Question about HP Pavilion dv6915nr Notebook
Laptop will not boot. LED light comes on when power cord is plugged in
rulds2008
  • 3866 Answers
SOURCE: I have a DV9000 17" Notebook, power led blink three times
Okay the logistics here of this laptop that would be normal for the power light not to come on without battery in place REASON? Because this laptops primary source is battery secounary source AC power.
A Blinking light and no boot means a hardware failure. I would need to personally look at it to tell you 100 percent what is the cause but I would rather you take it to Best Buy and have them do a full eval on it for under $50 bucks if there is something really wroung they can follow up with a warranty claim.
Posted on Sep 23, 2009
SOURCE: hp pavilion dv8000 help
I had the EXACT same issue on my HP Pavilion DV8000. After reading this thread I started disecting the machine, sure the issue was a faulty internal power plug/cable. It is TRULY a big job, but very doable without special tools. You pretty much have to take every single screw out of the thing to get to that stupid cable.
Here are a few things to know:
1) there are a lot of screws - mainly long black (L 12) and short silver (L 5x2.5). Keep track of all of them in order so you don't end up like me - with 3 leftovers. Lol. There is ONE long black screw that is a little shorted than the others (L 10). This is one I had left over. There are two VERY tiny black ones. I also have one of those left over. There is also a few smaller black ones, too. Just keep them all noted as you remove them and remember where these odd ones go!
2) There are some very flat band cables that plug in to tiny plgs. However thereis no plug on the cable. The flat end just shuves into the plugs. These are very delicate. be gentle with them.
3) When you finally get the housing for the fan loose you can now get to the entire power supply cable. Here is a note: I FIXED my problem by unplugging this cable and plugging it back in. The cable runs under the fan housing, and it seems like you have to remove that housing to get to the cable, but actually it comes out again right next to the processor and heat sink. There is a thin sheet of black sticky insulator tape over the processor and the cable at that point. You'll have to gently remove it. There is not much room there, but you CAN unplug the cable without removing the entire fan housing.
Here is what I did to test this plug and cable. After unplugging it, I shoved a tiny straightened staple (the female plug is very tiny) into the female receptacles for the prongs on the motherboard (red and black only). Then I plugged the power supply in to the power jack. With a DC meter I verified that the female end of the power cable inside the machine was getting juice, and it was.
With nothing left to test, I put it all back together (save three screws) and it is now charging the battery and running from the ad power plug. Whatever I did fixed it!
One last note: There are 4 sequenced screws that hold the heat sink tight. These are under a bit of pressure so the sink is tight. DO NOT remove these as the sink has a heat conducting "goo" that helps it disperse the processor heat. As old as these machines are now, you don't really want to disrupt that "goo" and risk the processor over heating.
I hope all of this typing helps someone.
Posted on Apr 17, 2010
  • 302 Answers
SOURCE: My HP DV7 laptop will no power on. The LED next
try pulling the hard drive loose and see if it tries to boot and comes up with no boot device found if it does the hard drive is bad if not the bios is corrupted and will need the bios reflashed.
Posted on Jun 22, 2010
Bowmans IT
  • 85 Answers
SOURCE: My HP dv4 1120us laptop
Sounds light a power switch short, but lets try to take the memory out of the laptop and power on the laptop. Does it boot up? if so lets try 1 memory stick at a time.
Posted on Nov 29, 2010
joecoolvette
  • 5660 Answers
SOURCE: HP Pavilion Dv6000z will not turn on
Florida Bob,
Battery is part of the power/charging circuit. As you have found it needs to be in place; kaput or not.
Believe your problem to be Power MOSFET's.
This will explain why,
http://www.fixya.com/support/t15330613-hp_pavilion_dv8_not_starting_up
(The Mayohardware article)
Now you may know what is wrong, and where to get replacement parts, and how to replace.
This is the HP Support link to the free Service Manual,
Main Support page for the HP Pavilion dv6000z Notebook PC,
http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&lc=en&dlc=en&product=3224052
Manuals download page,
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lc=en&product=3224052&
In the list you want the blue -
HP Pavilion dv6000 Notebook PC - Maintenance and Service Guide
USE an ESD wrist strap.
