Question about Dell Precision T3500 Computer Workstation (Intel Xeon W3503 160GB1GB) (BW1S13604) PC Desktop
T3500 System on, BIOS not executing, 2,3,4 flashing, solid amber power button
The manual sais "System on. BIOS not execution. This is the transition state to POST states" but we cannot find any directions as to what to do form here... can anyone advise, please?
  • Dell Master
  • 998 Answers
Means that the BIOS upgrade did not work. Computer toast.
Posted on Oct 09, 2014
  • 239 Answers
SOURCE: Dell 5150 - solid amber light at the switch.
Make sure the 12v power connector is securely connected to the system board. If you open up your computer look at the end of the board that the memory modules are there is a 4 pin connector thats the 12 v Make sure thats plugged in and secure, If thats ok you have already did the removal of the memory and replaced them, take out any pci express cards and use your onboard video, if that don't work try one memory module at a time see if that works you already seem to be savoy enough to do that and try that, and if that does not work you may need a new power supply. You can check it but probally will be bad I have the same desktop and thats been a problem with these 5150 along with the mother board going out after the warranty expires. I sure Hope this helps you out,, Happy Holidays to you and yours. Hey If you need me to look anything else up let me know. Thanks again bear001
Posted on Dec 15, 2007
jelacio
  • 10 Answers
SOURCE: I have a flickering amber light on the power button; replaced power supply and motherboard with no luck
FIRST IF YOU REPLACED THE POWER SUPPLY OF YOUR DELL PC,
MAKE SURE IS A RECOMMEND POWER SUPPLY FOR DELL COMPUTERS ONLY
BECAUSE DELL USE A DIFFERENT (NONSTARD) PS
AN PLEASE DON'T TURN YOUR PC ON, TILE YOU ARE SURE I'TS A DELL COMPATIBLE POWER SUPPLY
YOU CAN FRY YOUR COMPUTER
ON THE MOTHERBOARD I'T MAY BE THE BIOS (BIOS STANDS FOR INPUT /OUTPUT SYSTEM) I'T A CHIP ON YOUR MOTHERBOARD THAT CONTROLS THE SYSTEM HARDWARE AND ACTS AS AN INTERFACE BETWEEN THE OPERATING SYSTEM AND THE HARDWARE
I'T MAY BE FLASH
IF IS FLASH ,
YOU PROBABLY NEED TO REPLACE THE MOTHERBOARD
OR CALL DELL TO SEE IF THEY CAN FIX IT
Posted on Aug 20, 2008
SOURCE: Dell GX270 won't boot up with solid amber light on Power button
Check motherboard for bad capacitors. I had the same problem and when i had bad capacitors replaced everything is ok.
Posted on Feb 20, 2009
  • 20 Answers
SOURCE: power button on dell dimension 8200 is solid amber
hi this looks like the hdd is not powering up...take the cover of the tower and disconnect the hdd power and see if the motherboard fires up on its owen......unplug the power to the motherboard and wait 5 mins plug it back in see what happens.......on the motherboard were you plug in the hdd led cables and power cable and the led cables and fined the one that has the pwr on it plug it in on its owen see if that helps you
Posted on Nov 12, 2010
Testimonial: "This helped Thanks"
shademand
  • 114 Answers
SOURCE: Dell Precision T3500 Press
Try running diagnostic test press the power and the windows key at the same time and it will run in diagnostic mode and hopefully that will reveal the trouble. Also, you may wish to try reseating the memory.
Posted on Sep 06, 2011
System on. BIOS not execution. This is the transition state to POST states.
It might be the hardware issue. Please contact the local tech support to check your computer for hardware failure.
Apr 13, 2017 | The Computers & Internet
How do I reset the anti theft system on my Suzuki XL7? A new battery was installed and messed my system up
which one.
radio antitheft
car doors. (alarms) Content Theft Deterrent (CTD)
or immobilizer.
say what messed up means.?
the CDC system must be armed with the fob.
is that failing? I can not arm the system or it will not disarm. on my command?
my guess is arming. fails
  1. Turn OFF the ignition.
  2. Exit the vehicle.
  3. Important: The system is not armed if the doors are locked manually. The keyless entry transmitter or the door lock switch must be used to arm the CTD system.
  4. With a vehicle door open, lock the doors by pressing the LOCK button on the keyless entry transmitter or by pressing the LOCK button on the door lock switch. The system will begin the arm sequence when all doors are closed. The CTD system transition to the arm delay state when the final door is closed. The security indicator will illuminate steady when in the arm delay state.
    If the keyless entry transmitter LOCK button is pressed after the vehicle doors have been closed, the system will transition directly to the arm delay state with the indicator on steady.
  5. The system will arm approximately 30 seconds from the time that the system has entered the arm delay state. When the security indicator transitions to flashing slowly, the system is armed.
