Question about Xantrex Technology XPower Powerpack 200 Plus Power Supply (9383183) 200-Watt Power Supply
Recharge lamp is red while charging & will not charge
Battery status is red & yellow lamp on. What is needed so it will charge past the 50% charge that it stays at?
The red light on my mouse keeps on blinking
Here's a guide;
What do the battery lights mean on my mouse? Some keyboard and mouse models feature a battery light that shows the current status of the batteries. The following table describes the different lights and states.
Light
Device Model Status Single long green blink Rechargeable Batteries are good. This occurs when batteries are first installed or every time that the device is turned on. Slow green blink Rechargeable Device is docked in the charging station and is charging properly. Steady green Rechargeable Device is docked in the charging station and does not need additional charging. Steady green Presenter Mouse (Japanese version) Laser pointer is on. Red/green blink Wireless Device is discoverable (trying to connect to the transceiver). Slow red blink Non-rechargeable Batteries are low and need to be replaced. Slow red blink Rechargeable Batteries are low and need recharging. Fast red blink Rechargeable Device is docked in the charging station, but there is a charging error.
Reasons for errors: The wrong type of battery is installed; the battery or batteries are missing; or the battery connection is bad.
Solutions: Make sure that the correct battery or batteries are installed, and are installed correctly. If necessary, remove the batteries, wipe them with a clean cloth, and reinsert them. Steady red Presenter Mouse (Standard version) Laser pointer is on.
Oct 18, 2014 | Computers & Internet
Battery charger red charging light blinks once then goes out
Do the batteries charge? Are they charged? The green indicator normally is the status signal that the battery is charged and the red indicates that the battery needs charging or is charging. If you plug in a charged battery, some chargers will flash red momentarily then go out. This is an indication that the charger checked the battery (red light) and if the charge is good, the red light will go out. I hope this helps you.
Oct 24, 2017 | Hilti Drills
Nec vt540 vt540k
probably needs filters cleaning or a new lamp replacement.
Oct 07, 2013 | NEC VT460 Multimedia Projector
NEC lt240 lamp light stays off and power light is orange, no Image
COULD HAVE HOUR COUNT LAMP LOCKUP YOU WILL NEED TO RESET HOUR COUNTER BY USING BUTTON CONFIG AND MAINS.
john
www.jvsvisual.com
Apr 15, 2013 | NEC LT 240 Multimedia Projector
Ryobi charger model # 140295003 has a red and yellow light. When charging red light is on what does the yellow light mean? Also how long should the battery be left in the charger?
Completely wrong. Quoting from the user's manual:
"The charge indicator light (LED), located on the charg- ing stand, will light up red and glow when the char- ger is properly connected to power supply. This light indicates the charger is operating properly. It will remain on until battery pack is removed from charging stand or charger is disconnected from power supply.
After normal usage, 3 hours or less of charging time is required to fully recharge battery pack.
If both red and orange LED indicators glow, the battery pack is deeply or completely discharged, and 6 hours or longer of charging time is required to fully recharge battery pack.
Note: If charger does not charge battery pack or orange LED continues to glow after more than 30 minutes of charging, return battery pack and charging assembly to your nearest Ryobi Authorized Service Center for electrical check."
So to summarize: red = charging. orange (yellow) = fully discharged battery. orange after 30 minutes - bad battery or bad charger.
Apr 23, 2011 | Garden
Status Light Problem
Is the status light yellow or red? If it is yellow, then check the dust filter cover. That cover might be off or not secure. If the status light is red and blinking, then try unplugging the TV for a minute. If the error doesn't resolve the TV needs service. If it is out of warranty, you might want to open up the set and look for any obvious problems on the circuit boards (scorch marks, soot, bulging or leaking capacitors (look like cylinders on tripods)).
I hope this helps.
Jul 19, 2010 | Mitsubishi WD-62528 62" LCD HDTV
It is not switching on.when i set it for charging it show full charging but when i turn it on it shows red light and 3 time tone is heared thn it become off.....please help me
Even i also had a same problem after format a player its working good. Format your player and put songs again. thats it.
Notes:
  • Formatting is only available when the player does not playback.
  • If the OPR lamp lights red due to low remaining battery power, the player cannot be formatted.
  • All data stored on the player will be erased.
  • The Content Transfer software included with the player will also be deleted. If necessary,
    download Content Transfer from the customer support web site.
  1. Unite the left and right parts to turn off the player.
  2. Separate the left and right parts.
  3. Press and hold the jog dial for about 15 seconds until the status lamp blinks quickly.
    Release the jog dial. The OPR lamp lights red.
  4. Rotate the jog dial within 30 seconds after the OPR lamp lights red.
    The status lamp turns off. The OPR lamp lights alternately green and red each time you rotate the jog dial.
  5. Press the jog dial while the OPR lamp lights green.
    The OPR lamp blinks green quickly and formatting is executed. When the OPR lamp turns off, formatting is complete. If you press the jog dial while the OPR lamp lights red, or if 30 seconds have passed, formatting will be canceled.
have a nice song for ever...!!!!!!!!!!!!!!!!!!!!!!!!
Apr 11, 2010 | Sony Walkman NWZ-W202 MP3 Player
Status indicator flashes 3 short times, then one long red flash
Once the status light blinks 3 times, this is an indication that there's a problem with the lamp. The lamp may need a replacement.
If you replace the lamp, but get the same problem, check the inverter board.
If you're not sure where the inverter board is, then you may need to contact a pro for your safety.
Good luck and have a good evening!
Feb 14, 2010 | Mitsubishi WD-52327 52" Rear Projection...
It has been charging for days, but only the red & yellow lights come on. Shouldn't the green light shine when charged?
The battery is dead, a usual full charge for your sealed lead-acid battery takes only 10-12 hours. You can purchase a new battery from Black and Decker, they purchased Vector in 2006, here is the link;
http://www.dewaltservicenet.com/Products/ProductDetails.aspx?pid=69415&tid=15522
Feb 12, 2010 | Vector 1 Million Rechargeable Spotlight
Xantrex Technology XPower Powerpack 200 Plus Power Supply (9383183) 200-Watt Power Supply Logo
50 people viewed this question
Top Xantrex Technology Computers & Internet Experts
steve morris
steve morris
Are you a Xantrex Technology Computer and Internet Expert? Answer questions, earn points and help others