Use a multi-compartment container for the various screws you will remove.
Label each compartment for the area the screw/s come out of.
SOME screws look VERY similar to other screws.
Advise DO NOT mix them up.
http://www.ebay.com/itm/65W-CHARGER-AC-ADAPTER-FOR-HP-Pavilion-dv1000-dv2000-dv5000-dv6000-146594-001-/221082152535?pt=Laptop_Adapters_Chargers&hash=item337985ee57
18.5 Volts (DC)
For additional questions please post in a Comment.
Regards,
joecoolvette
Posted on Dec 11, 2012
Samsung r480 turn on blank screen
Does anything ever post to the screen when your turn the laptop on? If not, your video card on the motherboard might be the issue.
Since you mention that the hdd led does not light up, is the hard drive good?
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous. Most times the problemis with the memory or Video Card. Count the Blinking Lights or Beeps and takenote of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.
If you removed or put in the CPU and the Heat Sink did you put a fresh coat of Thermal Paste on them? If not that is like metal touching metal and it will short out when you try to boot up.
The other problem might be that either one of your memory chips is bad or one of the slots on the board that holds the memory is bad.
Maybe your memory is bad or the memory slot is bad.Remove the Power Cord, Remove the Battery, Remove the cover that houses the memory on the bottom of the laptop then remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
May 31, 2012 | Samsung R480 Notebook
Turning on of laptop
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.Maybe your memory is bad or the memory slot is bad.Remove the Power Cord, Remove the battery, Remove the cover that houses the memory on the bottom of the laptop then remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
May 29, 2012 | Computers & Internet
My dekker led does it work no lights come out.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.Maybe your memory is bad or the memory slot is bad.Remove the Power Cord, Remove the Battery, Remove the cover that houses the memory on the bottom of the laptop then remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
May 13, 2012 | Computers & Internet
Plug in power cord and led on side of laptop does not light. Now I can not charge the laptop .
Remove the Power Cord, Remove the battery, Remove the cover that houses the memory then remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.It could be a problem with the video card on the motherboard if all the above does not solve your problem.
Apr 24, 2012 | Computers & Internet
MODEL LT2016U WONT BOOT UP
Is it trying to boot up or is it doing absolutely nothing when you plug in the power cord and hit the power button?
Mar 30, 2012 | Computers & Internet
When i turn on, the green light comes on then goes out,why
Mar 28, 2012 | Computers & Internet
I have a DELL Inspiron Mini. The power LED light is alternately flashing white and red. The netbook will not come on unless I have the power cord plugged in. When I do plug it in and power on, the...
This could indicate a bad battery. Try removing the battery and powering on the laptop. If the power LED remains white then you have a problem with the charging circuit. That means your battery could be defective or the battery charging circuit on your motherboard is faulty.
Feb 21, 2011 | Dell Inspiron Mini 10 Notebook
My HP dv4 1120us laptop will not power on. When I insert the power cord the led for power bolt comes on and when I press the power button the power LED flashes once and then nothing happens. The power bolt...
Nov 29, 2010 | HP Pavilion dv4-1120us Notebook
I have a gateway ma7 laptop and press power and get nothing
When the computer is off, unplug the power cord from the laptop and then plug it back in. See if the charge light (lightning bolt symbol next to the led) comes on or turns green/blue. If it doesn't your power supply may not be working, even if the light on the supply is on. Second is the battery may be damaged. Remove the battery and see if you can power on at all.
If it boots with only the cord, the battery is bad/shorted forcing shutdown.
Apr 11, 2009 | Gateway MT3705 Notebook
Will not power up
pull battery and cord. push on / off button for 60 sec. put battery back in and plugg in power and boot up.. something else to try is some one elses battery to boot up in.
Jan 07, 2008 | Toshiba Satellite A35-S159 Notebook
HP Pavilion dv6915nr Notebook Logo
15 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
