Samsung PN51D8000 3D Plasma TV Logo
Alexandre Vieira Santos Posted on May 12, 2014
Clicks, does not get on - Samsung PN51D8000 3D Plasma TV
Arcadian Duran
Level 1:
New Friend:
  • Contributor 10 Answers
  • Posted on May 12, 2014
Arcadian Duran
Contributor
Level 1:
New Friend:
Answers
10
Questions
0
Helped
2572
Points
14
Most Likely a power supply problem, You going to have to open it up or take it to a TV repair place, most clicking is cause by power not being enough to go thru the board If you do open it up, check for bulging Capacitors and bugling caps must be replaced, check google for how to replace the caps properly because you can get shocked if you do not discharge the caps properly.
Power up fails, flashing red LED.
CLICK HERE WATCH LIVE=>> http://hdtvlivenow101.tumblr.com/
How do I get rid of a flashing message "Display Mode out of range"
Here is an article from Microsoft on this problem. Good Luck !
20x20_grey_minus.pngCause This behavior can occur if the signal from the video adapter exceeds the scan range of the new monitor. The video adapter setting for updating the screen (the refresh rate) is incompatible with the monitor. uparrow.gifBack to the top ' Give Feedback 20x20_grey_minus.pngResolution To resolve this behavior, either change the refresh rate, or change the video adapter settings.
To change the refresh rate:
  1. Restart the computer, and while it is restarting, press F8 until the Startup menu appears. Press 3, and then press ENTER to start the computer in Safe mode.
  2. Right-click the desktop, click Properties, and then click Settings.
  3. Click Advanced, click Adapter, and then click Adapter Default from the Refresh Rate list.
  4. Click OK, click OK again, and then click Yes to restart the computer in Normal mode.
You can set the colors and screen area to your preferences under Display Properties.
To change the video adapter settings:
  3. Click Advanced, click Adapter, and then click Change.
  4. Click Next, and then click Display a list of all the drivers in a specific location, so you can select the driver you want.
  5. Click Next, click Show all hardware, and then click Standard display types under Manufacturers.
  6. Click Standard Display Adapter (VGA), and then click Next.
  7. Click Yes, click Next, click Finish, and then click Yes to restart the computer.
  8. After the computer starts, right-click the desktop, click Properties, and then click Settings.
  9. Click 256 colors, click Apply, and then restart the computer.
  10. After the computer starts, click Start, point to Settings, click Control Panel, and then double-click System.
  11. Click Device Manager, click View devices by type, and then click Display adapters.
  12. Click Standard Display Adapter (VGA), click Remove, and then click OK.
  13. Install all updated monitor drivers.
Rainbow Six Vegas cheat codes
Various Cheats
While playing, input the following keys to activate the code/effect (editors' note - none of them are useful). All codes are input during gameplay, while the game is paused (START) and while the LEFT BUMPER is being held.
  • Big Heads - RED, BLUE, GREEN, YELLOW, LEFT CLICK, YELLOW, GREEN, BLUE, RED, RIGHT CLICK
  • Colorful Bullets - LEFT CLICK, LEFT CLICK, GREEN, RIGHT CLICK, RIGHT CLICK, RED, LEFT CLICK, LEFT CLICK, BLUE, RIGHT CLICK, RIGHT CLICK, YELLOW
  • One Shot Kills - LEFT CLICK, RIGHT CLICK, LEFT CLICK, RIGHT CLICK, GREEN, RED, LEFT CLICK, RIGHT CLICK, LEFT CLICK, RIGHT CLICK, BLUE, YELLOW
Hello.i just bought an LG L1742S-SF monitor and when i connected to the unit it shown the next warning:out of range and a certain frecvency.Can you tell me what would be the problem?Thank you
I have a emachine e627 i got it in Dec of 2009 and a blue screen flashes up that says driver_trol_not_less_or_equal_ than windows try to restart again..
1. Click Start, right-click My Computer, and then click Properties.
2. Click the Advanced tab.
3. Under Performance, click Settings.
4. Click the Advanced tab.
5. Under Virtual Memory, click Change.
6. Click No paging file. Click OK, click OK, and then click OK.
7. Restart your computer.
8. Click Start, right-click My Computer, and then click Properties.
9. Click the Advanced tab.
10. Under Performance, click Settings.
11. Click the Advanced tab.
12. Under Virtual Memory, click Change.
13. Click System managed sized. Click OK, click OK, and then click OK.
14. Restart your computer.
Hope this works!
1helpful
Attention out of range is displayed on ibm 2 74 monitor
2answers
Out of Range message displays when PC boots
The settings that you have for you tower needs to be changed if you have a old monitor connect that to the tower then right click on your screen go to settings and set it real low once this is done connect the new monitor up and set where you would like it,
The out of range is just letting you know that the settings thats set the monitor can see
I changed Desktop resolution setting to higher, Monitor went black with "Out of Range" message
please try this:
hope it helps!
3answers
Firefox Clear Cache
What version of Firefox are you using?
Firefox 1.5 - Windows
  1. Click on Tools | Options.
  2. Click on the Privacy icon.
  3. View the "Cache" tab and click on Clear Cache Now.
Firefox 2.x - Windows
  3. Click on Clear Now under the Private Data section.
  4. Ensure that Cache is checked, then click Clear Private Data Now
  5. Click on the OK button to return to browsing.
Firefox 3.x - Windows
Firefox 1.5 - Mac
  1. Click on Firefox | Preferences.
Firefox 2.x - Mac
  4. Click on the red close window button to return to browsing.
Firefox 3.x - Mac
  5. Click on the red close window button to return to browsing
1helpful
3answers
Hp deskjet D4160
unplug the usb cable.......open printers and faxes........delete the printer icon........click on file........click on server properties.....click on drivers tab........click on Hp Deskjet D4100 series....click on remove........close all the windows........click on run........type regedit........click on the plus sign on hkey local machine.......click on system.......click on control set 001........click on enum.......click on usb.......right click on vid 0f04.......click on permissions.......click on full control allow.......click on ok.......right click on vid 0f04.........click on delete.......click on the minus sign of control set001.......click on the plus sign on hkey local machine.......click on system.......click on control set 002........click on enum.......click on usb.......right click on vid 0f04.......click on permissions.......click on full control allow.......click on ok.......right click on vid 0f04.........click on delete...close the window.
Insert the cd which came with the printer
click on Add a Device.....connect the printer when the installation window says to do so...printer will be installed and ready to use.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
