Question about Tech Solution TS-8000 Cross-Cut Shredder
Can not locate sensor
Where is the sensor guide on my shredder?
It is dead center of where you put the paper in. if you look in the center, you will see the transmitter and the reciever.
Posted on Nov 07, 2007
When turned on shredder runs, dose not stop when items are finished, but must be turned off manually. is there anything I can do to fix this?
stuck ,faulty reader switch or debris is blocking or covering the sensor unplug unit and carefully look and try to clean any paper or debris in shredder
Aug 11, 2016 | Shredder Office Equipment & Supplies
My fellowes ps-70 shredder has a light on and it's not working
If the shredder is the kind that turns on when you insert paper, it may have an optical sensor that is dirty or blocked. Try blowing off the sensor with some canned air. The sensor is usually located in the center of the paper path slot. Also check that the bin is completely closed. Sometimes a tab on the door is bent or broken so that the shredder thinks the door is open. The tab activates a switch which tells the shredder that the door is safely closed. Fellowes has a lot of good tips on their website.
Apr 22, 2014 | Fellowes PS70-2CD Shredder
Is there a sensor for Omnitech shredder OT-NXC18PA? if so where can I locate it?
I have this same shredder and same thing happened to mine just 2 months after warranty is up. I called the company and told the sensor is gone and there is no way to replace. BTW mine runs in reverse but not forward.
Jun 24, 2012 | Tech Solution Office Equipment & Supplies
Model: SH9210PL
sensor is dirty. clean the sensor. it is located approx. 3 inches from left side of paper slot, 1 inch below top.
Jun 06, 2008 | IdentityGuard Cross-Cut Shredder
Shredder
If your unit has a mechanical paper feed sensor located in the center of the paper feed area there may be paper behind it causing switch not to activate. If it is an electronic sensor you probally have a burned out sensor, switch or a bad pc board. You will need to contact manufacturer for info on part replacement.
Mar 13, 2008 | Achiever CCS5000 Shredder
Shredder not working
Though I only work with Fellowes shredders this sounds like a paper feed sensor issue. If your unit has a mechanical paper feed sensor you can try to jiggle it in and out to see if any paper may have become jammed behind switch. If the unit has an electronic sensor it may simply need to be cleaned with a Qtip dipped in rubbing alchohol. Sensor is usually located in the center of the paper feed opening.
If neither of these help your paper feed sensor or your pc1.gif board has gone bad and you will have to contact your manufacturer for further parts availability.
Feb 07, 2008 | Techko SH1524CP Shredder
Have to turn off manually
Either there is a piece of paper that is jammed where the paper in sensor is located, or there is paper fibers covering the paper in sensor, or the paper in sensor is defective.
The paper in sensor is usually located in the center of the shredder where you place your paper. Once you locate your sensor, you can try blowing it out with a can of air that is used to clean your keyboard out.
Since the opening for the paper or the Thoat width is 9", the switch should be close to 4.5" towards the center.
To try to help you located the sensor, take a piece of 8 1/2 " x 11 paper and fold it in 1/2 Long ways. This will place a crease in the middle of the paper. With the power off, or unplugged, place the paper in the shredder and look around where the middle of the paper (crease) lines up in the shredder. You might need a flashlight to help you located it. It will either look like a slot, or a little black lever.
Hopefully you will be able to blow the sensor out and clean it.
Good luck.
Jan 29, 2008 | Fellowes Powershred P-45C Shredder
Fellowes crosscut shredder does not shut off
I got an email from Fellowes technical support suggesting I use alcohol and a cotton swab on the sensors after unplugging it. That fixed my problem.
Nov 16, 2007 | Fellowes DM8C Cross-Cut Shredder
Ts8000
Good luck.
Oct 24, 2007 | Tech Solution TS-4500 Shredder
Tech Solution TS-8000 Cross-Cut Shredder Logo
79 people viewed this question
Top Tech Solution Office Equipment & Supplies Experts
Michael Galve
Michael Galve
quennie732
Are you a Tech Solution Office Equipment and Supply Expert? Answer questions, earn points and help others
