Question about Vehicle Parts & Accessories
Why did my cruise control stopped working for me, ?
    Sergeant:
    Champion:
  • 248 Answers
Check the fuses
Posted on Sep 11, 2014
Cruise control not working
cruise controls are dependent on the following sensors all working together
brake sensor
clutch sensor
auto--vehicle speed sensor
rpm's sensor
fuse for the cruise control
cruise control switch either or all not working will stop the cruise control from engaging
road speed at which you can engage the cruise control has to be above a reset speed before it will cut in and work
Sep 05, 2015 | 2009 Chevrolet Chevrolet Equinox LS
2003 oldsmobile alero v6 -- cruise control stopped working...The cruise on/of button lights up, the green light cruise indicator comes on in the dash panel, but cruise control does not engage when CST SET...
Try checking the small switch at the top of the brake pedal. There may be two one for brake lights and one for the cruise control. To ascertain what is what, pull one wire off and see if brake lights work. If not, then the other switch controls the cruise control disconnect and engage..I you have a DC test light check to see if power is on on both side of the switch with brake pedal up. If so, depress pedal and check power on the other side there should be none, if there is the switch is defective.
Aug 02, 2017 | Cars & Trucks
Crusie control does not work on 2011 gmc sierra 1500 and I've already replaced the switch?
If the switch is replaced,then it can be wiring issue or faulty cruise control board.But as the switch is replaced,get the voltage at the switch tested to confirm the switch is actually receiving voltage.If no voltage received at switch power supply wire then ,apply external 12 volt power to the cruise control switch wire and then see if cruise control comes ON.If yes,then you know wiring is issue.
On this case, to troubleshoot this problem, there are solved help links. Click the link directly and refer the details to solve this problem yourself, with help of diagrams: ------
Ford ranger cruise control not working? http://technoanswers.blogspot.in/2012/02/ford-ranger-cruise-control-not-working.html
Horn and Cruise control quit working?
http://howtobyme.blogspot.com/2011/11/horn-and-cruise-control-quit-working.html
Horn and cruise control not working on Plymouth Grand Voyager?
http://howtobyme.blogspot.com/2011/11/horn-and-cruise-control-not-working-on.html
Horn and Cruise control quit working on 2003 Jaguar S-Type?
http://howtobyme.blogspot.com/2011/11/horn-and-cruise-control-quit-working-on.html
Cruise Control stops working, Excessive cranks to start the engine and RPM goes max 2500
http://whoisbyme.blogspot.in/2012/07/cruise-control-stops-workingexcessive.html
Cruise control stop working on 1994 Ford ranger?
http://technoanswers.blogspot.in/2012/02/cruise-control-stop-working-on-1994.html
Cruise control not working?
http://schematicsdiagram.blogspot.com/2011/12/cruise-control-not-working.html
1996 Ford Explorer: Cruise Control Wiring Diagram?
http://schematicsdiagram.blogspot.in/2012/06/1996-ford-explorer-cruise-control.html
These will help.
Thanks.
Nov 28, 2012 | GMC Cars & Trucks
On these case,to troubleshoot these problem,there are solved help links.Click the link directly and refer the details to solve these problem yourself,with help of diagrams:------
----------- Horn and Cruise control quit working?
Horn and Cruise control quit working on 2003 Jaguar S-Type? http://howtobyme.blogspot.com/2011/11/horn-and-cruise-control-quit-working-on.html
Cruise Control stops working, Excessive cranks to start the engine and RPM goes max 2500 http://whoisbyme.blogspot.in/2012/07/cruise-control-stops-workingexcessive.html
Cruise control stop working on 1994 Ford ranger? http://technoanswers.blogspot.in/2012/02/cruise-control-stop-working-on-1994.html
Cruise control not working? http://schematicsdiagram.blogspot.com/2011/12/cruise-control-not-working.html
These will help.
Thanks.
Nov 22, 2012 | 2003 Ford Expedition
How to fix cruise control
Cruise controls can cease to engage if the clutch or brake light cruise switch are out of adjustment. If this happens, try placing you foot under the clutch pedal (if equipped) and lift up on it (toward you) and hold it while engaging the cruise. If it now works, it will likely cut out when you remove your foot from under the pedal. Check the brake pedal in an identical fashion. Adjusting the switch at the pedals can often solve he problem. Some vehicles (Honda, Acura, Ford, to name a few) have a plastic insert that mounts in the pedal arm which presses against the switch. These can become brittle and fracture into pieces. My Acura has little pieces of blue plastic on the floorboard around the brake pedal one afternoon and I noticed the cruise didn't work. It was the pieces of the insert that had come to pieces preventing the cruise from coming on. I replaced the insert and no more problem with the cruise.
