Question about Frigidaire Refrigerators
Blinking H1 error code - Frigidaire Refrigerators
Have error code H1 on my freezer. I have it set on 5 what does it need to be
Frigidaire Refrigerator Error Code = H1
Condition = Freezer sensor shorted in freezer display
Repair or Check = Check wiring between thermistor and board. If correct, replace thermistor
Parts Needed = Thermistor (temp sensor)
Jul 05, 2017 | Refrigerators
What the code h1 means samsung washing machine
H1 on a samsung washer is a heating problem.
You need to check the heater and the control unit and find the fault form there.
If you have a multimeter you can test the heater as it should read about 28 ohms. If faulty then the heater will need to be replaced to cure this.
Check it out and see what you find but the H1 error code is a heating problem.
~~~via just answers
Feb 14, 2016 | Samsung Washing Machines
What does H1 code indicate?
Hello E, I appreciate your post!
I see that your Frigidaire air conditioner is displaying an error code of "H1". I have reviewed the air conditioner and the "H1" error code could be an "HI". The "HI" error code means that the room temperature is above the display range. I would recommend performing a reset on your air conditioner. In order to reset the air conditioner you need to unplug the power cord you can press the reset button and then the test button that should restart your air conditioner. If that does correct your issue I would recommend seeking assistance from a professional technician for proper diagnosis and repair. I hope this information is helpful for you. -Matt
Jan 22, 2016 | Frigidaire FRS12PYS1 12000 BTU Split...
What to do when h1 is flashed in ifb automatic front load washing machine
Cannot find anything about H1, but error code E01 is door not closed properly. An instrument at work sometimes reads "h1" and this indicates a "high" reading, but don't know if that is really relevant here. Sorry I can't help any further. Good luck.
May 19, 2015 | IFB Washing Machines
ASKO TL751 error messages ?
Asko dryers as model T760 or T780 indicate failure by error message (like "Overflow", "Sensor", "Thermistor", ...) while the model TL751 indicate failure by error code ("H1", "H2", ...)
Below you can see a list of error codes:
H1 error - Humidity sensor error
H2 error - Drying temperature sensor open/short error
H5 error - Heater overheated (ELECTRIC TYPE)
Heater disconnection check and H4/H6 error (ELECTRIC TYPE)
H3 Error - Flame Detector Open Defect (Gas Type)
H7 Error - Gas Valve Defect or Gas Blocked-off (Gas Type)
H8 Error - Igniter Defect or Flame Detector Short (Gas Type)
Dado
Mar 31, 2015 | Asko TL751 Electric Dryer
H 1 flashing Frigidaire side by side
I appreciate your post, Sharon!
From the information you have provided your Frigidaire side by side refrigerator is displaying an "H1" error code. I was unable to locate that error code but I did find the error code "HI" which stands for high temperature inside of your freezer compartment. Check your freezer is it still cooling? If so it may just be a miscommunication within your refrigerator and you can clear that by disconnecting the power cord for roughly ten minutes. If you continue to experience an issue I would recommend having a professional technician out to perform a proper diagnosis and repair. This will help you avoid any unnecessary part purchases. Best of luck! -Matt
Mar 24, 2015 | Frigidaire Refrigerators
WHAT FFHS2322MS H1?
Hello friend, thank you for your post!
I understand that your Frigidaire refrigerator is providing a "H1" error code. However, "H1" is an invalid code. I show a code for "HI" and that stands for high temperature in the freezer compartment. If you are receiving this error code but your temperature is cold inside your freezer it could be a miscommunication within the board and I would perform a reset on your appliance by flipping the household circuit breaker for ten minutes. I hope this helps. -Matt
Aug 18, 2014 | Frigidaire FFHS2322MS
What is a blinking H1 mean?
Good Morning Friend, that's a great question!
Error code "H1" is actually "HI" meaning that your refrigerator has detected high temperature in freezer compartment. The recommended factory setting should be 0 degrees for the freezer compartment and 37 degrees for the fresh food compartment. Try setting the freezer temperature to "0" or a lower setting and allow 24 hours for the temperature to stabilize. The refrigerator should resume normal operations. I ask that you please follow up with a comment on the post, at your convenience to advise if further troubleshooting is needed or if your refrigerator status has changed successfully. Thank you! - Z
Aug 03, 2014 | Frigidaire Refrigerators
Lennox 8 series ms8-z0-2ap3a error code H1, defrost operation
h1: defrosting /normal operation/ normal defrost operation.
see more: Air Conditioning Fault Codes
Jan 16, 2013 | Lennox Heating & Cooling
Samsung washing machine error h1
hi !
look here : http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3369-generic-daewoo-washing-machine-and-washer-dryer-fault-codes.html
Aug 13, 2012 | Washing Machines
Refrigerators Logo
18 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
