Question about Compaq Presario R3000 Notebook
System not start up
My system not starts even in safe mode and old best configuration, please help. 9753310707
  • 3 Answers
Probably hard disk problem. Can you get into BIOS setup and boot from CD (I.E. Windows repair function)?
Posted on Jun 23, 2009
2 Suggested Answers
  • 10 Answers
SOURCE: My system not starts even in safe mode and old
Just reformat your computer.
Posted on Jun 24, 2009
My moto G is stuck in safe mode I've tried everything please help
have you checked system configuration
msconfig
as it can be set to force the windows os to go into safe mode at start up
http://windows.microsoft.com/en-au/windows/using-system-configuration#1TC=windows-8
Apr 18, 2015 | Computers & Internet
Can u restore a emachines pc from the bio or boot logshelp
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer. Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System. Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice select the safe mode option To perform a system restore, follow these steps: 1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue. Hope this helps.
Dec 28, 2012 | eMachines W3507 PC Desktop
WHERE DO I FIND SAFE MODE IN LAPTOP OF HP 6735s
Enter Safe Mode at startup Follow the steps below to start Windows Vista in Safe Mode.
  1. Remove all CDs and DVDs from the computer.
  2. Restart the computer.
  3. At the first screen on restart, before the HP or Windows logo appears, press the f8 key repeatedly.
  4. When prompted, select the Safe Mode with Networking option.
  5. Log onto the computer with a user account that has administrator rights.
Enter Safe Mode when PC is operating If the computer can boot into the Vista operating system, follow the steps below to enter Safe Mode.
  1. Click Start , type msconfig in the search field, and then press the enter to open the System Configuration window.
  2. On the General tab of the System Configuration window, select Diagnostic startup .
  3. On the Boot tab, select Safe boot and click OK .
  4. When prompted, click Restart to start the computer in Safe Mode. If the computer does not restart automatically, press the Power button to turn the power on.
  5. On the Tools tab of the System Configuration window, select and launch the desired diagnostic tool.
The computer is now operating in Safe Mode. Exit the Safe Mode After completing the required troubleshooting and repair, follow the steps below to exit Safe Mode and return to normal operation.
  1. Click Start , type msconfig in the search field, and then press enter to open the System Configuration window.
  2. On the General tab of the System Configuration window, select Normal startup and click OK .
The computer restarts in the normal mode.
May 18, 2012 | HP Compaq 6735s Notebook
Even after formating and installing windows, after cold restart when i start my system its showing me the screen with several options like safe mode, safe mode with networking, noramal mode, last best...
Chose normal mode, and start normally windows. Next time, make sure that you shut down, or restart computer in a proper way.
I hope I helped you, please rate my solution
Jul 30, 2011 | Microsoft Windows XP Professional With...
System not starts up
There may be some problem with your hard disk. Try unplugging hard disk and plug it back and boot or format again
Jun 25, 2009 | Compaq Presario R3000 Notebook
Windows XP operating system does not load.
You need to repair your windows xp installation.
Insert the xp install cd and power off - then power on your pc.
If the screen says "press any key to boot from cd" then do that.
It takes a while until you get to choose options.
Choose the repair previous installation option by pressing the R key when prompted.
Follow the instructions on the screen and you should be fine.
May 09, 2009 | E-Machines (T2958) PC Desktop
IBM T22 Thinkpad won't boot up - not even in safe mode
either you have a virus or a corrupted dll file.
eitherway, beside create a bootable CD or Floppy disk, and try to fix from there, thats' time a money.
the next best thing, is to reinsall the operating system.
the other option is get a new hard drive and install the operating system on that so you can preserve the data you have on the old one.
Mar 04, 2009 | IBM ThinkPad T22 2647 Notebook
Windows not starting
First of all goto safe mode booting and then go back to normal booting and check it.
You have mentioned as not responding.....what exactly is it doing? can be more specific on this..
Jul 28, 2008 | Microsoft Computers & Internet
Compaq Presario R3000 Notebook Logo
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
