Question about RC New 3 Ch Co-Comanche RAH-66 Helicopter
What does it mean when the indicator light on my charger for my 3.5 channel AeroQuest RC Helicopter is flashing green
It is a 3.5 channel gold helicopter with gyroscope and it is brand new from home depot
2 Suggested Answers
Don3542
SOURCE: My helicopter won't take off,
This issue is the "Drive Gear Unit" It is the small gear just above the motors which is attached to the very large gear. You will have seen several posts indicating that sometimes this gear shifts and does not engage the larger gear. In my case I looked and say that it was indeed trying to engage the larger gear, however the gear is stripped (the teeth are nearly gone). The sound that you are hearing is the sound of the gear slipping against the Bigger gear. I have a UJ365 which is a newer model. To my disappointment I cannot find a "Drive Gear Unit" anywhere on line. The copter will not function without it. This issue is that it takes the lift of both rotors to lift the copter into the air. There are two motors (one for each rotor) and each motor has one of these drive gear units. Each of these attach to the larger gears which turn the rotors. The rotors each turn in the opposite direction. This is what keeps the copter from continually turning in one direction. When one of the "main Gear Units" becomes damaged it seems to have three noticeable effects. (1) There is a noise that is the gear grinding against the bigger gear. (2) Because many of the teeth are stripped the drive gear engages the bigger bear only some of the time, this causes the rotor to turn slower and in-turn causes there not to be enough lift from the rotors to lift the copter. And finally (3), someone noted that copter wants to spin in one direction. Understanding the above, you can now understand that if one of the rotors is not reaching its full potential to turn, it is also not reaching its full potential to counter act the other fully functioning rotor. Thus the fully functioning rotor is forcing the copter to spin in its direction and the malfunctioning rotor is not spinning fast enough to stop the spin.
So this is the answer to your questions, hopefully on the older models there will be parts available for you to replace it. The copter cannot work until the part is replaced.
Posted on Jul 11, 2011
There aren't green light in charger
Search Results
    How To Fix Your RC Helicopter - YouTube
    ? 4:22
    https://www.youtube.com/watch?v=R65JJYwSH50
    Jun 28, 2010 - Uploaded by R/C 101
    Does your RC helicopter spin out of control in the air or ... thing that the video says but there nothing wrong about it the remote is fine but the propeller .... i have a brookstone RC stunt copter that i have not used in a few months. i .... however when I come to fly it, it makes a sound but the wings aren't working.
    All comments on How To Fix Your RC Helicopter - YouTube
    https://www.youtube.com/all_comments?v=R65JJYwSH50
    where can I buy new gears and pinions for my mini rc helicopter?. Read more Show.... The two pins on the charger port aren't working they won't charge ..... The charging light is off meaning the battery is charged. Any ideas? ..... So, the motor spins the correct way but there is no gear to transfer the power to the rotors 'A'.Missing: silver ‎bullet
    rc helicopter light flashing Remote Controls Questions
Jan 19, 2016 | Brookstone Rc Mini Helicopter Silver...
I have a skyforce gravity r/c helicopeter trying to fix for my son.When it is plugged in the charger, it just blinks green light. Have it over night, and it is still just blinking green. Have lost remote....
It means that the charged battery is full. Some chargers have a steady glow, others have a flashing light to show that the battery is charged. When you run the helicopter, is the battery fully charged, does the helicopter blades spin flat out? If so, the battery is charged and the flashing light indicates the battery is charged. If the battery isn't charged or the blades don't spin enough to lift the helicopter, or fly for some time, then the battery isn't charged and the charger may be faulty. Take it to a hobby shop to see where the problem lies, the charger and its blinking light, or the battery.
Dec 28, 2014 | Toys
Skygiant rchelicopter when i sync it and then give it throttle all the lights on the helicopter syart flashing red and it dosent do anything
I bought 2 off brand ,of the same remote controlled Helicopters which cost about $30.00 each. The controller has A_B_C setting helicopter has none, You can set them up any way, either all on one or separate channels per controller which is channel A.
1st turn off Helicopter switch to off and controller off .
Set controller -1 to channel C , , then (controller-1 ) throttle knob to max, turn power on to controller -1 , throttle down and up 3 cycles and left and right 3 cycles
Turn on Helicopter 1 with controller -1 still on, it should work on channel C
Jun 11, 2014 | Team International Hawk Talon V3 RC Indoor...
She won't fly ?
First thing is to read manuals. A lot of RC's you have to bind or connect signals of the receiver and hand held controller. This is called binding. You always turn on radio first and then the RC. To bind there might be a button recessed in the receiver you need to push (you might need a small tool or stick) to push it. Most of the time it will go from a flashing light to a solid green light.
Jun 01, 2014 | Syma s33 3 channel rc helicopter 2.4ghz...
Aeroquest Gold Edition Helicopter (item no 50830) - Channel switched by accident
bottom rotors are both B rotors and A rotors on top. had the same issue and now in flight
Dec 26, 2012 | Toys
My Havoc Heli won't charge
http://www.buynicer.com/SWIFT6020--1-New-3--Channel-RC-Helicopter-w-Infrared-Remote-Control_pid8096.html
Aug 12, 2012 | Spinmaster Air Hogs Red Defender Remote...
I have 3 s107 and I it says 3 channel on the box and the transmitter says A B C but will only let me select 2 of them. What's the trick on flying 3 at the same time?
Mine's exactly the same as yours. Although the transmitter shows A B C the switch has only two positions, so there's a choice of two only. I doubt it's possible to fly 3 at the same time.
Nov 08, 2010 | SYMA Toys industrial New Syma S107 Radio...
RC New 3 Ch Co-Comanche RAH-66  Helicopter Logo
21 people viewed this question
Top RC Toys Experts
Tom Chichester
Kevin K.
Brett Duxbury
Brett Duxbury
Are you a RC Toy Expert? Answer questions, earn points and help others
