Question about Troy-Bilt Mtd Southwest Tb320bv "troy-bilt" Gas Blower Vac 31 Cc
Why am i getting gas in the oil reservoir - Troy-Bilt Mtd Southwest Tb320bv "troy-bilt" Gas Blower Vac 31 Cc
Where is the fill line for the oil ?
Are you talking about the oil for the gas or the bar oil? If it's the bar oil there usually isn't one. You simply fill the reservoir. If you're talking about oil for the gas and you need a 50 parts mixture just put 3 oz for every gallon your gas can holds.
Oct 09, 2014 | Garden
How much chain oil do I need for my poulan chain saw?
fill the oil reservoir to the top, each time you fill gas reservoir, a quart of oil usually should last you the use of a gallon of gas.
Jun 04, 2014 | Poulan Pro Chain Saw 46cc 20"
Do Petroleum Engineers enjoy their job in Jakarta Indonesia?
Depends upon which Petroleum Engineering sub-discipline one pursues. There are 3 sub-disciplines, Drilling Engineer, Production Engineer, and Reservoir Engineer. A Drilling Engineer, as the name would imply, is tasked with the drilling of well meant to produce oil or gas. They generally work both in an office and out in the field at well sites. A Production Engineer is tasked with getting the well to produce oil and gas after it is drilled and later to economically keep the well flowing making oil or gas. They generally work both in an office and out in the field at well sites. A Reservoir Engineer works in concert with Geoscientists (geologist, geophysicist, petro physicist) to locate reserves of oil and gas an quantify the value of the oil and gas. After the well is producing the Reservoir Engineer will keep track of how much of the reserve has been produced along with how much there is left to produce from the reservoir. Reservoir Engineers generally work just in an office.
As for what it's like. Imagine a job where everything you do is done through a 5-1/2" pipe 2-miles long. Unlike other engineering disciplines such as civil, mechanical, etc. the Petroleum Engineer can never see what they are doing with a well.
Apr 11, 2014 | Walthers Ho Scale - Wide Oil and Gas...
Does this 2stroke engine need the chainoiler reservoir(hence oil circulation and lubrication)to operate a gokart or is the gas\oil mixture enough?its easier to mount less one chainoiler reservoir
One reservoir is just for the lube of the chain.if you don't use this ,your chain will get hot and stop working the other one is for the engine to keep it lubed, you need both
Jan 10, 2014 | Garden
Troy-bilt cultivator 26cc gas/oil separate engine spewing oil out through filter when running...there is a hose from the oil reservoir straight into the back of the filter...as the engine revs it literally...
Hi, Check the oil reservoir breather that it's not plugged up. The oil should be returning back to the reservoir not going to the filter. That tells me that there is air being pumped into the engine (oil).
The piston rings could be broken or the carberator needs to be readjusted.
Open the air screw abit more on carb. Then see what happens. Good luck.
Jul 30, 2011 | Troy Bilt Tiller/Edger 26cc, Model No....
Leaky oil reservoir on MAC 3200 series gas chainsaw
The reservoir is part of the block assembly. It can not be change without replacing the entire block assembly.
Jul 09, 2009 | Garden
What kind of oil do I use in the oil reservoir of my chain saw?
I believe the reservoir you are talking about is for the bar chain oil. You can get it most anywhere. As for mixing the gas and oil mixture, you will need 2 cycle oil. It is available most everywhere also. Most modern chain saws use a 50:1 mixing ratio which means 2 1/2 ounces of oil to 1 gallon of gas. Hope this helps.
Apr 26, 2009 | Remington 16" Electric Chain Saw
Troy-Bilt Mtd Southwest Tb320bv "troy-bilt" Gas Blower Vac 31 Cc Logo
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
