Question about Maytag MSD2758G Side by Side Refrigerator
Ice freezing up on bottom of freezer and water puddles in front
Maytag model # MSD2758DR
  • Maytag Master
  • 4,655 Answers
Two possibilities, ice maker leaking or the defrost drain is blocked with ice or another object. Unplug the freezer and remove the rear panel in back of freezer. At bottom of the evaporator coil is a tray that catches the defrost condensate and sends it to the pan beneath your refrigerator to be be heated by the compressor and fan heat produced from the condenser. The moisture is then returned to the air inside your home. If the drain is blocked with ice or anything between the freezer and the pan below, the condensate tray will overflow will end up inside your freezer or fresh food compartment. Questions? I will be here to help you, Let me know, Sea Breeze
Posted on Jun 23, 2009
  • 1 more comment
  • John Tripp
    John Tripp Jun 23, 2009
    If I am able to help you in any way please let me know. If you have questions and need answers, let me know. If these solutions help you, please rate me, Thank You, Sea Breeze
  • Jimbo213 Jul 24, 2013
    John - will you take a crack at answering my question please
    Add a Commenthttp://www.fixya.com/support/t18987797-water_floor_french_door_refrigerator
My condensor coil totaly freezes up on my maytag msd2758dr refrigerator/freezer. Once a month items in the freezer start to get soft and fridge doesnt cool efficiently. Defrost drain is not plugged. could it be my defrost board malfunctioning? any help would be great. Thanks Anthony
Posted on Sep 08, 2010
Ice freezing up on bottom of freezer and water MFI2269VEM3
Sounds like your drain in the freezer is clogged. Try a flexible item like a guitar string to clear it.
BUT also make sure that the fan is working and blowing the humidity from the freezer to the fresh food section.
Jan 04, 2012 | Maytag Refrigerators
MZD2766 GE - A puddle of ice forms at the bottom of the freezer
Sounds like the defrost drain is cloged. There is a hole at the bottom of the freezer behind the back wall. if this is cloged then the water that is suppost to drain there will overflow and freez.
Jul 04, 2010 | Maytag MZD2766GES Side by Side...
I have a maytag bottom freezer refrigerator model#mbf1956keq
apparently its the way the maytag defrosts. I have had this issue since I bought it. FIrst of all, you dont have to go through the whole defrosting process with water on the floor and removing your freezer contents. Simply take a butter knife and from the front corner, slide it under the edge of the ice and the whole sheet can be slid out intact right under the freezer door. I think it had alot to dowith having the humidity switch on, because when it isn't like in the summer when the AC is running, the amount of ice is not that bad.
Apr 04, 2010 | Maytag 21.9 Cu. Ft. Bottom-Mount...
Ice accumulation on the bottom of the freezer
Your drain line is clogged, that is located behind the white wall inside of the freezer. The water comes from defrost cycle, that happens every 8-12 hours. You need to defrost it and snake it.
Maytag refrigerator repair in Orange County, CA
refrigerator repair in orange county, ca
appliance repair orange county, ca
Feb 06, 2010 | Maytag MZD2766GES Side by Side...
About 1/4 inch of ice forming in bottom of freezer about every 3 weeks. small puddles of water form under the front of frig when this freezes
That is a typical defrost drain blockage symptom unless the icemaker is over flowing, I will return with a link and more information. Sea Breeze
Jan 18, 2010 | Maytag 25.6 cu. ft. Wide-By-Side...
Water puddling in bottom of freezer which freezes
Tool needed: Screw drive with the insert tips can be used to remove screws use the end of the screw driver with out a philips bit or flat tip inserted. Remove frozen food to camping coolers igloo ice chests or coleman ice chests or a freezer in your home . Remove all racks and baskets to expose movable panels at the inside back of the freezer compartment.
Notice the 1/4" hex nuts remove the screws holding the panels at the back wall. Clear built up ice carefully. You now can take out the panels and expose the fan and cooling cool that creates the cold temperature on the freezer side.
Near the bottom is an aluminum U shaped pan with a shallow funnel indentation at the bottom. Clear ice from the funnel pan and inside bottom carefully. Sharp objects break ice nicely and can pierce the interior surfaces . Look under the cooling coil and at the back wall is a screw holding this soft metal catch pan in place. Remove the screw and carefully tip and slid out the catch pan tray. You now have access to the drain hole that is frozen closed or clogged. Place a large towel in the bottom of the freezer area to catch water. Pour hot tap water a half cup at a time into the drain area. Do not use boiling water the plastic inside a refrigerator or freezer can not tolerate high temperature. I have melted a freezer compartment in a GE with a hair dryer. Remove the water with a clean reag and add more warm or hot water repeat until the drain allows water to flow. stop adding water or the evaporation pan under the refrigerator will over flow.
Check the refrigerator about once a year for the freezeup problem or keep an eye on the bottom of the freezer looking for the build up of water frozen on the inside floor. The other solution get a new refrigerator.
Dec 01, 2008 | Maytag MSD2434GE Side by Side Refrigerator
Water puddling in bottom of freezer and freezing
the drain in the back of the freezer is probably full of ice. you need to pull out panel and use heat from a blow dryer to unplug the drain. then take a small gauge copper wire long enough to extend into the drain a couple of inches and loop it around the black heating element then when it goes yhrough defrost it should keep this from reaccuring
Ice buildup at bottom of freezer and small puddle.
Freezer has a drain in the back under the cooling coil. Melt Ice from drain area with a hair dryer, check drain and clear, under bottom in back behind a removable panel you will find the drain exit from the freezer going into the drain pan. This drain line has a loop for air seal, make sure it is cleared.
Aug 08, 2008 | Maytag MSD2732GR Side by Side Refrigerator
Bottom of freezer has water dripping into it
A bad freezer door seal causes condensation that freezes at the bottom of the unit. I realize you said the drip pan was full of ice, but if the drain is clogged, that will happen. If that unit has the pan at the very bottom, condensation can also contribute to this.
Jun 17, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Water leaking underneath refrigerator/water freezing in bottom of freezer
I'm dealing with the same problem right now with the same refrigerator. The cold water tank (for the front dispenser) has a hole in it that leaks every time someone dispenses water from the front door. You will find the water tank behind the top slide-out drawer in the fridge. The leaked water flows down one of the water tubes through a hole in the bottom of the fridge and onto the floor. I'll bet you have the same problem. Good Luck.
Jun 14, 2008 | Maytag MSD2758G Side by Side Refrigerator
Maytag MSD2758G Side by Side Refrigerator Logo
557 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
