Question about Vizio Computers & Internet
Vizio27ca-ao hdmi to sending out to television set
Vizio E320-A0 ... no signal
It would appear your signal board was damaged so it will require replacement. . If you purchased s extended warranty on the set it may be covered under the accident provision. If not you can go to Vizios site with the model no and locate the replacement board . If your capable you can order it and change it your self or contact a local servicer to assist or replace the set which may be more economical
Mar 06, 2014 | Vizio E320-Ao 32 Class Led Hdtv - 720P,...
Do you have to have a HD cable to hook up a PS3?
There are two ways you can connect your PS3 to your VIzio. First, you can do it with HDMI cable. Here the HDMI output from PS3 goes to HDMI input of the TV. Second, you can do it with the AV multi out cable.Here the multi output from the PS goes to AV input of the TV. After doing this please select the source accordingly. Good luck.
Dec 30, 2013 | Vizio E320-Ao 32 Class Led Hdtv - 720P,...
My HDMI port seems not to be getting the conncection just had the cable here and they had to hook it up through componet to suggest anything besides taking it to a repair shop or buying a new tv?
did you program source to transmit signal through the HDMI
a lot of sources need to be set to send signal through HDMI and also sending audio on lots of sources need to be specifically set also
good luck!!
Apr 15, 2011 | Vizio L32 32 in. LCD HDTV
How do I set my tv to 1080
You don't set your tv to 1080. You set whatever you are connecting to your television to 1080. Let's say it is a cable box or blu ray player. You would need to be connecting it to your television with an hdmi or component cable. Connect it only once to the television with an hdmi or component cable. This may sound ridiculous but there are people that have their devices connected to the television three times with three different types of cables (hdmi, component, composite) instead of just one. Make sure the television is on the proper input. Adjust the video output settings to reflect 1080 i or p if possible resolution.
Apr 07, 2011 | Polaroid 3211TLXB 32 in. LCD Television
I hooked wii up but I cant hear the sound. Help?
Using HDMI? The HDMI SETUP will tell the HDMI to receive the digital audio if the HDMI source (WII) is also setup to send the audio through the HDMI cable, so you need to check the HDMI sound setup at the TV and at the Wii.
Or you can use analog audio RCA jacks, but you still need to set up the TV and the Wii to send audio through analog ports.
Please leave rating if it helps.
Jan 13, 2011 | Dynex DX-L42-10A 42 in. LCD TV
I get no picture when I connect the set box HDMI cable to the TV
The default connection is usually HDMI 1. The possibility of the cable being defective, or the box sending a signal out need to be determined.
Set up your connections, then turn on your TV.
Try using different HDMI hookups.
Bring a different video source to get the TV to display.
See if you can bring up the TV menu to select an input to connect to.
Oct 12, 2010 | Samsung LN-T4665F 46 in. LCD Television
LC-26DA5U 26 in. HDTV-Ready LCD Television: i connect a hdmi cable 2 my hd cable box - the pic...
The cable box needs to be set to send different signals when using hd tv and standard tv. Usually a good setting would be 720p in hd and 480p in standard. The tv is working fine it is the cable box sending the signal. If you have another hdmi source such as a dvd player you may hook that up to show the tv is working just fine.
May 07, 2010 | Sharp LC-26DA5U 26 in. HD-Ready LCD...
PS3 doesnt work w/ hdmi
Have you tried reseting your option settings for video output? It could be set up for standard definition. There for not sending a 1080 signal through the HDMI, instead sending a different signal for SCART. There is a master way to do this as well. Think holding the off switch and turning of the master power button at the same time does it (do a search).
Jun 26, 2009 | Sylvania LC195SL9 19 in. LCD TV
What should i do,i have no volume?
i've narrowed it down to the cable box or the hdmi cable.i'll let you know.
Apr 06, 2009 | Samsung LNT3242H Television
Cant find HDMI input on tv, trying to hook up ps3
hdmi output is" INPUT 1" on the menu ALSO hold down on the ps3 power button for 6 seconds and it should come on. the ps 3 has a thing were you have to set it to send out in hdmi or comp.
Mar 12, 2009 | Hitachi 51F59 51" HDTV Projection...
Computers & Internet Logo
14 people viewed this question
Top Vizio Computers & Internet Experts
justwinwin
Are you a Vizio Computer and Internet Expert? Answer questions, earn points and help others