    Alternately, if the LOCK button on the keyless entry transmitter is pressed a second time, the system will arm immediately, bypassing the 30 second delay.
if this fails try the Second fob.
if the 2nd fob fails, then pull the battery neg lug, for 5 minutes
and put it back.
the full system rules are in the book called, FSM
seen here, read it for who to diagnosis this problem if it continues
just 4 bucks to read all facts
https://suzukipitstopplus.com/Products/10182-2007-xl7-service-manual.aspx
the book also tells you all things messed up with battery pulls.
good luck.
Oct 24, 2014 | 2007 Suzuki XL7 AWD
Resetting hanspree tablet
1. Power off the device. (Make sure to plug in AC power.)
2. Press and hold Volume Up(+) button and Power button at the same time for 5 seconds, and release both buttons to enter system recovery utility.
3. Press Volume button to select " wipe data / factory reset " and press Power button to execute
4. Press Volume button to select " Reboot System Now "and press Power button to execute
Hannspree Customer Service at:888 808 6789 (1-909-992-5025 outside of the US); Mon - Fri: 6am - 6pm PST / PDT.
May 03, 2014 | Hannspree HANNS pad SN10T1
0280:Previous boot incomplete - Default configuration used
Error Code: 0280 Previous boot incomplete - Default configuration used
Message Meanings : Previous POST did not complete successfully. POST loads default values and offers to run Setup. If the failure was caused by incorrect values and they are not corrected, the next boot will likely fail. On system with control of wait states, improper Setup settings can also terminate POST and cause this error on the next boot. Run Setup and verify that wait-state configuration is correct. This error is cleared the next time the system is booted.
What does the above mean ??? If the BIOS does not see a particular device loading ( like Hard Drive ) Try bringing up the Bios setting F-2 and reset to default. Hope this helps
BBBB
If one of the BIOS settings is incorrect or if the system is looking for a particular ggggg
Mar 17, 2014 | Acer Aspire 3100-1405 Notebook
Dell Precision T3500 wont boot 1-3 lights blinking
An amber light means your computer isn't reading the hard drive or CD right, Take it to a professional to get this corrected
Dec 16, 2013 | Dell Precision Computers & Internet
Download drivers
Ummm, no such thing.......
Driver: Small piece of software that allows the Operating System to communicate with a device
BIOS: Basic Input/Output System program
When you press the Power On button, the plastic assembly of the Power On button; presses against the Power On switch located inside it.
The Soft Power On circuit is activated.
This 'excites' the Power Supply, and turns it on.
The first chipset to receive power is the BIOS chipset.
The Basic Input/Output System program is initialized.
BIOS looks to see what devices are installed, does a Ram Memory count, turns the CPU (Processor) on; and hands the computer over to the Operating System.
To perform ANYTHING with BIOS in the respect you are stating, you would be performing a BIOS update.
The BIOS program in modern personal computers, no longer uses BIOS drivers.
"Older types of OS would use the BIOS to access hardware on the computer, but most new versions now access hardware directly through drivers built into the OS."
(OS = Operating System)
http://www.wisegeek.com/what-are-bios-drivers.htm
(Sometimes people just have to see another tech state this, just to make them feel comfortable about it, IMHO)
Know this;
IF, the power goes out when you are performing a BIOS update, your computer turns into an expensive doorstop.
IF, the BIOS update is not compatible with your computer, your computer turns into an expensive doorstop.
IF, you do NOT save the original BIOS program, and the above happens, your computer turns into an expensive doorstop.
Now,..........why is it you wish to fool with your BIOS program?
Post back in a Comment. Or click on Reply at end of this solution, and post.
Regards,
joecoolvette
May 14, 2013 | ASUS Eee Computers & Internet
VW fault codes
Hi there:
Are you scanned the PCM and have fault codes noted? Need description fault codes? Send us the specific fault codes that you find there.
Jul 01, 2012 | Volkswagen Cars & Trucks
How to reset bios password?
Solution
1. Manual
Remove the CMOS battery. Open the bottom of laptop casing. Remove the CMOS battery (about 7 seconds), then reinstall.
2.
From the operating system
Download and install software ACPI Flash BIOS
Note
1. That recommended the computer be connected to AC power via the AC adapter
2. Close all programs before executing
3. Disable; screen saver, scheduled tasks, turn off monitor, turn off the laptop
Dec 23, 2011 | Toshiba Satellite Computers & Internet
How do i chnage bios on dell dimension 4700
start computer with tapping f2 key, you will be directed to bios screen
and there you will get an option to default bios
Aug 11, 2011 | Dell Dimension 4700 PC Desktop
Dell Precision T3500 Computer Workstation (Intel Xeon W3503 160GB1GB) (BW1S13604) PC Desktop Logo
2,606 people viewed this question
Alun Cox
