Question about Hoover Nextra HNF 3167 Top Load Washer
Where is the fuse located of a hoover hnwf 6167
Hoover Nextra HNWF 3135 door will not lock
1) test the switch door, you do not have error code.
see the video, and replace for defective switch, or loose wires or broken, or burn.
God bless you
Jun 28, 2012 | Hoover Nextra HNWF 3135 Front Load...
Water will not drain
Check the filter located behind the kick plate at bottom front of machine.
Thanks for using Fixya.
Feb 10, 2009 | Hoover Nextra 160 HNWF 3137 Front Load...
Hoover Nextra HNWF 3137
this is a condenser washer dryer so water should evaporate to condenser then empty!
Oct 31, 2007 | Hoover Nextra 160 HNWF 3137 Front Load...
Hoover nextra 5+5 washer dryer HNWF 3135 heating broken
it is seperate heaters for wash and dry and unlikely to be connected with blocked filter tho you should check filter regularly. take top off. on manifold running across top you will see stats. one of these at least is resettable by presssing a small knob in middle and if it has gone you will hear a slight click. then check dryer manifole for build up of lint as pooir air flow can cause stat to pop. for wash heating, start by checking continuity of the wash heater located at the bottom of the tub
Nov 04, 2006 | Hoover Nextra HNWF 3135 Front Load...
Hoover Nextra HNF 3167 Top Load Washer Logo
29 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
