Question about Electrical Supplies
Generac xp8000e governor adjustment - Electrical Supplies
3 Suggested Answers
mydogisk
  • 50 Answers
SOURCE: Guardian generac 10kw model 5502 does not output correct voltage
the instructions says the voltage regulator is automatic/digital. when you check the voltage is there any load on the generator? if applying load to the generator doesn't help, you can manually change the motor speed where the governor connects to the carborator, but it may change the frequency, but the regulator may fix it
Posted on Apr 13, 2009
SOURCE: need adjustment procedure for a Generac Centurion generator, carb and regulator under full load
Before you adjust anything, suggest you verify gas line for proper pressure and importantly volume. Pressure for gas should be 5 to 7 inches and propane 11 to 14 inches W.C. Also make sure the line to the generator is sized properly and the gas meter is a high volume unit (if NG). 90% we find the problem with generator sunder load that otherwise are fine are fuel related. Good luck.
Posted on Sep 19, 2012
Generac XP8000E how do you replace the battery charger fuse 1.5 all I can find out is you have to remove the control panel. No manual and can't find any info
Roger,
1st check the voltage going into the Battery Charging Rectifier from the alternator. You should get between 12 Volts DC to 16 Volt DC with the engine running.
If you get these results next check the battery. You should get max 13v dc going to the battery. If your battery is not charging on this unit or gets under 12x dc, you need to replace the battery charging rectifier.
http://www.generatorguru.com/battery-charging-rectifier-99302775/
If you need other parts you can find them on this page.
http://www.generatorguru.com/xp8000e/
Hope this is of assistance to you!
Dec 19, 2016 | Generac Electrical Supplies
How to set up governor for Generac GN-220 motor
The circuit board controller is monitoring the engine rpm and frequency and thus controls the frequency, via the governor actuator, or stepper motor as you say. You can't adjust it. I doubt this is the problem it sounds like either engine is not delivering HP, or there is a stator short causing excessive load / current draw bogging the unit down, incorrect wiring of the stator output. Ha someone taken the stator output leads off the breaker? check the stator resistance and shorts to ground.
Feb 16, 2015 | Generac Electrical Supplies
I have a generac mc alternator model -38 6938 my voltage pulsates underamload just started any ideas
Cleaned and adjust carburetor per Repair Manual. then adjust governor repair manual and should take care of problem on this old generator.
https://www.generator-parts.com/manuals/generac-rv/051834.pdf
Jan 07, 2015 | Generac Electrical Supplies
Reset change oil message on generac xp8000e
There is no way to reset it manually. It resets automatically after you run it a few hours.
Nov 03, 2012 | Generac 5606 XP Series XP8000E 12,000 Watt...
Where can i get a new battery for my generac xp8000e?
Well, check your farm supply/hardware stores... some larger hardware chains may carry this battery and even the auto parts stores, some will carry these smaller batteries. Take down the make and model of the generator, or even better, take the battery along and they can fit you up with an alternative brand that will fit the space and provide the proper voltage to crank the generator.
:o)
Jan 04, 2011 | Generac 5606 XP Series XP8000E 12,000 Watt...
Have XP 8000e Generac -5 months old, Tires are supposed to be solid but have gone about completly flat on bottom, don.t seem solid like ones in store but no place to air up ...cb
These tires are made of a hard plastic with thick sidewalls to hold the generator up. They are not repairable once the sidewalls break down and collapse. The only option is to replace them. If you're still under warranty you can get them replaced under that. Only problem is you'll get the same kind of tires, unless Generac has updated them, and have the same problem in another five to six months. Your best bet is to do some research and find some truly pneumatic or solid/foam filled tires for your generator.
Dec 23, 2010 | Generac 5606 XP Series XP8000E 12,000 Watt...
Gererator turns off when i turn the idle control switch on generac 7500
the governor or or the idle coil assy needs to be replaced. Possible that a adjustment could be made.
Feb 07, 2010 | Generac 5622 GP Series GP5000 6,250 Watt...
Governor problem on 9 hp vanguard engine
Go online to Generac and they have parts list and owners manuals online. They will ship you parts.
Jun 25, 2009 | Generac 5724 GP Series GP3250 Portable Gas...
Apr 12, 2009 | Guardian Electrical Supplies
Electrical Supplies Logo
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
