Question about Ryobi 18-inch Electric Chainsaw Chain Saws
Ryobi Elec Chain Saw ECS-2040
Micro switch burnt out, replaced both swiches but i seem to have mixed the wiring . What is the correct wiring for the switch?
  • dontbother10
    dontbother10 May 11, 2010
    We need the make, model, and serial numbers from the manufacturer?s tag to help you farther.
    President:
  • 2,220 Answers
The number you provided don't cross to an exploded parts list.
The drawing can be found here:
Homelite/Ryobi.com
https://www.gardnerinc.com/recons/disclaimer-lg.php - Agree; Choose “Product Line”; “Select OEM” & “Select Catalog” both to “Homelite Consumer Products”. A drop down list appears; self explanatory from here.
I advise you find an authorized repair facility for your own safety. HTH
Lou
Posted on Sep 21, 2009
I put regular gas to my ryobi c4620. Chain saw. And know it won't start I check tne spark plug has spark I put mix gas still won't start is there something I can do to get this chain saw to start
when you put un mixed fuel into a tool that needs to have mixed fuel/oil (the oil acts as a lubricant) and the tool will run on no lube for a little bit but it quickly damages the rotating metal parts inside the tool , most times the cylinder/piston is the most effected by this , ive replaced a few pistons when this occurs , and sometimes it allows it run again , but its never as good as new again
Apr 28, 2016 | Ryobi Garden
I have an electric RCS1835. The motor seems to have burnt out, lots of acrid smoke, and loss of power. What needs replacing ?
It may need to be cleaned in side the chain area which may be making it ******* the saw. It could be brushes in the motor if its DC motor which I'm sure it is.
Apr 13, 2016 | Ryobi Garden
Chain saw brake does not go off
Your switch is broken and needs to be replaced. You can do it yourself when you get the part from a Ryobi dealer.
Jan 16, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
What type of oil goes in the Ryobi 08570 Blower? What is the oil gas mix ratio?
You need 2 stroke motor oil or chain saw oil.Mix it according to the lable to make up 50:1 oil/gas mix.
Nov 07, 2009 | Ryobi Backpack Blower 25.4cc
My ryobi chainsaw rcs 2040 keeps stopping but motor is still running, chain not moving!
RYOBI----- with the motor running at high revs the chain stops indicates that the sprocket behind the centrifugal clutch is worn out or the centrifugal clutch itself ,or the clutch shoes are worn out the way to tell is to remove the bar and chain and have alook where the chain was conected to the saw, i think you will see the sprocket is buggered and as that is attatched to the clutch drum that will have to be replaced along with clutch springs and shoes, i think you have been running the chain a bit too loose or not running it at realy high revs ,which is what they are designed to do ,cme back to me if you feel the need
Sep 21, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
Ryobi 40cc chain saw oiler not working correctly
Hi
Check and clean the oil filter from oil tank.Check the worm gear wich engages with the oil piston pump(under the clutch).Near the hole where the oil comes out from oil tank there is an oil tank valve(see if it is clogged),it equalises the presure between interior and exterior of the oil tank.
best reagards savumihai71
Dec 23, 2008 | Husqvarna Chain Saw 20" Bar
Ryobi 18-inch Electric Chainsaw Chain Saws Logo
618 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
