Question about Black & Decker Black and Decker & Grass Hog Electric Trimmer
How to restring remington rm 115st ? - Black & Decker Black and Decker & Grass Hog Electric Trimmer
Restring hills rotary clothes line
To restring the Hills Everyday 37 rotary clothesline FD88010 you are going to need a couple of tools which include a small screw driver and a set of cutters to cut the new line cord.
You will also need to order a pack of line, which for this unit would need to be the 70m pack from Hills. Here is a link to the line pack you would need.
https://www.lifestyleclotheslines.com.au/clothesline-spare-parts/hills-70m-polycore-replacement-pack-grey-FD903530
Here is a great video on the process to restring the Hills Everyday 37 rotary clothesline FD88010
If you need to access the Everyday 37 manual you can do so here and download it.
Hills Everyday 37 Rotary Clothesline Owners Manual FD88010
Hills line clips could be something that you may also need in the restring process as these do tend to break on the older models of this unit. Below is a link to the Hills line clips that fit the Hills Everyday 37 FD88010 model.
Hills Rotary Clothesline Line Clip Pack of 6 FD902506
Jul 19, 2014 | Hills Everyday Villa 37 Rotary Hoist...
What chain oil in RM1015P
Hello, The chain lubrication oil is called bar and chain oil. It is specially formulated to cling to the bar and chain to ensure maximum lubrication. You can obtain bar and chain oil at any hardware store or power equipment shop.
Jul 14, 2014 | Remington 10" Model Rm-1015p Electric Pole...
I bought a 14" riminington chain saw (Model RM 1415 A) from Harbor Freight but cannot get a replacement chain. Where can I by one?
You can buy one at PartsBuggy.com. Check the application listing for your model. If it doesn't appear in the list, you can email them and they'll help you identify a replacement chain for your saw.
Nov 29, 2012 | Remington Garden
How to restring a husqvarna 224L
To remove the head to restring, push in the bumper cap/side tabs on the strimmer head, the top should then just pull off exposing the inner spool.
Jul 24, 2012 | Husqvarna Weed Trimmer 224 L 4-stroke Line...
Cannot restring Troy-Bilt weed trimmer
On the directions below tells you how to restring the spool.
If you can not read it you can click on the link below to download the manual.
http://manuals.mtdproducts.com/mtd/GetFile.do?filename=769-04481.pdf
If you have any questions please ask befor you rate.
Good Luck
Jun 27, 2010 | Troy Bilt Tb70ss Gas Trimmer
Plastic cog stripped remington
You provided no model number; you need it to find parts on the breakdown here:
Remington.com
http://shoppingcart.msservicecompany.com/Default.aspx
  • Type "YourModelNumber" into the "Search for your unit by Model:" window, then click search.
  • Click the “YourModelNumber” - Remington Electric Chain Saw "View Model" link.
  • Click “View Owners Manual” or "View Illustrated Parts Diagram" link.
  • Type "YourPartNumber" into the “Search for your parts by Part #:” window, then click search.
If it returns NLA try a part number search here, sometimes they still have the part.
Master Distributors
http://www.masterparts.net/remingtonelectricchainsaw.html
Are you aware RemingtonPower is no longer in production? Often eBay is the only source. If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH Lou
Apr 09, 2010 | Remington Garden
Where does the charger plug in??
Did you recieve a manual with this radio? It usually states where the charger plugs into...
As my experience with other handies like this recalls, it should take the charger in either the mic or ear jack... (provided there are not any other jacks meant for the charger)
Best way is to obtain a manual from the supplier if you want to make 100% shure!
Regards,
Johan
Aug 19, 2009 | Remington RM-75SBC (22 Channels) 2-Way...
Maytag DE 412 won't heat. Looking for a fuse.
No fuse on that old of a model . Probably element bad or thermostat . You can get a restring kit a lot less expensive , but you would have to restring it yourself (not that hard though) or , you can buy the element already strung and all you have to do is transfer the thermostat and install . complete pt # Y303404 ...Restring element pt # Y313538
Jul 19, 2009 | Dryers
Black & Decker Black and Decker & Grass Hog Electric Trimmer  Logo
37 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
