Question about Nespresso D520 Gran Maestria Espresso Maker, Platinum
Yellow light on Nespresso D520 Gran Maestria Espresso Maker
Nespresso C60 not work
DO YOU HAVE LIGHT OF SOME KIND IS THERE ANY POWER INDICATOR ?
Nov 12, 2015 | Nespresso Pixie C60 Single Cup Espresso...
Where can I buy the gran maestria water tank?
I cannot find one but you can try calling 866-212-9040 to see if they can help you. http://www.nespresso-us.com/machines/gran-maestria/
Jun 22, 2014 | Coffee Makers & Espresso Machines
Nespresso pixie c60 cup stuck
Can't make the coffee and can't open the lever of pixie nespresso machine
Feb 10, 2013 | Nespresso C60 Pixie Electric Titan Single...
Nespresso Maestria pump isn't primed
We had the same problem and were ready to return the device when we were able to fix it. Here is what we did:
1. Fill the water tank all of the way and place in machine
2. Let the tank sit in position for a few hours (we let ours sit for 3)
3. Run the descaling option
4. Run a few cycles of the "longo"
5. If the machine is still not working repeat the process (Ours started to run after the 2nd cycle)
It just appears that the pumps are shipping with air in them and needs patience to get it out. Once you get it going though you won't regret it :)
Dec 20, 2012 | Nespresso Maestria Rosso
Nespresso essenza lever stuck
My Nespresso lever won't push back and it won't produce any coffee from capsule that is stuck in machine.
Jun 13, 2012 | Nespresso Essenza C100 Espresso...
How do I get replacement parts for my Nespresso C100 Essenza?
you can find them by searching on amazon. click here Amazon com nespresso replacement parts. Hope this was helpful. cheers
Jun 09, 2012 | Nespresso Essenza C100 Espresso...
I have a nespresso D290 It shows that its on but a small yellow light keeps flashing and when I push other buttons it beeps
The instructions for your Nespresso LeCube 250 can be downloaded here:
http://www.nespresso.com/fileadmin/ca-en/_img/manuals/NES_08_00_EN_Nespresso.pdf
The flashing light may indicate a problem with the heating system and proper water temperature is not being reached. Have you descaled your machine?
You may wish to seek guidance from Nespresso: 1-800-562-1465
Oct 30, 2011 | Nespresso D290 Espresso Machine
What does a blue light mean on my aerochino? thanks.
Means you are not heating your milk, the frothing milk will be cold (for iced drinks) because you have held the button down longer than normal. Usually it takes 5 Seconds for the blue light to go on. try turning it on or pushing the button faster, It should turn on red, for heated and frothed milk.
Nov 10, 2010 | Nespresso Aeroccino Automatic Milk Frother
Light don't stop blinking .... Nespresso Essenza C100
My guess is that the Essenza is in 'Descaling' state. See section 7 of the essenza manual. To get out of it, hold both the buttons down for 3 secs. The lights will then blink at normal rate for a bit and then turn solid.
Jun 21, 2009 | Nespresso Essenza C100 Espresso...
The Nespresso won't make coffee yellow light keeps blinking
This is because there is either too much water in the drip tray, the empties container is full or the drip tray is not placed correctly. This took me a while to figure out as well, and the manual was little help. Nespresso is located in Switzerland so their support number is international. Hope this helps someone...
May 25, 2009 | Nespresso D290 Espresso Machine
Nespresso D520 Gran Maestria Espresso Maker, Platinum Logo
48 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
