Question about Kenmore Dryers
Kenmore 80 Series gas dryer starts with heat but very short time
Kenmore Heavy Duty 80 Series gas dryer will start up and heat, but does not keep heat on very long. Will just run and run with no heat.
  • 97 Answers
Hello Friend, Your problem is very simple to fix. You're dryer needs a gas valve coil kit. To replace coils just remove front of dryer body and look below drum you will see the gas valve. The valve coils are located on top of valve (two little round black cylinders). It's simple, just remove the two screws from the little metal bracket that holds them down, unplug the wires from them and just lift them straight up off of the valve. Take notice that one has 3 wires and one has 2 wires. Just replace with new coils and plug wires back in and re-fasten metal bracket. Your dryer will run like new. Happy to help, Tim.
Posted on Jun 24, 2009
  • richardegagn Oct 09, 2010
    I have a different model and was having an issue like this when I read this I ordered the coils fromhttp://www.deydistributing.com/ and replaced them and no issue no more. Just wanted to thank you for the help
    Problem Solver:
  • 18 Answers
If gas is available after burner ignition for 3 - 10 seconds but then cuts out, this is an indication of a (1) lint clogged exhaust line,or (2) a fan suction bypass leak, both of which are resulting in insuffucient burner cone air/gas flow. Insufficient burner air flow results in actuating the high temperature limit thermostat or thermoswitch (usually a L220-40F thermostat) mounted on the topside of the cone. With inadequate cone air flow, burner flames are directed upward toward the thermostat instead of being pulled into the cone and then into the hot air supply for the dryer drum.
For (1), clear the exhaust line from the lint filter to the discharge louvers on the exterior of your home. Access to the backside of the dryer is necessary.
For (2), check the lint filter to fan suction connection for any possible leak paths. Access to the front interior of the dryer is necessary.
For a DG512, the front assembly that houses the lint filter and abuts the front end of the drum has a short duct that fits into the suction side of the casing for the squirrel-cage fan. This duct has a tendency to separate from the fan casing (its a slip fit) resulting in bypass leakage. If suction bypass leakage is occuring, this is air that is not being pulled through the drum, and hence, is not being pulled through the burner cone. As indicated above, a low cone air flow results in actuating the high limit thermostat, which then deenergizes the gas coils cutting of gas to the burner.
Note: These symptoms are NOT indicative of failed gas coils, since gas is being supplied initially to the burner for a period of 3 - 10 seconds. If the coil(s) have failed, the burner could not operate for any duration.
Posted on Oct 04, 2009
2 Suggested Answers
  • 382 Answers
SOURCE: 80 Series Gas Dryer - No Heat. All other parts
check outside drye vent where it goes through the wall they clog up with lint sometimes and force the escaping warm air to back up which causes sensor to give wrong reading if this is clogged just clear it till you feel the air coming through also check vent at bottom of dryer disconnect flex pipe and check for clogs there as well ..and always clear lint trap after every load
Posted on Dec 22, 2009
Dryer is a Kenmore Heavy Duty 80 series electric. Runs fine but very little , and often, no heat. Is the element gone?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 20, 2010 | Dryers
Dryer runs fine but heating unit will not ignite
heatman101
Jul 11, 2010 | Kenmore 77632 Gas Dryer
Dec 13, 2009 | Kenmore Dryers
Heavy duty super capacity plus Kenmore 80 series Electric drier the timer is running, but when I push the start button - nothing
the drum belt may be broken. you will have to check this, it goes around the drum and the pulley on the motor. you could also have a bad motor.
Oct 16, 2009 | Kenmore 73952 Gas Dryer
Kenmoore 80 series heavy duty (gas dyer) no heat.
If you still need help please post your model number. Gas/Electric?
Eric
May 25, 2009 | Kenmore 63942 Dryer
Dryer timer is not working and won't heat but runs fine
check the ignitor. That's a very common cause for no heat in a gas dryer. other possibilities are the coils, or it could be that you have a bad fuse in the dryer.
Dec 26, 2008 | Kenmore 73952 Gas Dryer
Kenmore 80 series runs but dont blow hot air
Where is the location of the heating element for a Kenmore 80 series dryer heavy duty model # 77834795
Dec 09, 2008 | Kenmore 63942 Dryer
Kenmore Heavy Duty 80 Series Gas Dryer won't cycle/won't heat.
if you ran this unit awhile without timer advancing,,now you blew the thermal fuse,,,re place thermal fuse and timer..
Nov 27, 2008 | Kenmore 73952 Gas Dryer
Dryers Logo
927 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
