Question about Jensen XA4100 Car Audio Amplifier
Jensen XA4150 car audio amp - Jensen XA4100 Car Audio Amplifier
How many watts RMS are?
Hello melesk82,
The Jensen XA4150 is a 4-channel amp that outputs 75 watts times 4 channels into a 4 ohm impedance.
Hope this helps.
Oct 03, 2009 | Jensen XA4150 Car Audio Amplifier
Amp cuts out
probably a loose ground or power wire in the inside of the amp
Mar 27, 2009 | Jensen XA4150 Car Audio Amplifier
Amp wont work
open the amp and look for a loose pwer or ground wire
Missing Input plug
i wouldnt use that generic if i were you. i would go out and get a high low capacitor and hook it up behind ur head unit. then u can run ur rcas back to youre amp asnd turn on ur hpf. and ull get all highs and no lows
Apr 09, 2008 | Jensen XA4150 Car Audio Amplifier
MTXThunder 4501
go to this page:
http://www.fixya.com/support/
p236752-jensen_xa4150_car_audio_amplifier/
manual-19203/page-7
Feb 04, 2008 | Jensen XA4150 Car Audio Amplifier
Problems with amp...
if you have some idea about installation procedure it wont be a big deal to fix it by yourself
Dec 30, 2007 | Jensen XA4150 Car Audio Amplifier
I have a jensen ka5 4channel amp
What were the events leading upto this problem?
Where you installing it?
Was it working fine for a long time prior?
Dec 15, 2007 | Jensen XA4150 Car Audio Amplifier
Peavey Bass amp 115
HI Subicbay,
ADjust your Gain setting to limit just enough so the amp does not go into Protect mode. Turn your Gain all the way down, then crank up the bass from your system. GRadually turn up the gain until you trip on protect. Turn the gain back a notch and your set for no more protect.
Oct 27, 2007 | Jensen XA4150 Car Audio Amplifier
Speakers
Hi Trim God,
I do not reccommend that you push the Pioneer speakers over 100 watts.  The jenson will already drown the car with bass through your pioneers so much you will want to turn off the bass boost when playing some low bass hip hop songs. It changes from one venue of song to another, so I just keep the jenson bass boost off and use my head unit to adjsut the sound to fit my listening prefences. I am telling you man, you will be blown away .  Hook up the pioneers straight to the Channels,. do not bridge.  I put Subs in my truck though.  I used the Pass output to send the audio to me Jenson 2 Channel 600W amp. I drive one 10 inch enclosed JBL Class A/B Sub. I bridged the output of the 600 W amp to the 10 inch sub  in my Z28.  The pioneers never get drowned out.  I did smoke my 2 channel Amp one time. and also took out a MTD 10inch sub. I am talk shooting flames and smoked the whole car up. I think if you bride the XA4150 to the pioneers, you will have the flaming smoke problem in no time.
Oct 02, 2007 | Jensen XA4150 Car Audio Amplifier
Jensen XA4100 Car Audio Amplifier Logo
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
