Question about Garden
Carberator on Husqvarna lawn mower leaks gas - Garden
SOURCE: I have a Husqvarna 5521CHV lawn mower. it stars
I don't have a solution but have the same problem. When choke opens the engine shuts down.
Posted on May 31, 2010
hunter19_46m
  • 7482 Answers
SOURCE: my lawn mowers carburator overflow and leak gas
If the mower/weedeater is over a year old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Oct 12, 2010
SOURCE: husqvarna 7021 kohler 173cc looks like its leaking
The carburetor probably needs cleaning -- the float is sticking.
Charlie
Posted on Jan 07, 2011
SOURCE: lawn mower husqvarna problem
I have an XT721F self-propelled, auto choke Husqvarna mower. The first time I used it this season it ran for a short time and then just quit on me. I have since emptied out all of the gas and have replaced it with high octane 91, and have also added Seafoam to clean out any other issues. I mowed two weeks ago with no problems and went to mow again today and only made it through 2/3 of my back yard and the mower stalled out on me again. What's going on?
Posted on Jun 28, 2011
hunter19_46m
  • 7482 Answers
SOURCE: I have a Kohler courage
Hi
Sounds like you have dirt/debris in your caburetor inlet fuel needle valve, this will cause the float needle valve to stick open and allow fuel to run out of the carburetor unchecked untill you empty the fuel tank.
Sometimes you can tap on the carburetor lightly with a hammer and dislodge the dirt/debris from the needle valve.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one.
Make sure you are using fresh fuel.
If the mower is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me
Posted on Aug 23, 2011
What are the steps to removing gas tank from Husqvarna 48 riding lawn mower?
Before you do that check the breather hole in the gas tank cap - that's the most common problem. Leaking is probably a faulty pipe, especially if you've disconnected them. Don't rely on push fit only - use hose clips.
Apr 30, 2015 | Husqvarna Garden
Lawn mower is smoking white
to much gas check to see if chock is off or replace bad fuel siliniod rebuild carberator
Aug 27, 2014 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
New husqvarna riding mower burns my foot when i press the gas petal
do you have a leak on the exhaust letting exhaust out in the wrong place?
Aug 09, 2012 | Husqvarna YTH2454 54in 25 HP Lawn Tractor
Lawn mower will not start after running out of gas.
are you getting spark?was the gas you put in newer than 30 days old?
Jul 22, 2012 | Poulan Garden
Model 42a707 engine spitting gas out of carberator
Fuel needle leaking in the carb, remove the float bowl, check the float is moving freely, clean away any dirt, if no better replace the inlet needle.
May 06, 2012 | Yard Machines Garden
Leaking gas through air filter
If the GCV engine is tilted with the carb. down, it will leak gas. If it is leaking gas setting level, this indicates the float/needle is not shutting the gas off properly. Would need to disassemble carb. and check the float and probably replace the inlet needle. The float hinge may be "varnished" and not allowing the float to "move" and shut off the fuel coming into the carburetor. Hope this helps in some way.
Mar 02, 2011 | Husqvarna 21" Lawn Mower with Honda GCV160...
MOWER ONLY RUN WHEN U PUT GAS IN CAB WANT START
Ok, so your not getting gas to carberator, or thru the carberator. Disconnect gas line from carberator, if gas is present thru fuel line, you have a carberator problem. Your rather meger with your mower information so this is all i can tell you. Wish i could be of more help.
May 29, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I can not keep my mower running. It ran great before winter, now it acts like it is going to run.. but dies. I have new gas in it, new oil, and changed the spark plug. What else could it be? craftsman...
Hi, I would suggest taking the main jet out of the carberator and cleaning it with carb cleaner. If you did'nt drain the gas out of it before winter, the gas has gotten old and has plugged up your main jet in the carberator. It could also be that the needle has got **** on it and is stuck, I'd clean that also. Your problem is all in the carberator, and old stale gas sitting in it all winter is the reason.
May 08, 2010 | Craftsman 675 Torque 190cc 21" RearBag...
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
