Question about Husqvarna Lawn Tractor  25 HP 54in Deck Model YTH2454
I was mowing with my 1648 ariens but it only mows on one side
    Scholar:
  • 90 Answers
Check for a loose free wheeling blade. If blade is tight try to spin the blade and all should turn. If the blade turns freely without the rest turning, the pulley may be loose and the key sheared off which means you need to pull the cover to do more checking which may require removing the deck. I hope this helps.
Posted on Feb 04, 2015
  • 35 Answers
SOURCE: Mowing
I did the same thing. I replace the belt that turns the blades. The pressure of the impact had stretched the belt and was slipping on the pully that engages the blades. Try that first and check the other belts for tension, wear and condition....Also make sure all springs are attached, not stretched, and in good shape...Hope this is helpful....Joe
Posted on Dec 21, 2008
lester482529
  • 226 Answers
SOURCE: mowing deck makes ticking noise when blades are engaged.
A FEW THINGS TO LOOK AT ARE ,1THE PULLY SHIELDSMAKE SURE THEY AREN'T BENT TO CLOSE TO THE PULLEY'S.2 THE PULLEY BEARING'S MAY BE WORE OUT AND TO BREAK .3LOOK UNDER THE DECK TO MAKE SURE YOU DIDN'T GET SOMETHING TRAPED IN THE CUTTING DECK.HOPE THIS HELPED.
Posted on Jun 11, 2009
agent91
  • 2100 Answers
SOURCE: deck will not shed the grass
The only way to shred the grass while mowing is to have a pair of mulching blades on your mower, they work, but they wear out fast. They do in Florida anyway with all the sand. And don't for the grass to look a hayfield to mow it. You have to keep at it. Hope this helps.
Posted on Apr 04, 2010
kel1guy2002
  • 3740 Answers
SOURCE: loud screeching noise from mowing deck
A lound screeching is usally a belt problem. Possibly a tension spring has broken for the belt idler. OR there can be a blade bearing that is dry and spalling. In any case the source should identified and corrected asap. That noise is going to cost money and ignoring it can cost even more money. The idler pulley bearing can have also failed.
You can use about a 3 foot section of hose to listen for the source. Just be careful because if you get the hose in a drive pulley it will yank the hose out of your hand. I do NOT recommend sticking your hands in the belt driven parts areas at all.
If you locate the source and need help finding parts we can do that here.
Kelly
Posted on Apr 19, 2010
  • 2239 Answers
SOURCE: Battery drains while mowing - after about an hour I cannot engage blades if I stop mowing - I have to charge battery after each mow - Have changed battery thinking that was problem but it still contin
Charging system on the engine is not charging, either the charging coil under the flywheel is bad, or the regulator is not working, you need to check what voltage/amps is coming out of the system, before doing thsi just check all the battary leeds are tight also the negative battary leed has a good earth at the chassis.
Posted on Jul 06, 2012
Have an Ariens Max Zoom 60, when engage the mowing deck the engine loads up and RPM's drops way down" Have tightened and loosened belt, what else can I Try?
Something in the mower blade drive is binding up. That puts a drag on the engine and causes the slow down in RPM.
Jun 16, 2017 | Ariens Garden
Ariens mower stuck in mowing mode after replacing belt. How do I fix it? Also wont start without quick start. How do I fix that? It is for my elderly neighbor
sounds like belt is on wrong side of clutch pulley and either choke not working or carb left over winter with gas in it clogged a jet
model?
May 19, 2015 | Ariens Garden
Can i replace an ariens 46in mowing deck with a 42in deck
as long as the mounting hardware is the same. and you will have to use a different belt
Oct 28, 2014 | Ariens 46in Lawn Tractor 22hp Briggs ES
Husqvarna Lawn Tractor  25 HP 54in Deck Model YTH2454 Logo
90 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
