Question about Element ELC-HS321 32 in. LCD TV
Someone please help me figure out why my elemnt t.v all of a sudden does not have no picture?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 96 Answers
There are many reasons behind this problem. Here are some common issues about this problem.
  1. Missing LED's Connection from PCB.
  2. Burning LED's (Back light)
  3. No current on back lights.
  4. See in sun shine or torch light, If display show and lights are faulted. Contact to repairing lab.
Posted on Jul 09, 2015
Crumbs stuck on the sides and bottom of toaster
You can follow the instructions on how to replace the heating elemnts of the dualit toaster in the link
http://www.fixya.com/support/r4472039-procedure_replacing_heating_elements
With this way you remove yours clean the toaster completely and put the elemnt back.
Good luck
Jul 24, 2010 | Dualit CTS4E 4-Slice Toaster
GE JSP39 range; front right burner eye doesn't work at all
there are two tests to chk which is bad,wether it is the control switch or the elemnt.disconnect the power to stove and open the top and disonnect the wires from elemnt and chks the continuity of the elemnt coil with a multimeter.if the meter does not read continuity then elemnt is bad.to confirm this connect the wires back to the elemnt and plug the unit to power, turn on the switch to high position and read the voltage coming to elemnt.it should be 240 volts.if u read that voltage, then for sure element is bad.if every thing is opposite to this then it is the control switch which is bad.
Aug 21, 2009 | GE JBP65 Electric Kitchen Range
I have a 48 in RCA and it pulls in at the top and bottom
Vertical Ic will be on right side of FBT flyback transfomer also there is a 1ohm feed resistor ck it and next to vert ic ck capacitors 100uf 35v, 2.2uf 50v .
Aug 21, 2009 | RCA HD52W59 HDTV Projection Television
Blurred Taking Pictures, But not all the time???
lens misallignment due to worn out gears on focus adjustment (zoom in/out), needs repair but could be expensive and not reliable enough.
May 20, 2009 | Casio Exilim EXZ75 Digital Camera
Blurry pictures, HELP ME PLEASE!
I'm currently having the same problem. :[
You might want to check and make sure your lens in on the "A" setting and not "M". This can be found on the side of your lens.
Nov 24, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Element Light Stays oN
An element control switch has failed or a connection to the switch has fallen off.
Jun 09, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Replacing main oven heating element
the element will held in place from the screws inside the oven not the back
Apr 17, 2008 | Kitchen Ranges
Element ELC-HS321 32 in. LCD TV Logo
100 people viewed this question
Top Element Televison & Video Experts
Joseph Hoffmann
Are you an Element Televison and Video Expert? Answer questions, earn points and help others