Mar 10, 2012 | 2003 GMC Sierra 2500HD
Cruise control don't work
To troubleshoot your problem,there are few help links,provided below.Click the link directly and follow the procedure to confirm the fault.So as per that you can continue further in repairing this issue of cruise control not working.
The direct help links are as follows :-----cruise control not working?
-----------Horn and Cruise control quit working?
Horn and cruise control not working on car?
Horn and Cruise control quit working suddenly?
Cruise control stop working ? http://technoanswers.blogspot.in/2012/02/cruise-control-stop-working-on-1994.html
ford ranger cruise control not working? http://technoanswers.blogspot.in/2012/02/2005-ford-ranger-cruise-control-not.html
My Cruise control not working? http://schematicsdiagram.blogspot.com/2011/12/cruise-control-not-working.html
This troubleshooting help links will help you to confirm the problem.
Thanks.
Feb 13, 2012 | Chevrolet 3500 Cars & Trucks
Cruise control stopped working. What do I need to do to troubleshoot it correctly?
first of all did you check the fuse! if ok check the cable from throttle body to speed control or cruise. on a few ford products before 2005 have a recall for the cruise control. call ford dealership to find out.
Jun 30, 2010 | 2001 Ford Escort ZX2
I own a 2005 GMC Canyon Five CYL and the cruise control stopped working last niight. You push the button and no cruise. I checked the fuse and it is ok I exchanged with another 10AMP and no change still...
Start with the simple and check the fuses and the Stop lamp switch. Check your brake lights, if they're not working, the cruise won't work either. If they're not working, check the fuse for them, if the fuse is fine, then take it into the dealer, there's been a recall issued on the brake switch, so it should get fixed for free.
Cruise Control Disengaged
The powertrain control module (PCM) disengages the cruise control operation based on the signals from the following switches:
* The stop lamp switch
* The TCC brake/cruise release switch
* The clutch release switch, if equipped
* The cruise control On/Off switch
The TCC brake/cruise release switch and the stop lamp switch are mounted on the brake pedal bracket. When the brake pedal is applied, the normally closed TCC brake/cruise release switch opens and the normally open stop lamp switch closes. The PCM detects a low signal voltage on the TCC brake/cruise release switch signal circuit and a high signal voltage on the stop lamp switch signal circuit. When the clutch pedal is applied, the normally closed clutch release switch opens and the PCM detects zero voltage on the CCP switch signal circuit. The vehicle speed stored in the memory of the PCM will be erased when the cruise control On/Off button is turned OFF, or the ignition switch is turned OFF.
The Cruise Control System will disengage when the PCM detects that a driver override function has been active for approximately 60 seconds .
When the Cruise Control System is disengaged, the PCM sends a class 2 message to the instrument panel cluster (IPC) in order to deactivate the cruise control indicator.
Cruise Control Inhibited
The powertrain control module (PCM) inhibits the cruise control operation when any of the following conditions exist:
* A cruise control related DTC has been set.
* The vehicle speed is less than 40.2 km/h (25 mph) .
* The vehicle is in PARK, REVERSE, NEUTRAL, or 1st gear.
* The engine RPM is too low.
* The engine RPM is too high, with fuel cut off.
* The vehicle speed is too high, with fuel cut off.
* The system voltage is not between 9 volts and 16 volts .
* The Traction Control System (TCS) is active for more than 2 seconds .
Thank you for using Fixya and start with replacing the stop lamp switch. Even though the brake light work, it;s been known for that switch to cause your issue. that's way there was a recall for it.
Apr 01, 2010 | 2005 GMC Canyon
Check the switch, located on the brake pedel the stop light switch and the cruise control switch are on the brake pedel towards firewall. The cruise control switch is plastic.
Mar 25, 2010 | 2001 Ford F350 Super Duty SuperCab
2000 windstsar sel cruise control stopped working
Check to see if your brake lights are staying on.
I thought my cruise control stopped working too, but realized that it would not work because the brake light control on the brake pedal was stuck.
I changed the $40 control and the cruise control works.
Jul 23, 2009 | 2000 Ford Windstar
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
