Question about Dell 110v Fuser for B2360d/ B2360dn/ B3460dn/ B3465dn/ B3465dnf Laser Printers
Why wont my printer turn on? Dell 2360dn.
I have moved my printer to install it on another pc and it wont come on. There is green light on the inside panel that is lit I dont think its in night time mode because i hold this in and still nothing happens
mellomania
  • 121 Answers
SOURCE: Dell Latitude C640 Laptop
get to the main board of ur system there is a jumper near the battery .
change its position while power is off and get it back to its previous position. this way u will reset cmos to default.
if the computer starts hit delete to enter setup and load system defaults.save changes then exit.
ps: defected processor could be the cause
Posted on Nov 14, 2007
Pyrhyc
  • 2028 Answers
SOURCE: Dell C400 Laptop Battery not charging
Go into the battery properties and check if the battery is charging. If it says it is, then test it, use the battery to see if it really is charging, they will sometimes give a false reading. If it's not charging, then check the power supply with an ohm meter for the proper output. If this all checks good, but the battery isn't charging, then I'm afraid you have a failed power management system on the motherboard. The power management system controls the charging along with other power related aspects of the machine. If the power management system has failed, then unfortunately, you will have to replace the motherboard in order to fix it.
Posted on Aug 12, 2008
SOURCE: Dell Dimension 5150 PC
thanks for all the advice, after de bending the usb contacts and cleaning the split rum and coke from the graphic card with nail varnish remover ( dont now how it found its way in ) working fine!!
Posted on Sep 16, 2008
  • 8 Answers
SOURCE: dell dimension 8100 diagnostic lights
Green Green Green amber is a start of "POV" whatever this stands for. Dells description is "System activity subsequent to video initalization" I would start with video card replacement,
Posted on Jan 09, 2009
byteguy
  • 2229 Answers
SOURCE: Four beeps wont turn on, Dell 4700
The four beeps usually indicate a memory problem and it won't pass it's Power On Self Test. Try reseating the memory sticks, or, if you have two of them, take one out and try to start the machine and then swap them.
If this doesn't solve the problem, you most likely have a bad motherboard.
Posted on Feb 01, 2009
Dell 2360dn printer manual paper feed settings
I know this sound hokey but it just worked on one new out of the box.
1 - Take the paper tray out.
2 - Flip the printer up on it's back.
3 - Pull the forms pickup roller out and remove white bands.
4 - Turn the bands inside out and replace them on the rollers.
Aug 18, 2014 | Dell B2360dn
My dell pc model dcslf will not power on green light on back is on and orange light inside is on
you could try opening the case after unplugging the power from the wall, then disconnect power supply from the Motherboard. then hold the pc power button in until the green back light and orange light go out. then reconnect power supply to motherboard. Plug the power back in to the wall and see if the pc turns on. Hope this helps
Apr 01, 2014 | Dell Computers & Internet
Dimension 3100 wont turns no power button light there is also an green light on motherboard cpu and power suplly fans working but wont bot up
Contact technical assistance.They will most likely ask you to send it back to repair.
This chart is where I got my conclusion.
Power Light
Problem Description
Suggested Resolution
Solid green
Power is on, and the computer is operating normally. On the desktop computer, a solid green light indicates a network connection.
No corrective action is required.
Blinking green
The computer is in the suspended state (Microsoft® Windows® 2000 and Windows XP).
Press the power button, move the mouse, or press a key on the keyboard to wake the computer.
Blinks green several times and then turns off
A configuration error exists.
Check the diagnostic lights to see if the specific problem is identified.
Solid yellow
The Dell Diagnostics is running a test, or a device on the system board may be faulty or incorrectly installed.
If the Dell Diagnostics is running, allow the testing to complete.
If the computer does not boot, contact Dell for technical assistance.
Blinking yellow
A power supply or system board failure has occurred.
Solid green and a beep code during POST
A problem was detected while the BIOS was executing.
See "Beep Codes" for instructions on diagnosing the beep code. Also, check the diagnostic lights to see if the specific problem is identified.
Solid green power light and no beep code and no video during POST
The monitor or the graphics card may be faulty or incorrectly installed.
Check the diagnostic lights to see if the specific problem is identified. See "Video and Monitor Problems" in your Owner's Manual.
Solid green power light and no beep code but the computer locks up during POST
An integrated system board device may be faulty.
Check the diagnostic lights to see if the specific problem is identified. If the problem is not identified, contact Dell for technical assistance.
Mar 06, 2011 | Dell Dimension 3100 PC Desktop
Computer wont turn on but there is a green light on inside
Dead power supply man, just had a computer in the shop that was doing the same thing. Unless its beeping at you then probably memory
Feb 25, 2010 | Dell Dimension XPS 400 PC Desktop
Dell computer monitor wont come on when I turn
When you turn on most dell monitors they come on with a yellow light, then turn green when the monitor and video source synch. If your light is not turning from yellow to green, your monitor is either dead or not getting a signal from the video source it's plugged into. Verify in your BIOS settings that you have selected to output video through an installed card and not from the motherboard source. If the BIOS settings are correct, your monitor has died. If the light is turning green after you turn the computer on, press the menu button on the monitor and adjust the brightness/contrast until you have a picture. If you don't see anything when the menu button is pressed, then again your monitor is likely dead.
Jan 04, 2010 | Computers & Internet
Dell d610 wont turn on ac adapter light is green
There is a small IC that Dell solders into their power supply as well as their batteries. When this parts fails you will have the type of problem you are having now. If you do a search on the web you will find a large number o sites that discuss this. Unfortunately there is no fix other than replacing your power supply. I had to do the same thing myself for the Dell laptop I use.
Nov 02, 2009 | Dell Latitude D610 Notebook
Kodak esp 5 printer wont turn on
Make sure that you have green light on the power cable, which goes to the back of the printer. if it is not lit up,the power cord is bad.If you have light there and the printer is still not turning on,make sure that the power cable is inserted properly to the back of the printer. is still issue is not resolved, call kodak @ 1800 421 6699 and they will replace the printer for you free of cost.
Mar 23, 2009 | Kodak ESP 5 Printer
XPS 200 power problem
Its is probably in hibernation mode. Hold the power button in for about five seconds or more until the lights go out and the restart.
May 09, 2008 | Dell XPS 200 PC Desktop
Dell 110v Fuser for B2360d/ B2360dn/ B3460dn/ B3465dn/ B3465dnf Laser Printers Logo
89 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
