Question about Homelite Mighty Lite Lawn Trimmer
Will a dj7y replace a dj8j champion plug? - Homelite Mighty Lite Lawn Trimmer
What is champion spark plug gap?
Depends on what year and model of engine you put it in.
Aug 28, 2014 | Champion 300129 Spark Plug DJ8J
Need sparkplug gap for McCULLOCH 3200
If you go to NGKsparkplugs.com, go to the tab at the top labeled 'part finder', select chainsaw, select MCCulloch, 3200 series...you get that it is .025 and the plug should be a BPM6F if using a regular NGK plug. Hope this helps...
Oct 01, 2011 | Garden
Proper spark plug
BM6F (Champion) or BM7A (NGK) of DJ8J (Oregon)
May 28, 2011 | McCulloch Garden
I was given a McCulloch Pro Mac 610 w/Electronic Ignition & cushioned power and it looks like a 22" bar. I'd like to know if I can still get a user manual for it. I'd also like to know the gas mix and...
Use 40:1 fuel mix using modern synthetic saw oil and mix it in it's own can. Be sure to shake the can thoroughly just before refueling each time. Check with a home center, hardware store, or saw dealer for the correct plug--set the gap at 0.020". Check the manual dealers on the web for a manual. Hope this helps!
Jun 23, 2010 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
What is the gap for a champion spark plug Part#847 or DJ8J in a IDC Weedeater
0.020" will work for just about any small engine. Good luck!
May 07, 2010 | Saws
Spark plug gap
What plug are you currently using?
if its a DJ7Y gap at 0.025 tapered seat
if its a DJ7J gap at 0.030 tapered seat
if its a CJ8 gap at 0.025 gasket
if its aCJ6Y gap at0.030 gasket
if its a CJ6 gap at 0.030 gasket
these are champion plugs
if you have different cross reference your make
Jul 05, 2009 | Homelite Mighty Lite Lawn Trimmer
I need spark plug gap on a ryan trimmer Model 264
.030 is what i set my ryan trimmer and have had no issues
Jun 14, 2009 | Ryobi Garden
I'm looking for a free downloadable owners manual for a McCulloch gas trimmer, model 1385L, or at least to find out what the spark plug gap should be.
spark plug gap is .025
spark plug recommended for this trimmer is DJ8J
Or RDJ8J if you dont want radio interference or if you do not like champion plugs NGK isMB6F
torqed at 110-120 inlb.
May 05, 2009 | McCulloch 26cc Gas Blower Mcb3208
Homelite Mighty Lite Lawn Trimmer  Logo
130 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
