Question about Vehicle Parts & Accessories
Renault modem car boot wont open - Vehicle Parts & Accessories
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 48 Answers
JUNK THAT FRENCH JUNK!!!!!!!!!!!!!!!!!!!!!!!!!
Posted on Dec 04, 2014
Boot Lid on my Renault Clio 2005 model wont close
Check you have not accidentally closed the latch this can be done by pushing the lock key when boot is open.
Try to fix by pressing the open key or try to push the latch open with your finger or a screw driver.
Regards Craig
Feb 13, 2018 | Renault Cars & Trucks
Can't open boot on a x reg renault megane scenic
Most likley to be the micro switch in the boot quite common, u can open from inside if I remember correctly where the boot latch is in the centre the bit that keeps the boot closed on the left of the catch there is a little lever u can use a spike to open it , if it's not there there will be a little lever somewhere on the catch that opens the boot
Jan 29, 2015 | Renault Cars & Trucks
Renault modus fual door wont open
Fuel flap actuator has failed to open simple open trap door in boot right hand side panel inside you will see a black box approximately 10cm by 7 cm with a hook that can be pressed upward to open the flap
Jul 13, 2014 | 2005 Renault Modus 1.5
Boot wont open
drive shaft boot retaining clips has to be cut with hack saw then you has to cut cv boot open.
Oct 26, 2013 | 2005 Renault Grand Scenic
Doors not locking on renault megane oasis
Hi there?
The doors wont close if any of the other doors are open. open and shut all doors and the boot several times and see if it works. It's a cheap shot but it may work. Good luck....
May 21, 2011 | Renault 181 Cars & Trucks
Hi, my central locking wont unlock the boot (renault clio 2002).
Its sounds like a sticky boot lock it wont be the remote, open the boot with the key and spray all around the lock and lock mechanism with WD-40 then lock and unlock keep repeating unlock, lock using both the key and remote it should free off.
Be sure to use plenty of WD-40 on the underside of the boot lid into the mechanism dont be shy with it.
Hope this helps.
Jan 22, 2010 | 2003 Renault 181
Cant open the boot
you need to fold down back seats and remove boot panel from inside {bring torch} then pull on little bars that connect to door lock one will click then you should be able to pull the handle and open the door.
Nov 17, 2009 | 2003 Renault 181
My boot wont unlock with key fob have changed batterie but still not working renault clio 03
sounds like solinoide for the boot lock is gone very easy to replace.just open boot then remove boot cover its a small plastic thing with a rod coming out of it . you can pick them up in scrap yards for very cheap.
Nov 07, 2009 | 2000 Renault 181
Renaualt scenic boot glass wont open
Probably the switch - been trying to find one myself, but no ide what it's actually called. If you remove the switch, and stick a bit of wire into the connector to short it out, the glass should then open - if it does it's definitely the switch, if it doesn't... who knows. (remember to have the car unlocked when you try to short it, or it won't open).
Mar 08, 2009 | 2000 Renault 181
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
