Question about Western Digital 500GB My Book Pro-External 500 GB Hard Drive
Is my hard drive broken? Can I some how "reboot" a hard drive?
It slipped off my table, a few cm's to the ground. It has stopped buzzing now but it still will not read that I have a hard drive plugged in.
I am on a Mac, are there any possible solutions to getting the information off?
    Problem Solver:
  • 9 Answers
Ok so there are a few things you can try. firstly simply remove the case and see if anything internal is damaged, DO NOT go and start prodding a pulling anything that seems broken, as odds are you will make it work. If there are any internal damage odds are you wont be able to restore any data unless you get it fixed by a professional.
My solution is to take the Hard drive from its housing and put it into your computers dvd drive, inserting all necessary cables eg power supply and the reader cable. dont do this when pc or hard drive are switched on. this has happened to me before and i was able to recover all of my data.
hope this helped.
josco91 =)
Posted on Jun 23, 2009
Relay buzzing under hood with car shut off
Hello!
Is it an electric like buzzing not too loud, or more strong?
I had a problem with the vacuum pump which is located on the left side, a little bit right, below the water coolant expansion tank, it is white and has the size of about 5 cm in length and about 2-3 cm diameter, if you pull down both little black rubber harnesses and it stops, then it was a vacuum pump. Made a quite loud buzzing sound in my car after I stopped the engine. I'd give it a try, only 10 seconds to do the work. If this is the problem you can get one free from a wreck or buy a used one, the don't really go bad too often, I would not buy a new one. But also read the other solutions as this was only my case.
Mar 19, 2014 | 2004 Kia Sorento
Tip
OMG! it worked! I have a 500 gb seagate and I dropped it very hard on the floor....
My hard drive was dead and wasn't recognized by the computer, it didn't even start, just a few clicking noises, which according to some of the experiences is the same as a DEAD Hardisk. Anyways, as I read that sometimes this happens as a result of a hit, well, I wacked my HD as a last hope for it to recover its "memory" (as in the movies) and believe me or not, it worked! I don't know if this might help yours, but it saved mine!
The way I did it was like this: I started the pc and when the HD started to run and I heard a couple of clicks, I hit it against the table while in vertical position (assuming that the arm of the HD might slightly move better that way) one time, and then when the spinning and the first click was heard agin I hit again. After that I heard the typical searching sound of a HD, and you can imagine I started to pray that what I heard wasn't my anxiety sound (if it has any). Now I am a firm believer in the old trick of whacking the old TV to get the vital signal back!
Good luck to you too!
on Apr 28, 2009 | Western Digital 250GB MyBook External USB...
Seagate goflex 500gb not detected giving 3 beeps
See if Testdisk sees the drive and if so try restore or create a boot sector
Nov 21, 2017 | Seagate FreeAgent GoFlex 500 GB USB 3.0...
Dell Dimension E520 Hard drive constantly buzzing
This could be a sign of a failing hard drive - I would backup all of your important documents immediately to an external drive to prevent you from losing any important data.
As you have already cleaned out the dust , there is a chance that one of the system fans (or the CPU fan) may be faulty or some wires inside your system case might be catching on the fan while it is spinning.
Disconnect all the system fans , so just the CPU fan is left plugged in and then switch on the system and see if the noise has stopped. Then plug each fan back in one at a time to identify if any of them are causing the noise.
Dec 01, 2013 | Dell Dimension E520 PC Desktop
My wd 500gb makes a buzzing noise
Either you broke the connector or crashed the head. You could crack the case open, buy a new empty enclosure and see if the drive will work in it. Otherwise if the head is crashed, replace the drive.
Jan 29, 2013 | Western Digital My Book Essential Edition...
Hearing a buzzing sound at start up.
I think that your PSU is dead and your motherboard must be dead too (not sure)
Dec 16, 2012 | Computers & Internet
Blade stops in middle of cut, slipping motor rpm is un changed. 10" compound sliding Bosch miter saw
Going on the information aas I read it, the blade is slipping, meaning that it is not tightened enough or a spacer in the hole in the blade is too thick. Make sure that the wall plug is pulled out before attempting any work on the blade.
Jan 16, 2011 | Bosch 10" Slide Miter Saw
My SanDisk 2 GB Cruzer suddenly stopped working. When plugged in it is still recognised as installed, but indicates that the disk in the drive is unformatted and asks if I want it formatted. The volume...
Windows cannot read the "Table-Of-Contents" from the SanDisk.
So, it "guesses" that trying to write a new T.O.C. will prepare the disk for "first" usage.
So, say 'no' to the question.
Search online for "file recovery" programs -- they try to read through the entire volume, chunk-by-chunk, to see if _any_ of the files can be read, and if those chunks can be "stitched" together to reassemble your files.
Or, spend $9 to buy a replacement 2GB unit.
Oct 29, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Reebok 8050es treadmill walking belt has started slipping/skipping. It has been oiled and it is 2 years old.
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both rear roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 in. (5 to 7 cm) above the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.If you still have slipping then the drive belt under the motor shroud can also cause this problem unplug unit remove shroud then plug unit in start it up observe the front roller to see if it stops if it does locate the tension adjusting bolt by the motor loosen motor mount and proceed adjusting until slipping has been eliminated
May 05, 2010 | Reebok 8050 ES Treadmill
Computer stopped being able to read external Maxtor hard drive. 640GB PN:9NZ2DG-500 SN:2HBADBDS. How do I retrieve data
Check the USB port and/or the cable, check if windows can detect your device. If windows can detect but can't read data perform a format or delete the partition and then use any file or partition recovery software you want to use. They will automatically rebuild partition table and MBR according to your need. If windows can't detect, unplug your device, uninstall the driver from the device manager, restart your pc, plug your device again and see windows will automatically install the device.
Dec 31, 2009 | Computers & Internet
Open Questions:
See all Western Digital 500GB My Book Pro-External 500 GB Questions
Western Digital 500GB My Book Pro-External 500 GB Hard Drive Logo
244 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marvin
Marvin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
