Question about Sony KP-51HW40 51" Rear Projection Television
Sony Trinitron 20" TV (KV-2093R) Suddenly Shut Off
Was watching TV live (not through Tivo) and suddenly the screen went black except for a horizontal green line came up on the middle of the screen for a second, then the green line shrank into a green dot and all went black.
No sound and no picture. The little red light on the front of the TV set was off, so there was no power on. Repeated tries to turn it on failed.
The picture had been excellent since the TV was new in 1986, so it's over 22 years old now. No previous trouble of any kind. Any idea what happened? Thanks!
  • duxquack Jun 23, 2009
    You're correct! Wouldn't make sense to spend any money fixing a TV set that old. Now I have to get rid of this heavy thing and replace it with an LCD flat panel--one with at least a 32" screen. Thanks!
  • rwc120 May 11, 2010
    Wow, if I got 22 years out of a T.V., personally, I would probably faint. Sorry I can't help with the problem, but I think I can understand because you get so used to something working good for so long, why does it have to end.?? Good luck!
  • Sony Master
  • 5,138 Answers
2 things that will cause that vertical IC or Yoke! Listen to this one went on service call 2wks ago Customer had a 50 INCH1988 pioneer big screen replaced 3 capacitors resolder poor connections TV is now working like New ?
Posted on Jun 23, 2009
Hi guys, TV Sony Trinitron KV-32LS35U The tv was working normally when suddenly went off and started a Red L.e.d flashing 2 times before steady green for 2 seconds. Please tell me it will not be too
the horizontal output transistor is not recieving any voltage or it is burnt out and since it could have shote some resistors around the fbt transformer
Jan 18, 2013 | Televison & Video
My sony trinitron 32" tv just went black and the
Hello
Six blinks of standby light in Sony TVs denotes the absence of horizontal oscillation.
No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
In most cases the Ic is foud defective. anyway check its soldering points for any loose contact, or bad solerings. Check the line drive transformer, a very little transformer soldered directly to the main printed circuit board, very close to the horizontal output transistor. Check its primary winidngs for open. If it gets open no horizontal drive signal will be present at the base of the horizontal output transitor, that also may the cause of horizontal stop.
Nov 20, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Top of screen slants on the right and left side horizontally
go in touch with SONY i assume ur set is still under warrenty.....call customer help and support
Mar 12, 2009 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Picture suddenly turned dark
hi the picture tube of ur tv has got damaged and it badly needs a replacement.. so its better to replace ur picture tube..
thank u rate me!!
Feb 08, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony FD Trinitron Wega Model KV-24FS 100 TV. Good morning from Arizona. The set is connected to Direct TV, and I use that remote, except when watching DVDs. A few days ago, the screen went blank, and the...
The 2X blink indicates that either the Horizontal output transistor is shorted, or the RGB amp is shorted (on the CV board).
The Horizontal output is probably the cause, and as a general rule, the flyback should be replaced along with the H-Out transistor. Good news is that Sony is pretty good about having parts in stock. In fact, a lot of times they will have the A board with all the parts on it for only a few bucks more than just the flyback, so you basically get a new TV (electronics-wise).
Any decent repair shop should help get the parts/do the repair for you if you don't have the electronic experience.
Hope this helps you...
Jan 09, 2009 | Sony FD Trinitron WEGA KV-24FS100 24" TV
Televesion went blank
Failure in the power supply, and or scan amplifiers, or high voltage area. Needs troubleshooting by an experienced TV tech.
Jerry G.
Jul 22, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony Trinitron 29inch Color TV
The 2 blinks are an indication of over-current. This is usually because of a shorted component. The most common is the horizontal output transistor. This will be a 3-legged part attached to a heat sink close to the flyback transformer (part with red wire coming out the top). This transistor will be marked C4856 or something similar. Update this with the exact marking and I'll provide you with the full part number and approximate cost.
Dan
Jul 14, 2008 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Sony Trinitron KV-27FS13
Good day.
Maybe there is a problem with eigther the vertical or horizontal circuitry of your unit. blinking lights indicate a problem associated with your flyback not being able to oscillate and distribute the supply for the tuner, audio, vertical...etc..
That is an internal problem pls refer to a qualified technician.
chris
Feb 17, 2008 | Sony KV-27FS13 27" TV
No picture and no sound,
Something shorted and shut your set down. Most likely the high voltage transformer shorted which also shorted the horizontal output transistor. Stargazer
Aug 01, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
1996 Sony 32" Trinitron - Suddenly lost picture and sound
The most common problem with TV was the failure of the Horizontal Output Transistor, this will also damage 2 transistors in the power supply and a resistor in the power supply also. (From memory): Horizontal Output location # Q501, 2 power supply transistors Locations Q601, Q602, and resistor Location R607. Also solder the Horizontal drive transformer, you can find it by following the circuit board from the base of the Horizontal output. Some models used an IC instead of the 2 transistors in the powersupply, it will have six legs and check like 2 transistors. Good Luck.
Jun 04, 2007 | Sony KV-32S26 32" TV
Sony KP-51HW40 51" Rear Projection Television Logo
295 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
