Question about Poulan Pro " Pro" Self Propelled Mower
Engine sounds like its missing
We changed the spark plug and it still happens
Whilst driving my e46, M43 engine, 318i, 2001 year model, my car picked up a miss and it stopped idling. It also had no power as the engine sounded roudy when i reved the engine. What happened?
Did you replace the spark plugs with the same brand recommended by ? Might also what to go over all the wiring harnesses, you disconnected when replacing the exhaust. Might of pinched a wire.
Sep 03, 2016 | 2001 BMW 318i
2004 linconl aviador Have code p0301, p316 I
If you are saying everything is ok when the engine first starts but number one starts to miss when at operating temp. Sounds like the number one coil has developed a internal crack that opens up when hot or at operating temp..causing a miss.change it.but before changing the coil check the spark plug wire it may be breaking down when hot..good luck
Oct 21, 2014 | 2004 Lincoln Aviator
Engine putters and has no power uphill, sounds like a miss, just replaced plugs and wires, its worse in the rain. any ideas?
If this happened after replacing Spark Plugs and Wires, you connected some wires in the wrong plug. If this happened before changing plugs and wires, you need to replace distributor cap and rotor as well. Note: Rain shouldn't make any difference unless electric system is exposed to water.
Apr 02, 2014 | 2001 Dodge Caravan
Why does 1988, 911 engine miss fire? what could be the cause of the problem? when I change the spark plug no 2 and 6 there are traces of oil but after replacing the spark plugs it runs smoothly again
It sounds like your spark plugs were fouled. Does it keep happening? If so, you may have low compression and oil is blowing through. If it only happened that one time then I wouldn't worry about it. It happens after a while.
Dec 11, 2012 | 1988 Porsche 911
I have a 1995 Chevy S10 4.3L Engine. What would cause the engine to miss during acceleration??
Have you changed the spark plugs this year ?
Is the check engine light on ?
How's the cap rotor and wires ?
A miss under load is normal when one of the spark plugs is weak or they are not getting enough voltage from the coil. Also, a weak injector or problem with the fuel system can cause a miss.
Jul 31, 2012 | Cars & Trucks
1998 toyota avalon spark plug problems
A common problem on these engines are the ignition coil packs, there is one for each cylinder, do you have any diagnostic code information so I can help diagnose the problem? The cat converter overheated due to the misfire.
Jul 09, 2017 | Toyota Avalon Cars & Trucks
My 93 olds cutlass ciera keeps misfiring and stalling, i have change the spark plugs, fuel filter, o2 sensor, maf sensor, and still stalls and misfires any ideas?
For engine misfiring problem check the help links mentioned below. Click the link below to go through the troubleshooting procedure :---- Engine misses and truck jumps? Hard to down shift? Issue with high gear only? http://technoanswers.blogspot.in/2012/02/engine-miss-and-truck-jumps-hard-to.html
Bad miss at idle?
http://technoanswers.blogspot.com/2012/01/bad-miss-at-idle.html
While stop engine idles like cylinder missing?
http://schematicsdiagram.blogspot.com/2012/01/while-stop-engine-idles-like-cylinder.html
Engine Misfire codes for car?
http://schematicsdiagram.blogspot.com/2011/12/engine-misfire-codes-on-chevrolet.html
Engine Misfire codes?
Misfire on cylinder 4?
http://schematicsdiagram.blogspot.com/2011/12/misfire-on-cylinder-4.html
Oil on spark plugs and car misfires?
http://technoanswers.blogspot.in/2012/02/oil-on-spark-plugs-and-car-misfires.html
This will help.
Thanks.
Feb 14, 2012 | 1993 Oldsmobile Cutlass Ciera
1990 Nissan Stanza 2.4 Liter Engine miss. This is a used car we just bought, has 112,000 miles on it and it only happens when I put the transmission in drive or reverse. It does not happen when in park....
could just need a tune up,you could also pull of the distributor cap and look for oil intrusion, if there is you will need to replace the distributor
May 27, 2010 | 1990 Nissan Maxima
96 ford taurus ran fine yesterday go on 25 mile trip half way through trip engine runs ruff. Like miss firing just changed plugs about two weeks ago it idles ruff but runs doesnt stall at all. baffeled
sounds like spark plugs or spark plug cables are bad and it is in fact misfiring this happened to me in my car and my spark plug cables were bad
Aug 29, 2009 | 1996 Ford Taurus
Just started missing while driving and the engine light came on
With very little to go on, here's a list of possibilities:
- Bad tank of gas/ dirt in the tank
- bad spark plug wire or spark plug (this just happened to me with an old VW. Just out of the blue started missing at a stop sign.)
so...start by removing one wire at a time until one of them doesn't change the sound of the engine at idle. when you have one identified as not making a difference if it's on or off, you've found your culprit, but you can verify this by switching it with another wire (at both ends) and making sure the effect is true at the different location. if it's not, then replace the spark plug (or swap if you're curious)
Aug 28, 2009 | 1993 Saturn SL
Poulan Pro " Pro" Self Propelled Mower Logo
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
