is the only one which opens the bonnet on my 52 ford mondeo
Take it to a lock smith and he can make a new key otherwise remove the back seat climb in and remove the c clip holding the lock on and remove the screw from the lock and pull out and take to the lock smith to get a new key made. To remove the rear seat pull the carpet away from the lower front of the carpet find two bolts one on each side and remove pull up on the seat and remove seat next find bolts to back of seat and remove lift up on the rear seat and pull out and away from the trunk then crawl inside to remove the lock,
Jun 18, 2009 | 2003 Ford Focus
Middel seatbelt will not loosen
I think you have to remove headrst bfore folding seat back down. You may have to unbolt seat from floor. 4 bolts.
Rear Seat Backrest —Split Bench Removal
NOTE: The 40% rear seat backrest must be removed before the 60% rear seat backrest.
  1. Remove the 40% rear seat backrest.
    1. Remove the nuts and bolts.
    1. Remove the backrest.
  1. Remove the 60% rear seat backrest.
    1. Remove the nut and bolt.
Installation
NOTE: The 60% rear seat backrest must be installed before the 40% rear seat backrest.
  1. NOTE: Do not tighten the nut and bolt at this time.
    Install the 60% rear seat backrest.
    1. Install the rear seat backrest.
    1. Install the nut and bolt.
  1. NOTE: Do not tighten the nuts and bolts at this time.
    Install the 40% rear seat backrest.
    1. Install the nuts and bolts.
60/40% rear seat backrest
  1. Tighten the 60/40% rear seat backrest nuts and bolts in the sequence shown.
40% Rear Seat Backrest
  1. Tighten the 40% rear seat backrest nuts and bolts in the sequence shown.
Jun 11, 2009 | 2005 Ford Escape
Mustang rear seat removal?
please rate highly if this is what you need
Section 01-10: Seats and Tracks 1994 Mustang. Workshop Manual
REMOVAL AND INSTALLATION Seat Cushion, Rear Removal and Installation
  1. Release pin from locks by pressing release button under rear seat cushion.
  1. Pull rear safety belt and buckle (60044) through openings in rear seat cushion pad and frame (600A88) and remove rear seat cushion pad and frame .
REMOVAL AND INSTALLATION Seat Back, Rear Sedan
Removal
  1. Remove rear seat cushion as outlined.
  1. Remove rear seat bolster. Refer to Section 01-05 .
  1. Remove rear seat bolster mounting bolts. Remove bolster assembly.
  2. Remove four seat back to package tray retaining bolts.
  1. Remove seat back.
May 04, 2009 | 2004 Ford Mustang
Fitting rear seat covers to AU Ford Falcon
To remove the rear seat off an au falcon get in the rear of the car facing the opposite way to which you drive facing the rear seat. you need to slide your hands along down where the seat belt conectors are pulling it up abit. than you need to use quite a bit off force pulling it towards your self.
May 04, 2008 | Baby Gear
Pride Sundancer 3 Wheel Electric Scooter Logo
22 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
